Sealer question
Discussion in 'Luthier's Corner' started by Theotherone, Dec 8, 2017.
  1. Theotherone
    Theotherone Junior Member
    20
    9
    Dec 5, 2017
    Was curious everyone's opinion on behlen vinyl sealer vs behlen "jet spray" lacquer sanding sealer? I will be using behlen stringed instrument lacquer for my top coat. I just noticed I purchased the sanding sealer instead of the vinyl sealer by mistake. I'm pretty sure either is compatible with my top coat but I want to double check. Should I order a can of the vinyl sealer and keep the sanding sealer on standby for another project or will the sanding sealer serve the purpose?
  2. Freddy G
    Freddy G V.I.P. Member
    11,308
    23,549
    Mar 18, 2007
    I don't like vinyl sealer. I would use the sanding sealer but don't spray too many coats of it. 2 coats is good, 3 max.
  3. Ripthorn
    Ripthorn Senior Member
    1,508
    1,164
    Mar 7, 2014
    I just did an instrument with the vinyl sealer and I didn't like the way it built or sanded. It worked fine, but I prefer a good lacquer sanding sealer. They tend to sand better dry, which is important to me.
  4. ARandall
    ARandall Senior Member
    11,999
    7,462
    Apr 16, 2012
    I have just been using the Behlen Qualalaq sealer. Seems to go on really well, and build quickly even with crappy almost useless grainfill underneath.
  5. Leña_Costoso
    Leña_Costoso Senior Member
    733
    691
    Aug 28, 2017
    I got a really light and grainy swamp ash tele body once. Finish blue metal flake. Sealer and filler .... I used CA.
    Other than the stink it went on , sanded , filled and sealed just fine. The blue flake was lacquer with clearcoat. Zero issues.
