Seth Lover
Discussion in 'The Custom Shop' started by Thunderheart, Mar 5, 2018.
  1. Thunderheart
    Thunderheart Member
    69
    26
    Dec 10, 2014
    Hi folks,
    I need some help with pup replacements.
    I have a 2012 LP Standard and want to replace the burstbucker pros and install a set of Seth Lovers. What else should be replaced? Pots, etc?
    Does anyone sell complete sets of the parts needed?
    First time for this so any help is appreciated.
    Thanks to all.
  2. kfowler8
    kfowler8 Senior Member
    4,952
    4,772
    Mar 1, 2011
    I use guitarpartsresource.com. Prices are good and shipping and reasonable. Forum member Jonesy makes top notch premade wire caps and pots.
    Honestly. Since it's an American LP, I'd try the pickups first. You're not going to get that much difference out of replacing the rest of the electronics.
    The Seths are great BTW. I just installed a set this weekend.
    Thunderheart likes this.
  3. SlyStrat
    SlyStrat Senior Member
    1,795
    893
    Jan 24, 2009
    My favorite pickups.
  4. Thunderheart
    Thunderheart Member
    69
    26
    Dec 10, 2014
    I guess a concern is that I have the push pull volume and tone controls?
  5. kfowler8
    4,952
    4,772
    Mar 1, 2011
    Yeah you won’t be able to split coils with the Seths. They only have two leads. So you need to ask how much you actually use that feature.
    FWIW, I also have a set of Whole Lotta Humberkers and you can split with those.
  6. JeffH66
    JeffH66 Pelham Blue Addict Premium Member
    324
    440
    Oct 31, 2010
    You should check to see if you have 300k pots or 500k. Maybe all USA LP's have 500's and I just don't know it. I always like to put in pots and caps of my choosing when I upgrade pickups, unless I know what's already in there is top notch. For $50-$75 it makes me feel better. There are several places that make great pre wired kits, one already mentioned here. Tone Man is another.
    The Seth Lovers are fantastic pickups, one of my absolute favorites. If you think you will use coil splitting, you can order Seth's with 4 conductor wiring. It's called a Shop Floor Custom order and you can place it through any SD dealer. There is no upcharge to order them that way, but it takes a couple of weeks. If you need the name of a dealer, let me know.
    Thunderheart and kfowler8 like this.
  7. moreles
    moreles Senior Member
    2,657
    1,276
    Apr 16, 2011
    Splittable Seths sounds like a fantastic setup! I think Gibson is now consistently using 500K pots, which they sure as heck should be doing, but you probably should check to make sure before you do the wiring, which should be easy. You could fiddle with tone cap values if you want, but I've done loads of fooling around with caps and usually find my way back to .022s.
  8. Thunderheart
    Thunderheart Member
    69
    26
    Dec 10, 2014
    I'll use a set of Seth Lovers and add new pots ( for piece of mind).
    Thanks to everyone for the all great advice.
    I appreciate it.
    kfowler8 likes this.
  9. kfowler8
    4,952
    4,772
    Mar 1, 2011
    One that I would be interested in trying is the no load pot. They don't make a reverse (left handed) version so I've never tried them but it's an interesting idea. Same mod as wiring the pickups directly to the output jack.
  10. kfowler8
    4,952
    4,772
    Mar 1, 2011
    If you've never soldered pots before, let me give you some advice. Take some ~300 grit sandpaper and scuff the back of the pot where you want to solder. I usually just do this where you solder the one lug to the back. You don't need to scuff it much. Just enough to take the shine off it. It'll make your solder flow so much easier. Took me years to figure this out.
  11. scott 351 wins
    scott 351 wins Senior Member
    1,092
    1,427
    Jan 31, 2009
    You might want to consider doing a 50's wiring upgrade if you're planning on adding new pots.
  12. Thunderheart
    Thunderheart Member
    69
    26
    Dec 10, 2014
    I'm a lefty and play a left hand LP. Do I need to specify that when buying pups and pots????
  13. kfowler8
    4,952
    4,772
    Mar 1, 2011
    PUs, no. Pots, usually yes but it depends on what you want. If you're using linear pots, it doesn't matter. If you use audio/log pots (what mostly used in guitars) then you generally want to lefty pots so the taper is in the right spot. It's really all personal preference though.
    I've used both and there is a noticeable difference for when the sounds changes.
  14. BrianB
    BrianB Senior Member
    3,466
    5,240
    Jun 20, 2012
    They make them....
    https://www.seymourduncan.com/pickup/seth-lover-bridge
    Just select 4 conductor in Buy Options -> Additional Options.
    For some reason, if you buy the set, the option isn't there, but if you order them individually (neck and bridge), you can get the option for 4 wire.
  15. ARandall
    ARandall Senior Member
    11,721
    7,051
    Apr 16, 2012
    I have a lefty and just wire up normally.....using the same patterns as a righty. The pots roll down the right way and 10 is still full volume.
    To be honest, I'd typically want the harness upgraded first. Its always good to hear your current pickups and the guitar 'unfettered'. Then maybe see if there are any tonal issues like overly bright/dull. It might affect either your pickup choice or make you think about component value tweaks for tone sculpting.
    JohnnyN likes this.
  16. kfowler8
    4,952
    4,772
    Mar 1, 2011
    10 and zero aren't the problem. It's where the taper happens. If you use a right-handed log pot and wire it for a lefty, there's a much quicker roll off. Some people like it, some don't. If you don't ever use the middle settings on your tone/vol, it won't make a difference.
  17. JohnnyN
    JohnnyN Old school Premium Member
    4,325
    11,941
    May 15, 2010
  18. ARandall
    11,721
    7,051
    Apr 16, 2012
    What I was saying was that if I'd wired it up like a RH pot, and used the same knobs so that the progression is from 10 through 9,8 7 etc past the pointer, then the taper will be the same too
  19. kfowler8
    4,952
    4,772
    Mar 1, 2011
    I think I understand what you're saying. But then the way you turn the pots will be reversed. I tried this way with a set of EMGs since the quick release plugs won't let you reverse the pots. I couldn't get past it since it was different than all my others. I ended up using traditional pots.
    I suppose though it's all what you're used to.
