RS Kit for R9?
Discussion in 'Historics & Reissues' started by Rubber Duck, Sep 6, 2017.
  1. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    I have stock electronics in my 2006 R9.
    My volume pots are noisy/scratching, the tone controls are not very functional, so I am considering to modify all the electronics.
    I have the old version of RS kit (with Jensen) in another Les Paul, I really liked the change.
    Now it seems RS has another kit for LP, with some RS branded caps. Called "Pre-Wired Premium Vintage/Modern Upgrade Kit - Short Shaft"
    Anyone tried these, and how are they compared to the old version? Alternatives?
  2. rclausen
    rclausen Senior Member
    2,593
    1,990
    Nov 9, 2011
    You'll achieve the same results. If you like the harness in your other LP then go with RS again. I can also recommend ReWind harness's as being the beez neez. I had James wire up a harness for my 335 and the results are fantastic.
  3. grayd8
    grayd8 Senior Member
    1,356
    1,091
    May 5, 2014
    RS makes some good stuff, but for Historics I like "The 59" wiring harness by Jonesy.
    Great quality CTS 550k pots, correct taper and luxe bees.
    alnico59 likes this.
  4. blackie2
    blackie2 Senior Member
    945
    834
    Aug 12, 2011
    If you can solder, get your own pots and caps then you'll save a bundle of cash too. Lots of suppliers out there for the parts.
    Dilver likes this.
  5. Wizard of Ozz
    Wizard of Ozz Senior Member
    107
    66
    May 6, 2011
    They're great... good stuff... good dealer.
  6. Rubber Duck
    Rubber Duck Member
    51
    154
    Sep 9, 2013
    Just to summarize; I ended up ordering "The 59" from Jonesy.
    I am very satisified with it, the guitar went from great to GREAT!
    I wouldn't hesitate to order again for my coming Historics:slash: (if needed...)
    musicmaniac, grayd8 and alnico59 like this.
  7. musicmaniac
    musicmaniac Senior Member
    6,307
    2,344
    Aug 11, 2012
    Good choice congrats!
    Rubber Duck likes this.
