Tale of Two...tail pieces?
Discussion in 'Gibson Les Pauls' started by xmacvicar, Jul 21, 2017.
  1. xmacvicar
    xmacvicar Junior Member
    13
    13
    Mar 5, 2010
    I have two LP's
    A Traditional Sunburst & Traditional 1960 Zebra both 2011. I am a huge fan of Les Pauls, but truth be told I am just starting to really get into them from a historical and technical standpoint. I picked up the Les Paul manual by Terry Burrows and I do alot of my own setups, etc.
    Last night I tried top wrapping - wasn't really a fan so today I switched back to the regular setup. That is what has prompted me to make this post. My Traditional zebra is able to get the tail piece completely in/flush with the body and still maintain clearance against the bridge.
    My sunburst (with the 50's style neck) is NOT even close. For me to clear the strings from the bridge I need to get the tail piece way off the body.
    I find it humorous that there is such a huge difference between the two. Can anyone give me some tips or explanations as to why? I know not all Paul's are made the same, but that much of a difference seems extreme!
    Christosterone likes this.
  2. mudface
    mudface Senior Member
    4,535
    13,328
    Aug 29, 2016
    A photo of the bridge from the side ( E to the e ) of both guitars might help. I am kinda think'n that the bridge is leaning ever slightly toward the neck on the sunburst. The neck pitch may also be considered.
  3. xmacvicar
    13
    13
    Mar 5, 2010
  4. ARandall
    ARandall Senior Member
    11,796
    7,188
    Apr 16, 2012
    Position of intonation/saddles........done.
    stilwel, 1all's Pub, MSB and 2 others like this.
  5. PierM
    PierM Black & Gold Premium Member
    2,861
    4,365
    Aug 19, 2016
    Intonation is different and also you have a thicker stud insert hat, on the bottom guitar, which means that bridge is higher than the top one, so I guess you also have a delta between the two neck angles (assuming you have same action on both).
    1all's Pub and mudface like this.
  6. mudface
    4,535
    13,328
    Aug 29, 2016
    The saddles are reversed and the GT saddles seem taller, one of these bridges is a Tone-pro bridge (the sunburst) and one is not (the GT).
    As it looks to me anyways.....
  7. guysmiley
    guysmiley Senior Member
    649
    270
    Jun 11, 2009
    Different hardware different angles. Also, different break angles. I always found the shallower angel easier to bend.
  8. xmacvicar
    13
    13
    Mar 5, 2010
    I only have the low E reversed here because I ran out of 'space' when intonating. All the other saddles are in the normal position
    mudface likes this.
  9. xmacvicar
    13
    13
    Mar 5, 2010
    Hey can you elaborate on this? I am not sure what else I can do to get the tail piece down without getting into top wrapping. I mean, the strings are literally a bee's dick above the bridge here :p Maybe in this case I 'DONT need to get the tail piece down?
  10. PierM
    2,861
    4,365
    Aug 19, 2016
    Why you want the TP down? It's not an ABR1 so it's hard to make it all down without getting strings touching the back of the bridge.
  11. xmacvicar
    13
    13
    Mar 5, 2010
    I guess its not that I want to really...just seeing in next to the goldtop with the bridge all the way down got me wondering what the fundamental difference is. You always read online about tone purists thinking the tail piece should be right into the body for better tone/sustain, blah blah blah
    I looked at the official Gibson specs and it states my Goldtop is a "tune o matic" bridge and the Sunburst traditional is a 'nashville tune o matic"
  12. PierM
    2,861
    4,365
    Aug 19, 2016
    That is the point about saddles/intonation difference between the two, affecting the clearance at the back of the Nashville;
    1all's Pub, MSB, Donal and 1 other person like this.
  13. xmacvicar
    13
    13
    Mar 5, 2010
    I can see how you would think that from the side, but its just the 1 saddle - the low E. All the others are the same direction on both guitars
  14. ARandall
    11,796
    7,188
    Apr 16, 2012
    Its not the angle of the saddle he (and myself) are pointing out, but the position of the fulcrum/saddle top in relation to the rear of the bridge. It stands out to my luthiers eye as incredibly obvious, and the whole reason behind the difference with the t/p heights.
  15. Christosterone
    Christosterone Premium Member
    2,736
    2,389
    Jul 12, 2016
    Here's your problem:
    The tailpiece is the wrong one :naughty:
    -Chris
  16. Cjsinla
    Cjsinla Senior Member
    3,269
    2,397
    Jul 7, 2014
    These guitars are not all made the same. The necks are fit in by hand. If you watch a video, the luthier is actually shaving bits off the tenon off the neck to fit the joint. There will be differences from guitar to guitar. Slight variance in the neck angle will cause the difference you are seeing with tailpiece height. What you see is not a problem, it is a "feature."
  17. mudface
    4,535
    13,328
    Aug 29, 2016
    This is very true, the slightest angle of pitch will result in overall bridge height and intonation, this is why these pieces are adjustable.
    Even Fender guitars are relatively flat, they do perform better with a little neck pitch. Paper thin shims are used on older Fenders as today they have a pitch adjustment screw via an allen wrench.
    Replacing the bridge with Faber ABR might solve your issues.
  18. gball
    gball Senior Member
    604
    515
    Feb 23, 2016
    Yeah, I purposely keep mine a bit higher as they seem to feel a bit slinkier. I also call BS on having them all the way down improving the tone - IME it either makes no difference or if there is one the higher tailpiece sound better, more "open."
    PierM likes this.
  19. kakerlak
    kakerlak Senior Member
    1,538
    572
    Feb 5, 2014
    A lot of variables here -- I think position of the saddles (and not the direction the saddle is installed) is a big difference, as ARandall pointed out (cool gif, BTW!). It's tough to tell whether the bridge is much higher on the sunburst guitar, but that doesn't look too different. One more thing that's possible is a difference in top carve. If the top stays flatter under the tailpiece on the goldtop, that could be contributing some. If the sunburst one's top carve starts to curve away more under the tailpiece, then its tailpiece would sit a lot lower, relative to everything else, when it's screwed down tight.
    That one's tailpiece is sitting so tall I'd be tempted to top-wrap it.
  20. xmacvicar
    13
    13
    Mar 5, 2010
    You know. I did that last night. I'm not sure I was a fan. I found when I did aggressive pull off's on the high E like 3-5-0 for example, I was pulling the string off the fretboard and hearing that clink/ping. Actually even with the strings back to normal, I find my guitar is still kinda doing that!
