sanding block
Discussion in 'Luthier's Corner' started by Weldaar, Mar 20, 2017.
  1. Weldaar
    Weldaar V.I.P. Member
    2,113
    271
    Mar 25, 2007
    I see flat blocks and radius blocks. Can I ask which do you prefer? New build needs to be worked. Tele style neck.
  2. Freddy G
    Freddy G V.I.P. Member
    8,894
    16,133
    Mar 18, 2007
    Flat blocks for flat surfaces.
    Radius blocks for fretboard radius.
    Flexible rubber blocks for contours (carved top, back of neck peghead and heel transitions etc.)
  3. Weldaar
    2,113
    271
    Mar 25, 2007
    For the fender radius on the frets
    I would use a radius block?
  4. Freddy G
    8,894
    16,133
    Mar 18, 2007
    This is a subject that has come up time and again.
    Use the radius block to sand the fretboard but never to level the frets....use a flat leveling bar, or a flat diamond stone for fret leveling.
  5. pshupe
    pshupe MLP Vendor
    2,679
    1,494
    Jan 19, 2012
    This is what I use and it works well. It's wide enough to make quick work of levelling, and also quite heavy.
    You are more concerned about the string path of each individual string being straight and level. You should check your neck and frets with a straight edge prior to leveling to make sure there isn't something wildly out.
    Cheers Peter.
  6. Weldaar
    2,113
    271
    Mar 25, 2007
    Got it. Now I understand. Thanx so much.
