Strat Mods to Improve Primary Tone
Discussion in 'Fender' started by FLICKOFLASH, Apr 5, 2009.
  1. FLICKOFLASH
    FLICKOFLASH V.I.P. Member
    24,753
    8,315
    Mar 18, 2007
  2. cooljuk
    13,998
    17,657
    Mar 12, 2009
    What's under the hood there regarding your electronics? I think I see an oil drum and a Pentium processor?
  3. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    Eric Clapton Mid-Boost and a TBX pot
    SteveGangi likes this.
  4. cooljuk
    13,998
    17,657
    Mar 12, 2009
    Roger that. I had not seen a Clapton mid-boost from the inside. There's more to it than I imagined.
  5. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    It is like a gain pedal built in the guitar with a 25db boost
  6. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    Next I plan to add these
    79standard likes this.
  7. cooljuk
    13,998
    17,657
    Mar 12, 2009
    I'd like to put some of those into a 3 bolt Tele to use as a travel guitar. Off the course of this thread, but it would be really handy to loosen the strings, remove the three neck screws, and fold the neck over the body and throw it in a small gym bag.
    Hey if they improved the tone - even better!
  8. slapshot
    slapshot Senior Member
    22,963
    23,646
    Aug 21, 2010
    i had a 60s japanese mosrite copy that was really really bad in the screw department.I had these laying around and rather than dowel & drill I gave em a razz.
    rock.solid.
    tone change?hmm maybe more sustain?
  9. Thundergod
    Thundergod Senior Member
    10,818
    10,991
    Sep 11, 2008
    The backplate changes tone? I didn't know that. My OCD wouldn't let me play them without the backplate tho :laugh2:
    79standard and SteveGangi like this.
  10. Dolebludger
    Dolebludger Premium Member
    12,561
    10,722
    Feb 11, 2009
    What is an OCD? And BTW, there is a thread on the "Tonefreaks" portion of this forum where actual players are denying that tonewood and the manner of string contact therewith makes a difference in amplified tone!!! Help me by cheking it out and commenting.
    And what is this Clapton mid booster? What does it do? Where can it be bought? how much?
  11. cooljuk
    13,998
    17,657
    Mar 12, 2009
    If nothing else, it's like an acoustic panel that vibrates sympatheticly with the guitar and the trem springs. Also you can hear the trem springs vibrating more with it off. It's an obvious difference acoustically, IMO.
    Some people think that doesn't mean anything once you crank the amp up. I'm in the camp that thinks if it makes an acoustic difference, that will transfer to the pickups, at least a little. Pickups are all a bit microphonic. Just tap on them and listen. Your finger isn't ferrous.
  12. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    Stick tubing inside the springs to stop the reverb vibrations. Helps with sustain as the strings ring longer
  13. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    Sand your neck pocket and the bottom of neck before using these .It creates a virtual one piece Body /neck connection better than glued in (as the glue acts like a casket barrier.) These torque very hard.
    1 person likes this.
  14. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    [ame=http://www.youtube.com/watch?v=O0Oyc6slYRc&feature=relmfu]How to keep your Strat tremolo in tune. Frudua Way - www.frudua.com - YouTube[/ame]
    I have been using this method and havs 0 tuning issues.I am very pleased let me tell you !!!
    4 people like this.
  15. cooljuk
    13,998
    17,657
    Mar 12, 2009
    :thumb:
    Ya, man. I've been following that method since the first time I tried it without fail. Ya gotta use good strings too, but once they are stretched and settled in just like that - rock solid tuning!
  16. FLICKOFLASH
    24,753
    8,315
    Mar 18, 2007
    I have found pure nickel strings and heavy gauge thicken up the tone.
  17. opalburn
    opalburn Senior Member
    801
    153
    Aug 12, 2008
    i've got those in mine... i have an 84 mij squier, so the truss rod adjustment is on the heel of the neck. and the wood bolts were a little loose, causing the neck to shift and get a little crooked.. put these in, and now the neck is so snug, i'm not sure i can even get it off again.. it's kinda ridiculous how tight i had to screw these down, but no more neck wobble..
  18. ozzmcom
    ozzmcom Senior Member
    441
    765
    Mar 29, 2012
    so I don't get this string tying . The guy says you should do no more than 3 rounds.
    I do only 1 round going straight to the hole is that good or bad.
  19. jd2112
    jd2112 Senior Member
    190
    149
    Apr 29, 2012
    I removed the back plate on mine.It made a small difference in tone.String changes are much easier now!
  20. vladmaximus
    vladmaximus Senior Member
    2,550
    250
    Sep 6, 2008
    Hmmm..how bout this EARVANA NUT !!!
    check this video guys...
    [ame=http://www.youtube.com/watch?v=a-TxGkG6jJY]Earvana - Compensated Tuning Systems for Guitars - YouTube[/ame]
