SG Down!!! How screwed am I?
Discussion in 'Luthier's Corner' started by Gojo03, Dec 28, 2017.
  1. Gojo03
    Gojo03 Senior Member
    308
    213
    Sep 20, 2009
    We live in smallish rooms when I'm at work. We recently received some new furniture which made the smallish rooms feel smaller. That SG has been out here with me for the last 2 years without incident, never really seeing the inside of a case. I have used a guitar dock for a long while without any issues. The other day I turned my desk chair towards the desk and the back of the chair clipped the top of the headstock and popped it out of the dock. I knew exactly what happened as soon as I heard the snap!
    Once it's glued and set, I'll throw up some more pics. I also moved the dock away from my chair!
    Who likes this.
  2. 70Falcon
    70Falcon Junior Member
    4
    3
    Oct 31, 2017
    Sorry to hear that happened. Hopefully it will come out good as new when you're finished with the repair...
    Gojo03 likes this.
  3. Robbie
    Robbie Member
    35
    5
    Jun 6, 2009
    You need to make cauls for pressing the two pieces together and hold them flat while they are drying. Cauls also let you tighten clamps without denting the mahogany. First, practice assembling and clamping the neck and headstock until you can do it fluidly. Then use an acid brush to paint on Titebond III generously, assemble, putting sheets of wax paper between headstock and cauls, then tighten the cauls lightly. Now, remove the clamps and use a damp rag or sponge to remove excess glue from areas other than the joint, and reassemble with clean wax paper.The wax paper keeps the cauls from being glued to the headstock. Tighten just enough to hold firmly together, but not so much that you force all glue from the joint, aka "starving the joint." Let dry for 24 hours or more.
    As for cosmetics, the main thing is the front of the headstock. You can buy a new black veneer with inlays on eBay or elsewhere. Remove the old one before you fix the broken headstock using a hair dryer to loosen glue. Remove veneer glue with naptha, acetone and a card scraper, repair headstock, then glue on new veneer. Sand headstock face before gluing veneer if necessary. To drill holes in veneer for tuning keys, clamp caul that covers entire face of headstock and drill from rear of headstock into caul. This will prevent tearout of the veneer. For the truss rod cover, use an exacto knive. Start in the middle and slowly trim away veneer. Patience! If you try to rush it you will screw it up. Change blades often so it's always sharp.
    Check this out:
    Gojo03 likes this.
  4. Who
    15,442
    27,158
    Mar 15, 2012
    Why III? It doesn't need to be waterproof.
  5. tolm
    tolm Bigsby Junkie
    3,760
    2,380
    Jul 20, 2008
    I’m no tech but that looks like just about the best break you could have hoped for: full truss rod length of the neck is still intact and a nice wide surface area to glue the headstock back on. Plus the whole guitar is black so the touch up spray will be a cinch to blend. Get thee to a luthieree!
    Gojo03 and Who like this.
  6. The Ballzz
    The Ballzz Senior Member
    1,432
    959
    Mar 28, 2013
    You are absolutely correct on most counts, but contrary to popular belief, black can often be one of the harder colors to match!
    Best Of Luck To Gojo03!
    Gene
    tolm and Gojo03 like this.
  7. Robbie
    Robbie Member
    35
    5
    Jun 6, 2009
    Longer open time. Someone doing this for the first time needs a glue that dries slowly so they have time to get everything aligned and clean excess glue.
  8. Who
    15,442
    27,158
    Mar 15, 2012
    I was thinking Titebond original, to allow easy cleanup after the fact.
    fumblefinger likes this.
  9. Gojo03
    308
    213
    Sep 20, 2009
    I have already ordered titebomd original. I will probably never try to fix the cosmetics on it. Thanks for the tips on the repair, but I just want it to be playable again. Once Amazon ships the stuff it'll take a little over a week for it to get here, so I hope it ships soon!
  10. Who
    15,442
    27,158
    Mar 15, 2012
    Wow.... where do you live? You can't be more than 15 minutes from a bottle of Titebond in a hardware store.
    Good luck with the repair! I think it will be fine. Don't spend time taking pics while you're doing it, just get it fitted and clamped.
    dickjonesify likes this.
  11. fatdaddypreacher
    5,750
    3,768
    Feb 5, 2011
    i was kinda thinking the same thing. I thought that stuff was available everywhere.
  12. Gojo03
    308
    213
    Sep 20, 2009
    I live in SC but work on the other side of the world. Kind of a bad neighborhood, so I'm not going out to look for a hardware store, lol
  13. Gojo03
    308
    213
    Sep 20, 2009
    I finally received my package yesterday. So, here is where I'm at right now! Waiting game now...
    PermissionToLand and Who like this.
  14. Who
    15,442
    27,158
    Mar 15, 2012
    I know it gets made fun of here, in other threads... but this might be a good guitar to add a String Butler to.
    Get a black one.....you'll never notice the repair!
    kmasters68 likes this.
  15. tolm
    tolm Bigsby Junkie
    3,760
    2,380
    Jul 20, 2008
    I’ve never heard of those but that’s a great idea! Wondering if one is worth trying on my 335 to get a straighter “through the nut” angle and help with Bigsby stability? Not that I have a huge issue at the moment but I can’t see how it would hurt ...
  16. Who
    15,442
    27,158
    Mar 15, 2012
    NewDayHappy likes this.
  17. Gojo03
    308
    213
    Sep 20, 2009
    Current situation w/10-52s... Seems pretty stable so far!
  18. bhmcintosh
    bhmcintosh Les Pauls, Telecasters, and 12strings Premium Member
    389
    232
    Apr 20, 2009
    Mask off the fingerboard and the top half of the headstock, sand the breaklines smooth, and feather in some rattlecan black lacquer and you'll be good to go, at least for a rough-and-ready around the office beater guitar.
    Remember, there are two kinds of SG owners - those with a broken headstock, and those who haven't dropped theirs yet. :D
    tolm, dickjonesify and Gojo03 like this.
  19. Who
    15,442
    27,158
    Mar 15, 2012
    Looks like you're back in the SG-playin' business!
    Gojo03 likes this.
  20. tolm
    tolm Bigsby Junkie
    3,760
    2,380
    Jul 20, 2008
    Looking good! Well, looking like a solid repair, I mean!!
