Standard vs. Short Spacing PAF
Discussion in 'Pickups' started by sangandongo, Jun 30, 2017.
  1. sangandongo
    sangandongo V.I.P. Member
    1,804
    621
    May 3, 2009
    Hi all,
    I just got a 1958 Byrdland with the original PAFs still in. These guys tend not to be as molested as other models because the pole spacing is tighter than standard PAFs due to the thinner neck and scale.
    I'm curious if anybody has A/B'd the short spacing against a standard PAF? If so, what are your thoughts?
    Thanks!
    cooljuk likes this.
  2. cooljuk
    14,091
    17,954
    Mar 12, 2009
    The sonic differences from one PAF to another PAF of the same spacing from that time are more significant than the sonic difference in different pole spacing.
    It's not like today's modern pole spacing differences in pickups, where the bobbins themselves are actually longer, resulting in more length of wire used per turn and a significant change in the properties of the coils. The pole pieces are just closer to each other. Same amount of the same steel mass inside the same coil with the same inductive properties, for the most part.
    You're not rolling the dice on the sound any more than you would be on a wider spaced PAF of the same era.
    Blue Blood, jcsk8 and DarrellV like this.
  3. sangandongo
    1,804
    621
    May 3, 2009
    Thanks. This thing sounds like a million bucks. I just wasn't sure what the actual differences between the pickups were aside from the spacing. I appreciate the clarification.
  4. DarrellV
    15,384
    32,604
    Nov 1, 2016
    OP you're a lucky guy! I'd like to see pics of that old Byrdland! :photos:
    I have a question for James that's related more to the pickup response in relation to the pole pieces being offset.
    Is there a response hit if the pole spacing isn't correct for the string spacing on the guitar?
    Mine are Shaw PAF's and I have been wondering for a while now if there might be a sonic penalty of any sort in the bridge pickup due to the way off center pole pieces as seen in the pic below.
  5. sangandongo
    1,804
    621
    May 3, 2009
    I'll venture a response on this one.
    In my experience, there's little difference in output between an F-spaced and G-spaced humbucker. If you look at the magnetic field of the pickup, you see that the strings sit well within them whether or not the poles line up perfectly with the strings. Bringing the poles closer will create a different response, but realistically, it's more aesthetic than practical in difference.
    DarrellV likes this.
  6. DarrellV
    15,384
    32,604
    Nov 1, 2016
    Thank you, sir!
  7. cooljuk
    14,091
    17,954
    Mar 12, 2009
    I couldn't tell you the difference in sound of a Les Paul with PAFs that has the pole pieces all lined up with the strings, as I've never seen one.
    The strings don't waggle around much at the bridge when you play so unless one of your E strings is too quiet, I'd just forget all about the alignment.
    sangandongo likes this.
  8. sangandongo
    1,804
    621
    May 3, 2009
    Here you go.
    I removed the celluloid pick guard because it was off-gassing badly. You can see the corrosion on the upper frets and on the high string side of the pickups.
    Blue Blood and cooljuk like this.
  9. chasenblues
    chasenblues Senior Member
    20,795
    30,775
    Apr 2, 2007
    But..But..But what about the blogs/websites/internet vids/ that say..??
    Oh my gosh i feel woozy...
    :laugh2:
    DarrellV and cooljuk like this.
  10. cooljuk
    14,091
    17,954
    Mar 12, 2009
    It matters more in Fender style single coils with AlNiCo pole pieces.
    The magnetic flux is so dense at the end of those rod magnets, and the top of the strings are so close to the magnet's polar surface, that you only have to move the string or pickup a little to the side to reduce the magnetic flux density by a great degree - maybe even more than a 50% difference with a 1/4" move?
    You simply don't have that kind of extreme range in flux density over the surface of a PAF. It's far more evenly spread.
  11. DarrellV
    15,384
    32,604
    Nov 1, 2016
    :lol::lol::lol::lol:
    Once again, Chasen delivers the goods!:cheers:
    thank you both for the replies.
    James it looks like its only a matter of uniform spacing (of course they are mass produced) being used in both positions.
    In my example the neck lines up perfect, but the strings widen more toward the bridge causing the mis alignment.
    In OP's Byrdland they are proper spaced, but the neck and spacing is thinner so it works for that model.
    And BTW @chasenblues , is that a laminated neck! :wow: Before Norlin! :run:
    Oh, we could have some fun with that too! :rofl:
    cooljuk likes this.
  12. DarrellV
    15,384
    32,604
    Nov 1, 2016
    :wow::wow::wow::wow:
    Dang, I KNEW I should have gotten bibbed up first! :drool:
    That's positively stunning! :cheers:
    Thanks for sharing! :applause:
    I wouldn't worry too much about the spots.....On a human they would be called beauty marks!
  13. chasenblues
    20,795
    30,775
    Apr 2, 2007
    I was just referencing/joking about lining up (or not) the slots on the screw heads on adjustable pole pieces.
    It may be true/have some effect..I don't know
    cooljuk likes this.
  14. cooljuk
    14,091
    17,954
    Mar 12, 2009
    Ya, I dig it. Alignment is way more important with Fender style singles than PAF style pickups, so there's a little truth to that part, at least.
    Lining up the pole screw slots - I have only head of lining up the slots for looks or for not having the slot alined with the strings, as to catch them while playing. I just move them to where they sound good. I do have a certain slot pattern and stagger I put on the buckers I ship out, but that's just me trying to be a neat craftsman. Like an electrician who lines up all the screw slots on your outlets and switches or bank facing bills. Not really a critical listening point or anything. Just a rough guess of what sounds good and looks good. Plus Gibson did it like \ / \ / \ / so I do it for that reason a bit too. For sound, I just adjust to taste once installed in the guitar.
  15. cooljuk
    14,091
    17,954
    Mar 12, 2009
    I agree completely. It's much easier to have one set of tools, parts, products and use that one product for both bridge and neck. As Gibson discovered, the spacing wasn't actually that critical anyway. They only made "humbuckers" and not "bridge" or "neck" specific pickups until the very end of the 1970's, with rare exception - like that Byrdland pickup and some P-90s and stuff for jazz boxes.
  16. chasenblues
    20,795
    30,775
    Apr 2, 2007
    I watched a little bit of a video the other day about adjusting the pole pieces..
    The guy made a statement to effect to make sure when you adjust them don't put the slot in the head directly under the string..| because there is less of a magnetic field that way.:shock:
    Now maybe he's got a valid point idk..But i'd never heard that one before.
    I've read/seen about adjusting them with a radius and the way you've described and a couple others. But that one was a new one to me.
    cooljuk likes this.
  17. cooljuk
    14,091
    17,954
    Mar 12, 2009
    What if it's a Phillips head screw?! :run:
  18. chasenblues
    20,795
    30,775
    Apr 2, 2007
    Or an socket/Allen head? :dunno:
  19. DarrellV
    15,384
    32,604
    Nov 1, 2016
    Or a DiMarzio hollow hex head? :wow:
    sorry, Chasen....
  20. cooljuk
    14,091
    17,954
    Mar 12, 2009
    The only sensible option is to be like Rickenbacker and use painted iron nails.
    sangandongo and DarrellV like this.
