Sold - Please Delete
Discussion in 'Member Classifieds' started by Braciola, Oct 1, 2017.
  1. Braciola
    Braciola Senior Member
    577
    192
    Jul 19, 2011
    Okay guys, I'm posting three amps for sale, and need to sell at least two.
    - Here is the link to the Wizard MTL -
    http://www.mylespaul.com/threads/wizard-mtl-incredible-amplifier.398668/
    - Morris Perplex'd - Sold
    * Note
    Two amps left - the MetroPlex & Wizard.
    I only need to sell one more, so which ever sells first, the other will be off the market.
    All three are unquestionable the most impressive amps I've had the pleasure of owning, and never thought I'd be selling any of them........, however, we were just pummeled by hurricane Irma here in central FL, and it destroyed the roof on my home.
    I need to have my roof replaced ASAP, and I just found out that my insurance deductible is going to be 4.4 grand :doh:
    So no trade offers please!
    The Metro-Plex -
    This amplifier is only two months old and in Mint condition.
    I can't say enough how awesome this amp is.
    Serial #230
    Built date is "July 2017" written on the chassis
    Includes - Manual, Footswitch, Power Cable, Original Box with all the Original Packing.
    Sold
    Price - $2999 Shipped - Meticulously Packed - Fully Insured - FedEx
    Will split PayPal fee if that's your method of payment.
    Also accept postal orders / cashier's check
    From Metropoulos:
    This head is the current and latest version with improved switching circuit, less "whoomph" sound when changing modes, less "pop" when activating BOOST, added TRS and TS jacks for integrating the MP into programmable rigs (Bradshaw style). The TRS and TS jacks are added on the rear, next to the existing 5-pin footswitch socket. Players should use either, but not both at once. TRS is used to activate BOOST and MODE, while the TS jack is for LOOP. These 1/4" jacks will accommodate virtually any programmed rig, making the Metro-Plex compatible and able to drop in to most situations.
    Years of reverse engineering and R&D has all coalesced into George Metropoulos' modern day masterpiece, the Metro-Plex. Using his own '66 45/100, '67 Superlead, '69 Superbass and '70 Superlead as the templates, each important era of the famed 100 watt amp is now available in one amp. These are amps you can't create from schematics and data sheets. You can't even buy a replica this true in music stores. No production amp incorporates this level of detail or, in a word: obsession. You'll hear it immediately, you'll feel it deeply and your playing will respond sub-consciously. The final word in a Plexi replica: The Metropoulos Metro-Plex.
    The Metro-Plex is a 100/50 watt head featuring a PLEXI mode w/ master, a MODDED PLEXI mode w/ master, a JTM 45/100 mode, a BOOST mode, a built in variac and built in FX loop. The master volumes truly allow bedroom volume without degrading the tone, like no other before. With this amp you have squeaky clean to full-on scream at your fingertips (and toe tips via the foot pedal).
    The Metro-Plex is based on the tone of a 1968 Superlead played through a 1968 basketweave slant cab loaded with G12M speakers. NOTHING else sounds like this amp - until now. That tone is the heart of the new Metro-Plex amp, called PLEXI mode. Add in a circuit mod and you are in MODDED mode. Time for a solo, hit the footswitch for BOOST mode, a high voltage FET boost built into the front of the amp - and it has a separate master volume.
    Also included in this design is Metropoulos' reknowned Zero Loss FX loop, switchable for pedal level or rack level operation. Foot-switchable.
    FEATURES:
    - Each mode, PLEXI and MOD, has two possible voicings.
    - PLEXI mode is selectable between the JTM 45/100 voicing and '68 Superlead voicing.
    - MOD mode is selectable between the '68 Superlead voicing and Modded Superlead voicing.
    - All the following combinations of voicings are accessible via the footswitch:
    • - 45/100 and '68 Superlead
    • - 45/100 and Modded Superlead
    • - '68 Superlead and Modded Superlead
    - BOOST is a separate function, which can be applied to any mode. Think of it as a high voltage, clean boost in front of the amp. Just built in.
    - Variac mode simulates using a variac to operate a plexi at 90V AC.
    - Switchable for 50 or 100 watts output.
    Metlking and Duane_the_tub like this.
  2. Braciola
    577
    192
    Jul 19, 2011
    Bump!
  3. Duane_the_tub
    Duane_the_tub Senior Member
    763
    808
    May 31, 2015
    Sorry to hear about your house. Best of luck with the sale. I'd love to take that MP off your hands if I had the loot, always wanted one. Really great amp.
  4. Braciola
    577
    192
    Jul 19, 2011
    Thanks man, I really appreciate it.
    Duane_the_tub likes this.
  5. Braciola
    577
    192
    Jul 19, 2011
    bump!
