Sg w/Floyd frx
Discussion in 'Other Gibsons' started by DrewDM, Jan 18, 2019.
  1. DrewDM
    DrewDM Senior Member
    163
    59
    Dec 23, 2012
    Was wondering if anyone has tried them out. Thinking of putting one on mine to counter act the neck dive.
    Has anyone used one on an SG?
    And if so, did it balance the guitar a little better?
    Not much of a purist with this sg, it’s a 2016 HP model. It’s a great playing guitar but I’m sick of the auto tuners and the neck dive is annoying.
  2. Daniel.S
    Daniel.S Senior Member
    211
    264
    Dec 28, 2018
    Put standard Grover’s on it then.
    DrewDM likes this.
  3. Roxy13
    Roxy13 Senior Member
    4,808
    16,603
    Dec 27, 2017
    Tape a little baggy of fishing weights in the control cavity or use a strap with suede on the inside.
    My HP SG is a diver, too. No other SG I have or have had does it though.
    SGs need Maestros or Bigsbys :)
    DrewDM likes this.
  4. DrewDM
    163
    59
    Dec 23, 2012
    Thanks for the replies, gonna change out the tuners next week and see if that helps first I guess.
    Daniel.S likes this.
  5. Roxy13
    4,808
    16,603
    Dec 27, 2017
    Are you going with the Grovers? Please post back with whichever tuners you use and whether or not that helped the dive. I've been thinking the Grovers might not be much lighter than the G Force. And the headstock holes are the larger ones (10mm I think) so if you use a light weight tuner like a vintage type you would have to use the larger bushings, too.
    So far I am enjoying the G Force. It makes the guitar a really good one for doing Led Zeppelin songs with alternate tunings, and if you want to play slide this is the fastest guitar for raising and lowering the string height.
    DrewDM likes this.
  6. Daniel.S
    211
    264
    Dec 28, 2018
    Also, I’m not a fan of Derek Trucks, but you could add the maestro tailpiece for more weight.
    DrewDM likes this.
  7. warmachine
    warmachine Senior Member
    776
    221
    Jul 16, 2008
  8. Frogfur
    Frogfur Senior Member
    19,849
    35,408
    Jan 18, 2013
    That would be the worst reason in the world to do that. You'll enduo selling it.
  9. DrewDM
    163
    59
    Dec 23, 2012
    I was actually thinking either Grover’s or the hipshots. You are right though roxy, there are definitely pros to the e tune, my main reason for changing them would be to lighten up the headstock.
    Gonna look into the maestro tailpiece too, didn’t think of that, thanks.
    I had an sg standard in ‘96, wound up selling it in ‘97 to get an RR1. I don’t remember ever having the issue with the neck dive back then but who knows. From what I’m reading it’s an issue with most SG’s
  10. Roxy13
    4,808
    16,603
    Dec 27, 2017
    I don't think dive is an issue with most SGs. I have 4 right now and only the HP dives. I think the aluminum bridge and tailpiece are part of the equation as well. It's not just the G Force. I'm not sure though if your 2016 has those too or if that was a 2017 on thing.
    DrewDM likes this.
  11. 61LPSG
    61LPSG Senior Member
    1,714
    483
    Oct 31, 2007
    Is the SG body thick enough to house the Floyd?
  12. Have FUN
    Have FUN Senior Member
    1,684
    2,056
    Apr 27, 2011
    GForce is heavy, too much.
  13. DrewDM
    163
    59
    Dec 23, 2012
    The FRX attatches to the standard Gibson bridge posts.
    61LPSG likes this.
