SD Skinnerburst pickups into 17' Les Paul Std
Discussion in 'Pickups' started by krb813, Jul 7, 2017.
  1. krb813
    krb813 Member
    35
    21
    Mar 23, 2014
    Do any of you foresee any problems installing the SD Bonamassa Skinnerburst pickups in my 2017 Les Paul Standard? I really don't like the Burstbucker Pro's that came in it. Any insight will be appreciated.
    Thanks
  2. BlueCajun
    BlueCajun Senior Member
    925
    431
    Jul 26, 2012
    Depends on the electronics in your LP. If it has regular pots, caps, and wiring soldered together, you should have no problems. If it's a PCB with the pickups attached via Molex connectors, it could be difficult.
  3. krb813
    krb813 Member
    35
    21
    Mar 23, 2014
    Thanks for the info BlueCajun. I will take a look inside and see.
    BlueCajun likes this.
