Reverb pedal suggestion for my set up
Discussion in 'Pedals' started by Crotch, Mar 8, 2018.
  1. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    12,181
    18,000
    Jan 13, 2012
    I usually run a Stratocaster into a Fender Eric Clapton Tremolux. I love the sound of the amp so don't want to screw it up but I need to have some reverb. (the trem is ridiculously stupid on this amp unless you're playing surf tunes) I have other amps that have built in reverbs but I like the sound of this amp a lot, the notes just choke out a little.
    I like the Wampler Faux Spring and WET out of all the ones I've looked at but anything else you can suggest? I don't use pedals at all really anymore, but would like a true bypass analog box. Really like the Wampler but no battery, which isn't a killer I guess.
    Suggestions? Thanks!
    bulletproof likes this.
  2. Travis19
    Travis19 Senior Member
    503
    654
    Apr 26, 2013
    I used the Strymon Flint for years and can highly recommend it. If you're into a really wet reverb (surf rock, etc.) then you might want to look at the Topanga by Catalinbread.
    I only stopped using the Flint after picking up a tube driven outboard reverb unit made by Headstrong (the Prima Verberato). It was expensive, but money well-spent. I've heard good things about the Victoria Reverberato as well, but I've never played one.
    Crotch and bulletproof like this.
  3. bulletproof
    10,139
    21,594
    Jun 1, 2011
    I just got this recently,great verbs,however, I really don’t think y’all need the trem...:laugh2:
    Crotch likes this.
  4. northernguitarguy
    northernguitarguy SWeAT hOg
    27,350
    44,376
    Feb 22, 2009
    I have a first gen. Tech 21 Boost RVB for trade. Six knobs, a tweaker's dream. Take advantage of the weak Canadian dollar. :naughty:
    Mockbel and bulletproof like this.
  5. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,421
    8,237
    Apr 4, 2013
    I really like the TCE HOF mini. It's super simple and there is a tone print that was created by/for JD Simo that is really good. That's the only tone print I use and it's all I need. Basically, when you pick softly, it's more noticeable, but when you play more loudly, it's more subtle.
    Here's a video of him talking about it...
    You can skip to 1:05 to hear him describing the concept or 6:05 to hear examples...
  6. Gridlock
    Gridlock Senior Member
    2,039
    1,653
    Nov 30, 2011
    I have a Catlinbread Topanga Reverb pedal. As close to BF & SF Fender spring reverb tones as you can get. I stopped looking for Reverb pedals after buying this pedal.
    A Strymon Big Sky might be a little better, but it’s at least $100 more than the Topanga.
    I also picked up a used Fender ‘63 RI Reverb Unit at a good price. I’m using the Reverb Unit into the Loop with my Marshall Astoria and the Topanga out-front with my Marshall Bluesbreaker. Great Reverb either way.
    BurstingOut and bulletproof like this.
  7. bulletproof
    10,139
    21,594
    Jun 1, 2011
    That’s brilliant,man.... I may have to have one.
    bossaddict likes this.
  8. Crotch
    12,181
    18,000
    Jan 13, 2012
    Probably more of what I'm after, a simple, small stomp box that's gonna be under $200 without modding anything or doing anything special.
    bulletproof and bossaddict like this.
  9. joff
    joff Senior Member
    1,898
    1,485
    Jan 16, 2010
    I have the Neunaber WET Mono Version 4...sounds great thru' my EC Vibro Champ. :)
  10. Mockbel
    Mockbel Senior Member
    2,154
    1,798
    Nov 2, 2015
    I am a bit biased to TC Electronic in modulation effects so I would say Hall of Fame.. I don’t have it but i like TCE products in general
  11. Mookakian
    Mookakian Senior Member
    6,181
    2,283
    Jan 18, 2010
    Neunaber wins in the verb department to me hands down. Ive had 4 TC products and all had issues so i just cant suggest them to others.
    Otherwise for versatility the strymon units all sound nice, but for me its always neunaber, the algorythms they put out are sublime
