Scero Laulita '59 #1 BUILD
Discussion in 'Luthier's Corner' started by Scero Guitars, Aug 27, 2016.
  1. emoney
    emoney Senior Member
    7,024
    3,191
    Jan 31, 2010
    Looking good! Keep those updates coming.
  2. Scero Guitars
    Scero Guitars Senior Member
    222
    148
    Mar 13, 2011
    Thanks Lou!
    I got the FB my luthier, he's had it in a stash for about 30+yrs.
  3. Scero Guitars
    222
    148
    Mar 13, 2011
  4. Scero Guitars
    222
    148
    Mar 13, 2011
    After some final sanding up to 320 grit, was onto the first coats of lacquer, to use as a sealer coat. Ive never been one to use vinyl sealer first, but I know it's common practice.
    [​IMG][/url]IMG_0067 by Louis Scutti, on Flickr[/IMG]
    [​IMG][/url]IMG_0068 by Louis Scutti, on Flickr[/IMG]
    [​IMG][/url]IMG_0066 by Louis Scutti, on Flickr[/IMG]
    Next was yellow lacquer color coat.
    Onto the burst. Customer wanted me to match a Gustavasson he'd seen an loved.
    [​IMG][/url]IMG_0069 by Louis Scutti, on Flickr[/IMG]
    Some darker amber coats started to pull and tie it all together nicely
    [​IMG][/url]IMG_0070 by Louis Scutti, on Flickr[/IMG]
    [​IMG][/url]IMG_0071 by Louis Scutti, on Flickr[/IMG]
    [​IMG][/url]IMG_0073 by Louis Scutti, on Flickr[/IMG]
    [​IMG][/url]IMG_0074 by Louis Scutti, on Flickr[/IMG]
    The New dry transfer decals from Imagetransfers.com came out killer. Was able to perfectly match VERY popular Gold ;)
    [​IMG][/url]IMG_0079 by Louis Scutti, on Flickr[/IMG]
  5. Scero Guitars
    222
    148
    Mar 13, 2011
    That's about where I'm at as of today. Got the last coat of lacquer on about a week ago, and will give it another 1-2 weeks of drying. Luckily Colorado has extreme low humidity, and we still have plenty of dry heat, so drying tends to go QUICK.
  6. ARandall
    ARandall Senior Member
    12,008
    7,473
    Apr 16, 2012
    Very nice.
    That brownish colour of the burst - was that just the amber over the initial red outer or was there any UV involved.
  7. Scero Guitars
    222
    148
    Mar 13, 2011
    Thanks! The brownish color you see, was a mostly brown lacquer sprayed as the burst, that had tiny bit of red mixed in. Probably 85/15. Then amber over everything.
  8. SG Lou
    SG Lou Senior Member
    2,677
    1,820
    Apr 3, 2009
    Kick ass finish !
    BTW: Love the re-purposed engine stand !
  9. D'tar
    D'tar Senior Member
    356
    162
    Sep 23, 2014
  10. tmmakino
    tmmakino Junior Member
    11
    0
    Jul 5, 2016
    Is that difference in neck/body color just from the wood alone? Is there color on there or just the clear sealer coat?
    Great looking build!
  11. KnightroExpress
    KnightroExpress Senior Member
    1,393
    1,415
    Sep 5, 2013
    +1 on the engine stand, great idea!
  12. kakerlak
    kakerlak Senior Member
    1,639
    696
    Feb 5, 2014
    What sort of tuners are you using? Looks like a lot of wood between the tuner holes and edge of the headstock on the treble side.
  13. Open_Book
    Open_Book Senior Member
    1,180
    683
    May 26, 2014
    That is a great looking finish.
  14. Scero Guitars
    222
    148
    Mar 13, 2011
    Thanks man! As far as the engine stand, got the idea from my buddy Doug Kauer. Works amazingly. Having a level surface to spray on has helped finishes lay down Much smoother.
  15. Scero Guitars
    222
    148
    Mar 13, 2011
    Yah the color contrast you see is just the two dif woods. Old growth sinker Honduran neck, and the Spanish body. Those are just lacquer sealer coats. I considered leaving the contrast, which would've look cool. But decided a consistent color between the two kept with the "inspired" look better.
  16. Scero Guitars
    222
    148
    Mar 13, 2011
    I'm using Kluson Supremes, vintage style. With the way I place my tuner holes, there is less angle after the nut to the tuner, so yes, the buttons tend to be a tad closer to the headstock. Luckily though, doesn't make grabbing the tuning peg any more difficult, just a slightly dif look. Which I'm ok with.
  17. Scero Guitars
    222
    148
    Mar 13, 2011
    Appreciate that! Thank you
  18. Scero Guitars
    222
    148
    Mar 13, 2011
    Well do to a finish error, and the customer not being completely happy with the first burst, i went ahead and redid. And luckily, second one was even better. Just had me match a pic of a burst he liked, and I feel like it was pretty close!
    [​IMG][/url]Untitled by Louis Scutti, on Flickr[/IMG]
    This was halfway thru assembly, and all buffed out -
  19. Scero Guitars
    222
    148
    Mar 13, 2011
    Would LOVE to hear your guys' thoughts!
  20. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,260
    913
    Nov 29, 2012
    I think its beautiful, especially with the double whites.
