Stuck on the old server.
Discussion in 'Front Desk' started by onedaycloser, Jan 17, 2010.
  1. onedaycloser
    onedaycloser Senior Member
    686
    7
    Oct 29, 2009
    Can anyone help me get over to the new site? I can see there is a difference between the site on my PC versus what is on my phone.
    There's about 20 people or so still stuck over there including myself and River.
    This isn't a joke.
  2. Boleskinehouse
    Boleskinehouse Senior Member
    27,350
    2,251
    Feb 1, 2008
    I've been trying to help River get in. Nothing works.
  3. BMS
    BMS Senior Member
    4,693
    616
    May 18, 2009
    That sucks. :(
  4. onedaycloser
    686
    7
    Oct 29, 2009
    Anyone? A mod, Alex? This is pretty shitty.
  5. FLICKOFLASH
    FLICKOFLASH V.I.P. Member
    24,756
    8,316
    Mar 18, 2007
    I emailed Alex
  6. onedaycloser
    686
    7
    Oct 29, 2009
    Thanks, we've been trying EVERYTHING over there and nothing helps. Been at or 4-5 hrs now.
  7. mobprop667
    mobprop667 V.I.P. Member
    8,571
    6,918
    Feb 7, 2008
    i got over to the new server. dont know how, but after many hours, here i am.
  8. kmk108
    kmk108 Senior Member
    12,904
    8,334
    Oct 18, 2009
    What's the difference? Nothing looks different on mine.
  9. The_Sentry
    The_Sentry Senior Member
    27,005
    9,328
    Dec 12, 2008
    Are you crazy mayn? Dig that new Server smell! :dude:
  10. mobprop667
    8,571
    6,918
    Feb 7, 2008
    there are a lot less users on it, and no new posts other than what the few users that are on there are posting, including any threads that you may start. they end up on the new server and you cant see them.
  11. mobprop667
    8,571
    6,918
    Feb 7, 2008
    this server has SlashRAM
  12. dubyatf
    dubyatf Senior Member
    2,192
    20
    Oct 21, 2007
    You clicked your heals - didn't you? :laugh2:
  13. mobprop667
    8,571
    6,918
    Feb 7, 2008
    everytime i did that i ended up at the wizard of ozforum.
  14. djwilbanks
    djwilbanks V.I.P. Member
    28,339
    7,705
    May 16, 2008
    Cleared your cache? Reset your browser? Deleted cookies and temporary Internet files?
    If none of that works then the server has become self-aware and SkyNet is playing a horrible joke on you.
  15. FLICKOFLASH
    24,756
    8,316
    Mar 18, 2007
    Changes to domain name information in registry-controlled DNS zones are generally not instantaneous.
    Once you make changes to your domain with the registrar you purchased your domain from, the changes will first have to be uploaded to the registry, which will then update its DNS servers with the new information. ISPs DNS resolvers can then pick up this information through a sequence of stages, a simplified version of which is as follows:
    the DNS resolver queries the DNS root servers for the registry's DNS server information
    it then queries the registrar's DNS servers for the domain's own DNS server information
    finally, it queries the domain's own DNS servers (which are typically run either by or on behalf of the domain's owners, often by the domain registrar that issued domain) for the domain's detailed DNS information
    In practice, this process may involve several extra more cascades of DNS lookups than are described here, but the effect is ultimately roughly the same as the above.
    Once an ISP's DNS resolvers have obtained your DNS record information, they then cache it for a period which may vary from ISP to ISP. This time is generally controlled by the TTL field of each DNS record, but some ISPs may hold the data for a longer or shorter period, depending on the particular software and settings they are using on their DNS resolvers.
    As a result, it may take several days for changes to a domain's DNS records to propagate throughout the Internet; firstly the information must propagate from your registrar to the registry, secondly the registry must update its own DNS servers, and thirdly the ISPs recursive resolvers must forget their cached copies of any previous settings.
    [edit] Domain propagation and domain expiry
    When a domain name expires, the registrar, who still has control over the domain's DNS information via the registry, might take it for domain parking, which results in web requests seeing a different page altogather as its DNS records are now changed, typically to point to a webserver controlled by the registry or a domain parking aggregator. The new name server information is then cached with the querying DNS resolver for the standard time to live. Even after renewing the domain name and changing the name server to the original state, it will not resolve to the original website since it takes time for the cache memory to clear.
    In this situation, renewal sometimes can be confirmed by visiting the website through a proxy site
  16. dubyatf
    2,192
    20
    Oct 21, 2007
    One can only imagine the horrors happening to those left behind on the 'I Am Legend' server!
  17. djwilbanks
    28,339
    7,705
    May 16, 2008
    Weeping, gnashing of teeth... and probably the distinct smell of brimstone and flaming jheri-curl. :Ohno:
  18. dubyatf
    2,192
    20
    Oct 21, 2007
    Jheri-Curl! Oh the humanity! :laugh2:
  19. mobprop667
    8,571
    6,918
    Feb 7, 2008
    i actually killed and ate one of the users logged on as "guest" and declared myself as emporer of the old MLP.
  20. dubyatf
    2,192
    20
    Oct 21, 2007
    That's awesome! :thumb: That's *the* only way to start an empire. Now, you need a ship and a flag - and go get some more servers!! :laugh2:
