Strat switches.
Discussion in 'The Custom Shop' started by thefraggle, Jul 21, 2017.
  1. thefraggle
    thefraggle Senior Member
    101
    49
    May 6, 2015
    I've been thinking....... My Frankenstrat.... I would love to have some very clear on and off switches for each of the pickup's . It's got the normal strat switches but I want to be able to simply switch them off as I decide. 1500663013050351091858.jpg
  2. chasenblues
    chasenblues Senior Member
    20,791
    30,747
    Apr 2, 2007
  3. thefraggle
    101
    49
    May 6, 2015
    Which one would give me independent control of each pick up without effecting the others so I could effectively pick and choose which pups are working?
    By the way, massive thank you for replying
  4. chasenblues
    20,791
    30,747
    Apr 2, 2007
    I've never done the mods myself in all honesty..
    But going by that first diagram they're just your basic on/off switches for each individual pickup.
    You might have an issue with that type of wiring if you like/use the now "standard" strat type 5 way switch.(Think of Positions #2 & #4)
    You'd have to figure out how to wire the #2 and #4 positions of the 5 way switch with the switches you want to use. I didn't read the link i posted but that type of switching is probably covered in there somewhere.
  5. kakerlak
    kakerlak Senior Member
    1,534
    570
    Feb 5, 2014
    I think individual mini-toggles are too finicky. Want to go from one setting to another? You might have to flip all three switches to get there (e.g. go from neck only to bridge+middle). I like G&L's S-500 wiring better, which is the standard strat 5-way, plus a mini-toggle that turns on both neck and bridge, which allows the two "missing" positions (neck+bridge and all three on). With the switch engaged, you get neck+bridge when the 5-way is at either end of its sweep and all three on with the switch in positions 2-4. Easier to use on the fly in my experience.
  6. DarrellV
    15,375
    32,588
    Nov 1, 2016
    @OHIOSTEVE did the 3 toggle mod to his strat , maybe we can get him to post a pic in here ...
  7. OHIOSTEVE
    OHIOSTEVE Senior Member
    4,801
    5,320
    Jan 3, 2015
    I used tbe first diagram... Love it.... Buy good switches and turn em so they flip front to back not up and down.... 20170509_233536.jpg
  8. OHIOSTEVE
    4,801
    5,320
    Jan 3, 2015
    Setting in waffle house after a show... I did another fernandes for a friend.. Lemme see if I have pics
  9. OHIOSTEVE
    4,801
    5,320
    Jan 3, 2015
  10. OHIOSTEVE
    4,801
    5,320
    Jan 3, 2015
    You can buy guards ut for this mod.. I just glued a knob over the hole.
  11. OHIOSTEVE
    4,801
    5,320
    Jan 3, 2015
    I apologize.. I did not use the first diagram. That has 2 tones. I have 1 and 1
  12. OHIOSTEVE
    4,801
    5,320
    Jan 3, 2015
  13. Tubejockey
    Tubejockey Member
    35
    43
    Oct 22, 2017
    If you really want the best useable tones, with none of the bad ones, in a simple to use and intuitive setup, try this.
