[SOLVED] EMG Solderless Installation
Discussion in 'Pickups' started by Svea, Sep 21, 2011.
  1. Svea
    Svea Senior Member
    130
    17
    Sep 21, 2011
    This is something I DID wrong the first hook up.
    I am going to take some photos with a better camera and try to cover everything because maybe it's my guitar and not the stuff from EMG. I don't know :/
    Thanks for all the help though, hopefully better and more inclusive pictures will be a better guide to this :)
  2. Svea
    Svea Senior Member
    130
    17
    Sep 21, 2011
  3. WildeStarr
    WildeStarr V.I.P. Member
    3,040
    738
    Sep 7, 2007
    OK, it looks like I might have found it. Flip the green and black wires on the BUSS. You have the wires backwards on the 3-way. The black is coming off your hot, and the green is coming off the ground. I think it should be the other way around.
    :Ohno:
    refer to diagram 8:
    http://www.emgpickups.com/content/wiringdiagrams/HX_0230-0110D.pdf
    your 3-way switch is slightly different then the one shown in the diagram, and I think that is where your problem is.
  4. Svea
    Svea Senior Member
    130
    17
    Sep 21, 2011
    Yesssss, thank you! You ARE the EMG guy :D
    More output even! And I thought I was hearing the "lower output more organic" EMG X haha :D I still have alot of humming but maybe that's the amp! Will play around more tomorrow, thanks a bunch!
    One last question though, do I need to shield anything in the cavity with the solderless?
  5. WildeStarr
    3,040
    738
    Sep 7, 2007
    I don't think you need any other grounding, of course this assumes that everything else is wired correctly.
    "When installing any EMG-X Active Pickup, DO NOT connect the
    bridge ground wire. This wire is usually soldered to a volume or
    tone control casing and goes to the bridge. This wire grounds the
    strings and uses them and your body as a shield against hum and
    buzz. It also creates a shock hazard.
    EMG Pickups are shielded internally and DO NOT require string
    grounding. This greatly reduces the possibility of reverse
    polarity shock from microphones and other equipment"
    I RULE
    :thumb:
  6. Svea
    Svea Senior Member
    130
    17
    Sep 21, 2011
    I love it ;D BUT... I still get quieter guitar when touching output or pickups - maybe thats normal?
    edit: very minor!
  7. WildeStarr
    3,040
    738
    Sep 7, 2007
    Still sounds like it could be a problem somewhere. Maybe the amp, bad/cheap guitar cord, or a grounding problem in your home, overhead fluorescent lighting can cause this as well. If you have a multi-meter, check all the grounds on the guitar. Cheaply made guitar cables can be very noisy.
  8. captcoolaid
    captcoolaid Senior Member
    11,415
    3,906
    Nov 29, 2008
    Wild Starr What part of Cali are you from.
  9. WildeStarr
    3,040
    738
    Sep 7, 2007
  10. captcoolaid
    11,415
    3,906
    Nov 29, 2008
    I used to live in San Leandro.
  11. TimMerrick
    TimMerrick Junior Member
    1
    0
    May 2, 2012
    Hey Guys,
    Just wondering; what kind of cables would I need to solder to the toggle switch? I know it says Red, Green, Black, and White, but what kind of cables are they?
    Apologies if this is a ridiculous question, but I've had a look all over and couldn't really find anything?
    Plus I think I've annoyed the guys at EMG with all my questions..
    Cheers,
    Tim
    EDIT; Found what I needed.
