Something to cover a strap button hole?
Discussion in 'Luthier's Corner' started by Al Walker, Sep 14, 2017.
  1. Al Walker
    Al Walker Senior Member
    1,128
    1,136
    Sep 14, 2014
    On my PGK 58 Doublecut jr build I put the strap button on the back under the neck joint like the originals. Not realizing that the DC jr was similar to an SG in neck positioning. A little neck dive and a long reach. Is there some place I can get a medallion or something to cover the screw hole so I can relocate the strap button to the upper bout? Any serious suggestions would be welcome.
  2. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,237
    890
    Nov 29, 2012
    Ive seen fretboard dots used to cover small holes before
    Kris Ford, fumblefinger and jkes01 like this.
  3. TheHarleyMan2
    TheHarleyMan2 Senior Member
    578
    170
    Aug 26, 2010
    If you have a woodcraft place near you or any hobby shop, see if you can find a dowel about the same hole size in the type of wood the guitar is made out of.
    Who and kiko like this.
  4. Al Walker
    1,128
    1,136
    Sep 14, 2014
    If I was A Harley Man , I could put a Harley medalion on it. There are alot available. But alas, I'm not. So it would be a fake act.
    Not ready to start refinishng the back of the guitar, Just finished it. A marker dot may work.
    TheHarleyMan2 likes this.
  5. The Ballzz
    The Ballzz Senior Member
    1,448
    965
    Mar 28, 2013
    What color and type of finish? A pic of the area in question wouldn't hurt!
    Just Sayin'
    Gene
  6. kiko
    kiko Senior Member
    1,085
    1,225
    Jul 16, 2015
    I second the dowel suggestion, then paint it over with paint or marker.
  7. kakerlak
    kakerlak Senior Member
    1,534
    570
    Feb 5, 2014
    You could also just leave a strap button there. Doesn't look out of place unless you think too hard about there being two of them.
  8. LeftyF2003
    LeftyF2003 Senior Member
    7,347
    8,477
    Mar 2, 2010
    I fill those with Plastic Wood and use matching paint from a hobby shop. Depending on the finish you can also drop fill with colored lacquer.
  9. moreles
    moreles Senior Member
    2,711
    1,339
    Apr 16, 2011
    Yes on the wood filler. Easy. Also easy is epoxy colored to match the wood. Also easy is the dowel routine. The easiest, best way depends on the nature of the hole, and w/o pix, who knows.
  10. jkes01
    jkes01 Senior Member
    2,072
    952
    Jan 10, 2011
    fumblefinger likes this.
  11. Kris Ford
    Kris Ford Senior Member
    4,754
    4,035
    Dec 17, 2011
    Red Sharpie and a ninja like touch can be MAGIC on Gibson Cherry Red..
    kiko likes this.
  12. Al Walker
    1,128
    1,136
    Sep 14, 2014
    The guitar is my avatar. It's a recent build. No wood putty, dowling or color matching here. I'd rather have a hole then do that. A Tort dot could be cool. If I can figure out how to do that.
  13. chasenblues
    chasenblues Senior Member
    20,795
    30,776
    Apr 2, 2007
    Heavy duty hollow punch tool,
    Thick tort guitar pick.
  14. Al Walker
    1,128
    1,136
    Sep 14, 2014
    Yea, that would work.
  15. chasenblues
    20,795
    30,776
    Apr 2, 2007
    Or from a piece of the pickguard material if you have any left around.
  16. Leña_Costoso
    Leña_Costoso Senior Member
    733
    687
    Aug 28, 2017
    Dunno how it would work on your application but, I have an ES-333 that I added a Bigsby to. The stop bar bushings remained. Ended up goin' on "that great auction site" and finding some nice engraved buttons. WTF? yah just some solid nickel buttons. Epoxied to a dowel that fit into the bushings fairly snug and that was that. Removable later if need be, and the little engraved tops actually look pretty good.
    Again... dunno about your circumstance, but don't be afriad to think outside the box.
  17. Al Walker
    1,128
    1,136
    Sep 14, 2014
    I was looking out side the box. Buttons? How did you find them? I'm still looking. Moved the strap button and put in a stainless screw with an upholstery washer temporarily. Still looking.
  18. Bill Hicklin
    Bill Hicklin Senior Member
    7,519
    10,126
    Nov 3, 2014
    Band sticker.
    Daddy Dom likes this.
  19. Leña_Costoso
    733
    687
    Aug 28, 2017
    Searched nickel buttons....
  20. jkes01
    2,072
    952
    Jan 10, 2011
