Saul Goode SAF series
Discussion in 'Luthier's Corner' started by mux164, Oct 17, 2016.
  1. mux164
    mux164 Senior Member
    2,629
    1,888
    Sep 1, 2012
    IMG_7827.JPG IMG_7828.JPG IMG_7829.JPG Waiting to get some new sanding pads, I fixed the little chunk out of the neck pocket on the karri topped one.
    I also got the rope and the back chambered in the pine build, it's getting a karri neck and blackbutt fretboard. Also got the bolt soundholes cleaned as best as I could. Going with a bucker in the bridge and a hot rail type pickup in the neck, both will more than likely have trapeze tail pieces and definitely have roller bridges
  2. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7844.JPG IMG_7845.JPG IMG_1008.JPG All fine sanded, just need to make a neck for the pine one and glue that in
    The pup ring is hitting the bridge so I may have to direct mount it, or get a metal surround and sand that down
    Could not wait for the new sander pads so I hand sanded the neck and two bodies. All nice and smooth now
    The karri top build will be clear coated tomorrow, and I'll work in the neck during the week for the pine build
  3. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7851.JPG IMG_7850.JPG Started applying clear coat
  4. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7863.JPG IMG_7865.JPG IMG_7866.JPG IMG_7867.JPG Still clear coating, got the side dots and the nut glued in the new neck, now I need to fret and carve the neck. And give it another good sanding
    I've also got a Tele to put together that my mum's neighbour gave me todo, I did some repair work and and after seeing the hollow body ibanez makes me want a true hollowbody guitar. I will most likely get a pit bull 175 kit
  5. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_1013.JPG Onto carving the neck tomorrow sanding the body and stripping a cheap tele
  6. mux164
    2,629
    1,888
    Sep 1, 2012
    Neck carved and glued in. I also fine sanded everything.
    Will start clear coating tomorrow and put the final clear on the karri top guitar IMG_7870.JPG IMG_7871.JPG IMG_7872.JPG IMG_7873.JPG
  7. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7876.JPG And it begins again
  8. mux164
    2,629
    1,888
    Sep 1, 2012
    Just need to figure out why the volume knobs isn't working, it just stays on the maximum setting for both volumes.
  9. mux164
    2,629
    1,888
    Sep 1, 2012
    okay I figured out why the volume knobs weren't working.
    Whoever made the wiring harness decided to wire the switch wire to the first lug instead of the second.
    All sorted, now I'll be taking it to the local music shop to see if they like it
  10. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7877.JPG Well this fella has a new owner
  11. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7974.JPG IMG_7972.JPG IMG_7973.JPG Both of the latest two have new owners, the owner of the karri top guitar has asked me to make two thinline teles so I'll be working on them next.
    As well as refinishing another Tele for my mums neighbor which is nearly done I have also finally started clearcoating the jem style guitar I started when I did the green Tele.
    So after this post I will be going a 30 inch saf bass so that should be interesting
    Also I put some filtertron in the blue saf, it's intentionally looking like that I swear
  12. jkes01
    jkes01 Senior Member
    2,121
    995
    Jan 10, 2011
    Lookin good man. Like that purple :)
  13. mux164
    2,629
    1,888
    Sep 1, 2012
    Thanks
    That's rustoleum grape purple it's a primer/top coat, I had issues with it before I got it, first one had the nozzle break off when I took the lid off, went and bought another can then it had a clod in it that I couldn't get out even with turps, and then I poked around with a drill bit and I must have poked a hole in the valve so it went everywhere lol.
    I would have clear coated it but my weed killer spray pack leaked and made te back a nasty yellow
    Can't wait to get on to making the bass but that'll wait till I'm done with the teles, the purple one was just stuff to do inbetween coats for one of the teles
  14. jkes01
    2,121
    995
    Jan 10, 2011
    Oh no... :wow:
    Small scale bass is on my long wish list of things I want to build. List seems to just keep getting longer.
  15. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_8116.JPG IMG_8113.JPG IMG_8140.JPG IMG_8141.JPG IMG_8208.JPG IMG_8209.JPG IMG_8103.JPG IMG_8104.JPG IMG_8179.JPG IMG_8232.JPG IMG_8233.JPG Been busy on these two, a bass and another saf with a strat neck
    I've had issues with the charcoal, but since changed paints and it's turning out better each coat. Of course it's on one that I am making for someone else
    And the bass was a brain fart, I measured about 20 times before routing for the j pickup and then it turns out I was out by nearly 4 inches lol oh well it's a prototype and it's for me. Hopefully the hammered charcoal will hide the boo boo
    paulmarr likes this.
  16. mux164
    2,629
    1,888
    Sep 1, 2012
    What's the go with the sideways photos? I shouldn't have to go I and edit each photo, especially since they were taken the right way around
  17. mux164
    2,629
    1,888
    Sep 1, 2012
    Proto bass is coming along and so is the other saf, I have a pine blank ready to go.
    dickjonesify likes this.
  18. mux164
    2,629
    1,888
    Sep 1, 2012
    dickjonesify and jkes01 like this.
  19. mux164
    2,629
    1,888
    Sep 1, 2012
    A7B72EC8-6784-49F8-A99C-A5B1B5291C1E.jpeg DA83B16C-1BF1-44CC-AB5F-309DC9C6F36A.jpeg Started a new SAF this weekend, the top and back is teak that I found at bunnings, it’s just a multi laminate shelving. Luckily it’s wide enough and long enough for this design.
    The Centre section is good old pine that will have the bass and treble sides chambered and behind the bride also. It will have a roller bridge and a trapeze tail piece.
    The top and the back will be heavily chambered except for around ge neck join and where the bridge sits, I have some shots where it was rough rout d and I also had to use acetone to get rid of the oil that was in both sides. It will have a 1 and 5/8 round over and most likely no access cavities B9151F96-58BD-46B9-B2C8-0CC181921512.jpeg 35A11197-E49D-476C-AC43-4D1EDBCB7D37.jpeg E40DED15-162F-4A9E-910A-2676936554AC.jpeg
  20. mux164
    2,629
    1,888
    Sep 1, 2012
    Few things left to do, drill for the jack, thin out the back and glue it on, glue the neck in, fix the f holes up.... DEDD5C7A-7FDB-486E-AC52-8533110E3291.jpeg but I’m happy with the progress since I started on Sunday and work full time
