So, I'm thinking of removing my sideways vibrato...
Discussion in 'Vintage SG' started by Monstronaut, Apr 24, 2014.
  1. Monstronaut
    Monstronaut Senior Member
    181
    139
    Mar 19, 2011
    Because it makes my '63 SG/Les Paul a pain in the arse to play. It doesn't work as a vibrato, the string spacing is too close together, the strings hit the bridge at a shallow angle which I don't like and it kills sustain to my ear. I don't feel too bad about modding the guitar as it's already had a heel reset and a cavity crack but seriously, what were they thinking!!
    Anyone want to buy a sideways vibrola!!:fingersx:
  2. David Mccarroll
    David Mccarroll Senior Member
    1,775
    1,265
    Oct 12, 2011
    I'll pass on buying the vibrola (although to be honest with you I think if you chose to sell it you'd probably get enough to buy another guitar!), but having done the same thing it is the best thing you will EVER do for your SG!
    They really are one of the worst mistakes in electric guitar history!
    Cheers, and I say: go for it!
  3. mdubya
    mdubya Senior Member
    16,798
    26,104
    Jan 25, 2010
    2 people like this.
  4. Dolebludger
    Dolebludger Premium Member
    12,851
    11,161
    Feb 11, 2009
    Yeah, I've seen those vibratos go for over $500 on ebay. Maybe even more, a it is a long time since I looked. I agree about them sucking tone. I'm trying to keep mine as stock as possible though, but I can sure see somebody going the other way.
  5. Monstronaut
    181
    139
    Mar 19, 2011
    It's going this weekend.
    1 person likes this.
  6. Kevin James
    Kevin James V.I.P. Member
    1,511
    1,155
    Aug 23, 2010
    Sad IMO, but if that's really what you want....
    5 people like this.
  7. xroadie_jim
    xroadie_jim Senior Member
    537
    558
    Aug 29, 2011
    Don't do it!!!! Go buy a reissue, they are cheap.
    3 people like this.
  8. Monstronaut
    181
    139
    Mar 19, 2011
    I wouldn't remove it if this was a collectors grade guitar but it's not and never will be. As I said, it's a poor piece of engineering, it detracts from the tone and playability of the guitar. Im sure thats not the case with all of them, but this one, with its shallow neck angle which means that the strings are level with the bridge and therefore slip off when bending, deserves to be played. I do around 100 gigs a year and I plan on making this my no.1.
    2 people like this.
  9. mdubya
    16,798
    26,104
    Jan 25, 2010
    Have you seen Billy Gibbons'?
    8 people like this.
  10. 1959burst
    1959burst Senior Member
    2,695
    758
    Feb 2, 2008
    put a lightweight stop tail and enjoy
  11. Kevin James
    1,511
    1,155
    Aug 23, 2010
    I actually really like the tone my sidepull 61 has. It's definitely different than my lyre equiped 62 and 65 SG's. Not saying better or worse, just different. I like it. I also have no tuning problems with light use.
  12. strat1701
    strat1701 El Diablo Cazador De Hombres Premium Member
    5,644
    6,714
    Sep 27, 2011
    I have one as well on mine (a '62). My only beef with it is the arm when fully back overlaps the output jack hole so I have to have my arm up a tad to get a cord in the jack. While I wouldn't fully remove it, I may unscrew the top 'folding' part of the bar since I don't use it anyway. It's your guitar, if you say it's not collector quality (perhaps there are repair issues?) then go for it. Mine is all original save for a volume pot change, so mine won't be having any crazy mods!
    2 people like this.
  13. jeggz
    jeggz Senior Member
    3,499
    2,919
    Aug 19, 2008
    Well?
    Did ya take it off?
  14. Monstronaut
    181
    139
    Mar 19, 2011
    I did, pics to follow once I figure out the best way to cover the holes. Any ideas are welcome. The guitar now rings like crazy, more than any guitar I've ever owned, including my '56 junior which I had with me and did comparisons. I'm very happy with the results. I just need a decent case. Any recommendations?
  15. jeggz
    jeggz Senior Member
    3,499
    2,919
    Aug 19, 2008
    Nice!
    I'd just leave the holes,unless they large.
  16. used guitars
    used guitars Member
    82
    190
    Dec 2, 2012
    man, sorry i'm seeing this late. i could have helped you greatly, and frankly; i'm surprised someone else didn't.
  17. Monstronaut
    181
    139
    Mar 19, 2011
    Cryptic!
  18. ColdCobra
    ColdCobra Senior Member
    652
    291
    Jul 17, 2012
    LOL very cryptic
    I've never read a good thing about those sideways vibratos. So you probably did the wise thing.
    I too would just leave the holes, especially if its a player. Adds to the vintage mojo
  19. thewestwon
    thewestwon Junior Member
    10
    8
    Oct 30, 2012
    I'm really interested in this. If you have any setup tips, I'd love to know them. I've recently acquired one that needs some setup attention.
  20. Dolebludger
    12,851
    11,161
    Feb 11, 2009
    Monstoraut,
    If you removed the original side pull trem, did you install a TP? Probably, you did. And, if so, have you checked if the original trem would cover the new holes for the TP? If so, you may want to re-install the original trem if you want to sell someday, and if the collector's value for these guitars ever goes back up.
    Considering all this, you may want to just fill the trem holes with water-based wood filler, and smooth it out with a wet rag when it is almost dry. Then let the filler fiully dry. Then get some red cherry dye from a pro paint store, and dye the filler with a very small paint brush. Then apply a small amount of super glue over the filled and dyed trem holes with another very small paint brush. When dry, smooth lightly with 00000 steel wool, and wax over. If done correctly, the guitar should look fine on stage, but it will remain easy to find should you ever want to put the original trem back on. Keep the original trem, just in case.
