Safe easy way to take a little of new nitro shine off Les Paul Classic Plus?
Discussion in 'Gibson Les Pauls' started by Lkdog, Mar 3, 2018.
  1. Lkdog
    Lkdog Senior Member
    1,300
    534
    Apr 4, 2013
    As title says- looking for a safe way to dial back the shine on a 2017 LP Classic Plus.
    I bought it used from MLP member here in like new condition and he had added an amber switch tip, a switch ring, tophat knobs, and blank truss rod cover and backplates to give it a more vintage look.
    Having been used to VOS historics for years- I am swapping out a few stock parts for used aged ones I am rounding up (bridge,stopbar, tuners, pickup covers). So this is kind of a minor low cost aging project.
    Guitar sets up, plays, and sounds very good.
    Question is if there is a easy safe reversible way to take a little of the nitro shine off?
    It is a heritage cherry burst with subtle flame- kind if like you might see on an R8.
    Done a few searches. Do not want to use Scotchbrite or steel wool on it.
    Am wondering about some safe polish or mild rubbing compound that would dial it back a little bit, but if I want to go back to the original shine I could do so.
    Any input is welcome.
  2. Prometheus
    Prometheus Senior Member
    1,916
    2,793
    May 22, 2012
    I honestly don't see any other way than old elbow grease and play her...
    filtersweep, yamariv, SHERIFF and 2 others like this.
  3. Leña_Costoso
    Leña_Costoso Senior Member
    733
    686
    Aug 28, 2017
    The key word there is "reversible", but the question is "at what price?".
    "Play the fokker like you stole it...."
    SHERIFF and Bobby Mahogany like this.
  4. SlyStrat
    SlyStrat Senior Member
    1,794
    891
    Jan 24, 2009
    First World Problem.........
    NINFNM and yamariv like this.
  5. Latearrival
    Latearrival Senior Member
    1,311
    756
    May 28, 2011
    Amazingly so!.....I wonder if anyone would even be asking this question, say 30, 40 years ago?....
    Just play it and don't polish it!....
    yamariv likes this.
  6. Lkdog
    Lkdog Senior Member
    1,300
    534
    Apr 4, 2013
    Hey sorry. I thought I was on the Les Paul forum where people discuss.......Les Pauls.
    You can go back to yelling at kids to get off your lawn now.
  7. Uncle Remus
    Uncle Remus Silver Supporter
    891
    1,626
    May 5, 2016
    Maybe a white 3m pad?
  8. afjungemann
    afjungemann Senior Member
    658
    523
    May 23, 2014
    I would think the only choice is to get some good swirl action from a lightly abrasive compound. If you wanted to reverse it, you could polish it back out. It would of course come at the cost of a certain amount of your nitro.
  9. tolm
    tolm Bigsby Junkie
    3,759
    2,375
    Jul 20, 2008
    Half a dozen gigs oughta do it ...
    azzapeel and yamariv like this.
  10. NHTom
    NHTom Senior Member
    648
    745
    Jun 7, 2014
    I would think if you went with a very mild compound or even a light "'swirl remover" and a LOT of elbow grease, it would tone it down a bit, but could always be re-polished back to gloss if you wanted.
    Ideal would be to have something to test it on first......scary to just do it with no test.
    NHTom
  11. Rotorhead
    Rotorhead Senior Member
    480
    1,057
    Jan 10, 2018
    Most every kind of polish or compound is going to have an opposite effect from what you're trying to achieve. It's their job, really.
    bulletproof likes this.
  12. bulletproof
    10,099
    21,434
    Jun 1, 2011
    Exactly.....I think y’all would achieve the look yer going for by playing it. A lot.....
    Rotorhead likes this.
  13. crazytrain513
    crazytrain513 Senior Member
    1,411
    855
    Nov 1, 2012
    I agree. I know this isn’t the answer you want to hear, and I’ve often wondered if I could tone down the sheen of my tea burst Classic myself but honestly, there isn’t really any legit substitute for time, playing it and, frankly, being a bit careless with keeping the guitar clean. Especially now where the finishes have been made to avoid checking and essentially last “forever”.
    There’s a reason why VOS finishes add so much to the cost of the instrument.
  14. 07rogersg
    07rogersg Senior Member
    240
    75
    Aug 29, 2008
    Anything you do to dull the finish will remove a bit of the nitro, which by its nature is non-reversible without reapplying more lacquer.
  15. dsmcl77
    dsmcl77 Senior Member
    3,142
    8,834
    Jun 2, 2014
    Room full of smoke, sweat and beers.
  16. Breezin
    Breezin Senior Member
    500
    664
    Sep 6, 2014
    Not true really.
    Polishing compounds vary in degree and purpose.
    There are aggressive "cutting" compounds that leave a dull finish
    (when used by hand) that are used before a finer finish polish.
  17. XpensiveWino
    XpensiveWino Senior Member
    1,218
    788
    Dec 24, 2014
    @Breezin above is exactly correct.
    I was also thinking you could get a set of 3M micro polishing papers. Start with the 1 micron and go up from there to 'rough' it up. What I don't have an answer for is how you do it without causing swirls, directional scratches, etc... maybe others will chime in.
  18. ARandall
    ARandall Senior Member
    11,713
    7,043
    Apr 16, 2012
    The problem here is that you are trying to get a worn in look......but you generally get that with lots of different depth scratches. Simply dulling the finish with 1 type of pad or compound gives you that amateur relic look where you simply have a matte finish in degrees. It not only looks nothing like vintage, but will look a lot worse than the VOS.
    Rocco Crocco, endial, Pappy58 and 3 others like this.
  19. bulletproof
    10,099
    21,434
    Jun 1, 2011
    Exactly what I was trying to say.....
    dsmcl77 likes this.
  20. Lkdog
    Lkdog Senior Member
    1,300
    534
    Apr 4, 2013
    Thanks for all of the input. I knew I wasn't all that crazy to be thinking about how to do this.
    Kind of nervous about any scuffing or micro mesh actions. I have used mild car rubbing compound before to fix imperfection on nitro. I
    probably polished it after that then. Don't remember.
    I can't recall if it dulled it up or not. If there was a way to test it out I might try that.
    Maybe the idea of just playing it a lot in the humid summer months coming up is the best idea for now.
    I will post a picture of it later this week when I get all of the different parts on it. It is coming together pretty well and best of all it plays and sounds
    really pretty good. These newer USA Gibsons are really good build quality. This one has the 59 pickups in it stock - not the 57 Classic and 57 Classic plus.
    I might throw some SD Antiquities I have in it as they are maybe my favorite PAF, but have to say these 59 pickups are pretty damn good.
    Sorry for being a smart ass above.
    I agree there are more important things in the world to worry about.
    azzapeel, bulletproof and Blue Blood like this.
