SG Down!!! How screwed am I?
Discussion in 'Luthier's Corner' started by Gojo03, Dec 28, 2017.
  1. Gojo03
    Gojo03 Senior Member
    317
    228
    Sep 20, 2009
    So, my 2014 SG Standard took a spill yesterday and broke the headstock clean off. I'm trying to decide what direction I'm going to take with it now. I work away from home and have the guitar with me. That means I don't really have anyone close that I can get it to quickly. I can bring it home with me, but that'll be around March. So, here's the options I have come up with so far....
    I try to glue it up and see if it holds.
    Bring it home with me and seek pro help.
    Order another body and scrap it.
    1: I would have to order some glue and try to figure out some kind of fixture to set it in place to do the repair myself. I don't have access to any woodworking gear, so any other bracing wouldn't happen. It is kind of a beater, so I don't care what it ends up looking like, as long as it is solid.
    2: It isn't worth a ton, so the repair cost would have to be low for that option to be considered. Time frame isn't an issue since I can leave it as long as necessary.
    3: Replacing the body wouldn't be difficult, I would just have to drop the $$$ for it and wait for it to be shipped out here and hope it doesn't break in route.
    Any other ideas or options I haven't thought of?
    NewDayHappy and Who like this.
  2. Ripthorn
    Ripthorn Senior Member
    1,556
    1,194
    Mar 7, 2014
    This is a fairly classic break, and it can be repaired fairly easily of you are handy. I've not done it before, so I will let others who have chime in on best practices.
    Who likes this.
  3. Norton
    Norton Senior Member
    495
    426
    Dec 12, 2013
    Piece of cake repair. Glue/clamps/24hrs and you’ll be good as new
    Gojo03, Who and fumblefinger like this.
  4. lunchbox
    lunchbox Senior Member
    7,050
    9,735
    May 29, 2011
    Ugh. I'd make it a shattered guitar wall hanger and buy a new one if that happened to mine. There was a really cool one in the background of the movie Vanilla Sky, but I can't find a photo. It was kinda like this:
    NewDayHappy and rockstar232007 like this.
  5. kiko
    kiko Senior Member
    1,134
    1,281
    Jul 16, 2015
    Do it yourself, wood glue, clamps. It's a lot easier than it looks.
    Gojo03, Who and Duane_the_tub like this.
  6. Gojo03
    317
    228
    Sep 20, 2009
    Titebond hide glue or the original?
  7. Skyjerk
    6,204
    7,425
    Feb 9, 2014
    Assuming you can fit the pieces together seamlessly and clamp it without them moving, I'd use UF glue.
    Its my new favorite for joints that dont ever need to come apart, and of course the goal here is a repair that will never come apart.
    I reiterate though, make sure you can fit the pieces together perfectly. Remove any little splinters that might be hanging off and preventing a perfect mating of the two faces. Test-clamp it and make sure it wont slide apart when you glue it. Glue can be a lube that, when under clamping pressure, can make the pieces slide.
    UF dries hard and brittle as glass so is great for the same reasons as hide glue, but has a real long open time. It'll never release, though, so if it moves when you clamp it you'd have an issue.
  8. kmasters68
    kmasters68 Senior Member
    1,317
    346
    Aug 6, 2015
    Easy fix. Cosmetics are your only real issue.
    bhmcintosh, Who and fumblefinger like this.
  9. Freddy G
    Freddy G V.I.P. Member
    11,830
    25,330
    Mar 18, 2007
    That's right. When I quote for that kind of fix it's relatively cheap for just the fix. If you want an invisible repair? That's where all the work is.
    kasu, wildhawk1, Gojo03 and 7 others like this.
  10. The Refugee
    The Refugee Senior Member
    7,577
    5,099
    Aug 6, 2010
    Titebond is about $4 at a hardware store. Buy a few clamps and you should be able to have this fixed up for under $30, easy.
    bhmcintosh and Who like this.
  11. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,318
    954
    Nov 29, 2012
    Nevermind the work, thats where your experience comes in.
    To be honest for a first attempt at a headstock repair stick with titebond 1. It is reverseable if you mess it up with minimal issuses. Urea formaldehyde glue is a fantastic product but requires absolute precision cause it ain't coming apart again.
    Titebond has been used the world over for this exact repair with great results.
    If you are looking for a better looking repair then you should look at replacing the fiber board overlay on the front of the headstock. There are several sources for new ones that look good. The it is a matter of touching up the nitro on the back of the neck. Black is a b to match but with paitence its something that wont be noticed unless up close.
  12. fumblefinger
    fumblefinger Senior Member
    1,220
    496
    May 10, 2012
    If you can, I'd make a bit of a jig so that the headstock can't creep out under clamping.
  13. Paully
    Paully Senior Member
    190
    165
    Nov 22, 2013
    Skaaaa-Rood !
    dcomiskey likes this.
  14. warprider
    warprider Senior Member
    312
    274
    Jan 31, 2011
    Look at all that surface area. Consider yourself lucky.
    kasu, Thumpalumpacus, Gojo03 and 2 others like this.
  15. Gojo03
    317
    228
    Sep 20, 2009
    I ordered some titebond and some clamps on Amazon today. Probably be here next week sometime... I'll let you guys know the how it goes! Thanks for the tips
  16. Al Walker
    Al Walker Senior Member
    1,230
    1,275
    Sep 14, 2014
    Clean break. Should a piece of cake. Just get it lined up straight and it will be good. Kirk Hammet says it will sound better, too!
    Gojo03 and fumblefinger like this.
  17. fatdaddypreacher
    5,892
    3,887
    Feb 5, 2011
    dry fit the piece back on before glueing, insuring there aren't any stray fibers inhibiting a clean, tight fit. If they are small and can't be coaxed back into place with confidence, simply remove them. This also gives you an opportunity to figure out how you are going to clamp it. bear in mind that when you clamp it with glue, the pieces may want to slide a bit. be sure that they are in the correct alignment when the glue tacks up. remove as much of the excess glue with cloth dampened with water. may help to make two clamping cauls (flat smooth boards or plywood covered with vinyl tape to ensure glue doesn't stick to them) to sandwich the headstock in. this ain't rocket science, so don't over think it. snug clamp seamless joint is what you are going for. keep us posted.
    cain61, Gojo03 and fumblefinger like this.
  18. HEADKNOCKER
    HEADKNOCKER Banned
    1,123
    630
    Apr 30, 2014
    I wanna see this after the repair..
    Should come out fairly nice, Lots of surface area, clean break..
  19. Who
    17,065
    31,690
    Mar 15, 2012
    You will be fine. Since you're using Titebond, you don't need to be super careful about managing squeeze-out. You can clean it up later.
    While you wait for the supplies, here is my first-timer thread for doing this:
    http://www.mylespaul.com/threads/epi-custom-headstock-neck-break-repair-another-thread.278972/
    If I was doing it again, I'd take @fumblefinger's advice, and use a jig. Or a heavy table near a wall.
    Here's my second one:
    http://www.mylespaul.com/threads/re...tock-guitar-30-epi-sg-craigslist-find.371252/
    That one didn't have all the surface are you are "blessed" with.
    By the time I did my third one, I didn't even make a thread. Just some glue, two clamps, it was playable 24 hours later.
    You can do it!
  20. 70Falcon
    70Falcon Junior Member
    4
    3
    Oct 31, 2017
    Just curious, how did this happen?
