Sound card upgrade
Discussion in 'Recording Studio' started by ricky1918, Apr 25, 2017.
  1. ricky1918
    ricky1918 Senior Member
    400
    183
    Jun 26, 2014
    Hello gentlemen,
    I'm in need of a sound card with more analog outputs.
    Right now I'm using a Focusrite 18i8, which has only 2 main outs.
    My problem is that in a live situation I'd rather send to the mixer different signals for the FOH and the stage monitors, but right now I can only have the FOH sound on stage.
    My question is, would a Motu 828mk2 be "too old" hardware-wise to keep up with my needs?
    Consider that I'm using an MBP from mid 2011, with 8GB Ram, Ableton Live and 7/8 inputs live (5 synths, 2 mics and a guitar)
  2. DarrellV
    15,435
    32,898
    Nov 1, 2016
    Looks like your unit has SPDIF I/O as well.
    You could try something like this to get 2 more channels of audio out.
    My Saffires offer different assignable streams to SPDIF and mains out.
    Yours might work the same.
    SPDIF by spec is a stereo (2 channel) signal.
  3. ricky1918
    400
    183
    Jun 26, 2014
    I thought about using the SPDIF out, but considering the smd2a costs 130$, I'd spend less selling my 18i8 to get a bigger sound card!
    Also I was talking with the other members of the band, and realized we'd need more outputs.
    It would be:
    2 main outs without voices and guitar
    3 outs to send to the mixer with voices and guitar
    2 outputs for the IEM
    So this way the sound guy can mix the stuff as it works best without us having to modify settings on mixcontrol
    I'm talking with a guy for a Focusrite Saffire Pro 40, think I'll get that one!
    edit: I'd get the saffire pro 40 for about 250€, hoping to sell the 18i8 for about 200 it would be a nice deal
  4. LenPaul
    LenPaul Premium Member
    2,914
    3,986
    Jul 13, 2012
    The motu 828 mk2 would give you 2 main outs + 8 other analogue outs.
    Older unit, Still supported & works as expected on latest Mac OS.
  5. DarrellV
    15,435
    32,898
    Nov 1, 2016
    I have 2 saffire pro 40's! Love them!
    They come with a mix utility program (a virtual patchbay & mixer) That takes some getting used to because it is very flexible!
    It can even be used in the field AS your mixer using the firewire connection to a laptop.
    The pro 40 out of the box already has 4 outputs; 2 main(monitor in white stripe) and 2 independent headphone outs. Plus 6 more line outs to equal the 8 inputs.
    FWIW I run mine in series with my mixer. I bought a small 12 ft XLR Male to 1/4 balanced snake.
    I assign each output to the same number input.
    I then plug the snake XLR's 1-8 into my mixer 1-8.
    Plug all your mics into saffire inputs (1&2 are on the front)
    Now you can record on all 8 if you want.
    In your case I would plug the snake into 3-8 and leave 1 and 2 open for now.
    You can also send monitor mixes to IEM from your mixer OR using 1 of the pro 40 headphone outs.
    You could send mains mix out of lines 1 and 2 that you left open as mentioned above for this reason.
    Outputs 3-8 are already going into your mixer. Mix away!
    you can also record this mess if you have a laptop with firewire and asio support.
    Mine is rock solid under win 7.
  6. LenPaul
    2,914
    3,986
    Jul 13, 2012
    For 8 ins & 8 outs, Mac OS, mid range budget, I'd suggest metric halo ,, but it may be overkill . $ wise.
    quality or quantity. the wallet always makes the final decision.
  7. ricky1918
    400
    183
    Jun 26, 2014
    Metric Halo is a little bit out of our league haha
    I'll call the guy tomorrow and hope to get the saffire by thursday evening.
    I already have a rack with the IEM and space for a power conditioner that will come next.
    Thanks everyone!
  8. LenPaul
    2,914
    3,986
    Jul 13, 2012
