String buzz
Discussion in 'Epiphone Les Pauls' started by RandolphT, Jan 25, 2011.
  1. RandolphT
    RandolphT Senior Member
    379
    9
    Dec 29, 2009
    Whenever I put strings on I get this odd distinctive buzz, Only me haha
    When someone else puts on strings they don't have this buzz.
    Seems more like a metallic ring
    I got my guitar setup professional from a friend for free and they installed the strings the way I do and the strings don't have the buzz.
    I use the string locking method at the tuners
    Help is appreciated and well needed.
    Sorry If something up there is screwed up I'm tired ...:shock:
    Sound clip:
    no - shit
    Sorry for shitty little riff, just wanted to get help
  2. AJLaveaux
    AJLaveaux Member
    79
    1
    Jan 25, 2011
    what frets does it buzz on?
  3. RandolphT
    379
    9
    Dec 29, 2009
    It is not fret buzz.
  4. AJLaveaux
    AJLaveaux Member
    79
    1
    Jan 25, 2011
    perhaps whoever else does it oils the strings, you tried slapping a bit of fast fret on there?
  5. RandolphT
    379
    9
    Dec 29, 2009
  6. kiddakidda
    kiddakidda Senior Member
    348
    17
    May 30, 2010
    Most guitars MAY buzz slightly and can depend on playing style such as how much your 'digging in'.
    I have listened to your clip and there is nothing that really stands out. Maybe you should record sound clips of the buzz on individual strings/frets playimg single notes.
    Good luck.
  7. sammyblp
    sammyblp Senior Member
    1,573
    921
    Oct 26, 2010
    is it the pickups that buzz?
  8. Koop
    Koop Senior Member
    184
    73
    Oct 18, 2010
    How are you stringing it? If you wind the string to the top of the machine head you may be causing an issue at the nut. There are a few different techniques for locking the string to the tuner and only using a few wraps. The last wraps should always be towards the headstock, not towards the top of the tuning post.
  9. AJLaveaux
    AJLaveaux Member
    79
    1
    Jan 25, 2011
    I've found that doing the first turn under the hole, the second over it then the rest under gets great effect. Plus 3 wraps looks pretty :naughty:
  10. RandolphT
    379
    9
    Dec 29, 2009
    I do all of my wraps towards the headstock
    2 Wraps E
    2 Wraps A
    3 Wraps D
    3 G
    2 B
    3 HE
  11. morb
    morb Junior Member
    13
    0
    Dec 16, 2010
    I have this issue! :s
    By playing certain low notes my pickups buzz... any idea how to resolve?
  12. RandolphT
    379
    9
    Dec 29, 2009
    Pups too high Lower them
    bad pups?
    Bad ground?
  13. morb
    morb Junior Member
    13
    0
    Dec 16, 2010
    Only with the neck pickup which is set quite low.
    Note that it's not a buzz through the amp but the pickup itself is buzzing/vibrating lol
  14. Phatius
    Phatius Member
    87
    2
    Nov 14, 2010
    maybe its your bridge. that little wire that holds the saddles in place on Epi bridges can get lose n make a buzzing noise. i replaced mine with a Gotoh TOM bridge. but like others ive heard from, have the same problem with the holes for the post bring a little too big. but its not really a problem with the strings holding it in place.
    try holding the wire down while strumming. if you don't hear the buzz then it's probably the bridge.
  15. Drew224
    Drew224 "Obvious BS Artist" V.I.P. Member
    16,575
    7,765
    Oct 11, 2009
    Mine used to buzz like that, just a little. But it's gotten worse as the frets have worn down in the middle register.
  16. RandolphT
    379
    9
    Dec 29, 2009
    Mine has no retaining wire so that can't buzz, like I said its more of a ring
  17. AJLaveaux
    AJLaveaux Member
    79
    1
    Jan 25, 2011
    Aren't guitars supposed to make that noise?
  18. crazytrain77
    crazytrain77 Senior Member
    254
    22
    Jan 16, 2011
    It could just be that some of the hardware is loose. My advice would be to just take it in to a luthier to find out what the problem could be its hard to say. The reason someone asked what frets it was earlier is that it could just be a simple set up problem and the string is coming in contact with a fret in either the upper or lower register. Does it buzz when you move the guitar around? Only when its plugged in? Does the buzz seem to come from the headstock?
  19. morb
    morb Junior Member
    13
    0
    Dec 16, 2010
    I also have that... what is it?
  20. morb
    morb Junior Member
    13
    0
    Dec 16, 2010
    No one? :)
