Sustain bar
Discussion in 'Luthier's Corner' started by FLICKOFLASH, Feb 21, 2015.
  1. FLICKOFLASH
    FLICKOFLASH V.I.P. Member
    24,749
    8,310
    Mar 18, 2007
    I am thinking of getting one made. Wondering if others maybe interested ? Thinking they could be put stealth under the maple cap with the use of longer screws.These came off of a Yamaha SG 2000 that I believe dates to 1977 - 1979 range.
    1 person likes this.
  2. Baylin
    Baylin Senior Member
    1,150
    846
    Feb 16, 2014
    Do they work or is it a gimmick? Just curious as I would have that vibration transmission in to the wood, would be better via smaller point such as standard bridge/tail studs.
  3. FLICKOFLASH
    24,749
    8,310
    Mar 18, 2007
    Les Pauls weakness is the bridge post as the only go into the maple top. Using longer post improve tome immensely. Imagine a telephone pole with only 5' in the ground vs one with 10'. So basically these give you a huge solid ground to transfer tone and energy. Carlos Santana is where these originated.
  4. Aj2pointo
    Aj2pointo Senior Member
    173
    64
    May 18, 2014
    Can you explain how it works exactly? I think I have an idea but not 100% sure. I am taking about how you mount/attach it not its function btw. I know I saw something along this line, except instead of the plate it was a solid bar of metal and it went under your tune o matic with no modification required. I can't remember where I saw it for sale though...
  5. Mr Teeny
    Mr Teeny Senior Member
    3,543
    2,402
    Dec 27, 2010
    The SG2000's have a thru neck rather than set neck so I guess the one length of wood and brass block to reduce any loss of energy to the body all help. The block just goes directly into a routed recess
  6. Douzydo
    Douzydo Junior Member
    2
    0
    Jul 15, 2014
    Hey guys old post I know but I'm looking to make a sustain block and wondered if any one has the measurements of the Yamaha one ?
    Thanks in advance
  7. ARandall
    ARandall Senior Member
    11,504
    6,747
    Apr 16, 2012
    That looks to be the same dimension as a Nashville bridge.
    But if you're making one yourself the absolute dimension is less important. You can make it any size/depth you choose.
    Be aware that in adding this sort of thing that whilst it will change things.....there is no guarantee that you will like what it does. If I were to place generic odds then I'd say it would be a 50/50 proposition. Plenty have tried the mapleflame mod (longer abr posts) only to find it made things worse.
