Setting Intonation
Discussion in 'Epiphone Les Pauls' started by Paully, Feb 21, 2018.
  1. Paully
    Paully Senior Member
    190
    164
    Nov 22, 2013
    I've got an €pi Les Paul Special 1 p90's, with the wrap over bridge.
    I have found an Allen wrench that almost fits the set screw on the bridge/saddle. The one that came with the guitar is too small. I got the bridge closer to the nut, but she still rings sharp.
    Advice?
    Tks,
    Paully
  2. Stillhouse
    Stillhouse Senior Member
    1,031
    1,850
    Nov 24, 2012
    If it's sharp you need to move the bridge or saddle away from the nut. If flat move towards the nut.
  3. Paully
    190
    164
    Nov 22, 2013
    Ahh that explains it.
    Tks.
    Paully
    JohnnyN likes this.
  4. Ambrola
    Ambrola Senior Member
    1,248
    1,052
    Nov 6, 2011
    What rings sharp? All of the strings? I have never heard of that. One string normally goes sharp or flat. You can set it at the 12th fret. Play it open and then again at the 12th. The 12th fret is half way from bridge and nut. This will help you.
    DagerOne and WaywerdSon like this.
  5. Brians Evil Twin
    Brians Evil Twin Poophoria Sōtō Zen V.I.P. Member
    10,556
    24,867
    Apr 24, 2012
    12th fret, not 13th.
    Thumpalumpacus likes this.
  6. Ambrola
    1,248
    1,052
    Nov 6, 2011
    Opps, my mistake. I edited it to make it correct. But that is a good video by one of the best guitarist ever.
  7. GRASS
    GRASS Senior Member
    332
    121
    Jan 3, 2011
    OOPS another mistake.
  8. WaywerdSon
    WaywerdSon Senior Member
    4,525
    7,977
    May 1, 2013
    Of course a strobe is the best way to set intonation, but the harmonic at the 12th trick works well if you remember not to fret the note too hard. Play the 12th fret harmonic and then play the same string fretted at the 12th. You can usually get pretty close by ear. You will end up setting it slightly sharp if you squeeze too much. A fretted instrument will never have 100% perfect intonation anyway, so as long as its reasonably close you will sound just fine
    truckermde and stiff fingers like this.
  9. irocdave12
    irocdave12 Senior Member
    2,412
    2,922
    Jun 22, 2011
    Jeebus now we know why Joe never starts a show on time.
  10. ehb
    ehb Chief Discombobulator Premium Member
    25,168
    115,961
    Feb 20, 2013
    "Run away from sharp objects."
    Think it out.
    Jymbopalyse, Thumpalumpacus and LP121 like this.
  11. NorlinBlackBeauty
    NorlinBlackBeauty Senior Member
    6,514
    19,069
    Oct 29, 2017
    I've never seen that ... Joe rocks! :)
  12. Ambrola
    1,248
    1,052
    Nov 6, 2011
    :jam:Walsh has always rocked. He be my hero.:acoustic:
  13. NorlinBlackBeauty
    6,514
    19,069
    Oct 29, 2017
    Agreed. That clip was not very useful for novices, but gets all the important points across only the way Joe could.
  14. LP121
    LP121 Senior Member
    4,246
    8,608
    Jan 23, 2014
    See, things like this may sound silly, but they really help a simpleton like me. :laugh2:
  15. Paully
    190
    164
    Nov 22, 2013
    I gots me intonation set. :acoustic:
  16. rednefceleb
    rednefceleb Senior Member
    615
    362
    Nov 16, 2017
    :) :) J. Page played a Danelctro DC-59er 6 string <kind of an oldie> and fitted it with a Schaller 6 string adjustable bridge. It was a solid fit that solved his intonation problems well enough to render his guitar fully adjustable. I had one of those Schaller adjustables on an old L.P. Special & it worked like a charm! They don't fit on <every application perfectly> but took care of my woes. Good old Schaller! Quality stuff. :) :)
  17. Jymbopalyse
    Jymbopalyse Senior Member
    2,352
    4,622
    Oct 3, 2016
    A quick thought about your allen wrench.
    If it 'almost' fits. You probably need a metric wrench instead of a standard one. (or is it the other way around ?)
  18. ehb
    25,168
    115,961
    Feb 20, 2013
    Metric.
    Harbor Freight has dual sets dirt cheap...
  19. Paully
    190
    164
    Nov 22, 2013
    I've got more "Allen" wrenches than I know what to do with.
    Imperial and Metric both.
    Thanks for advice.
  20. Ambrola
    1,248
    1,052
    Nov 6, 2011
    Metrics sucks! Why can't all tools be in inches?
