Rescued Squier Tele electronic problem
Discussion in 'Luthier's Corner' started by 5F6-A, Sep 12, 2017.
  1. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    Somebody gave me a neglected, almost left for dead 2007 Squier Tele which had some parts missing. I have been bringing back to life with whatever bits and pieces I had at hand. It is almost functional now and I have left the relic look intact as I prefer guitars that look and feel used anyway.
    Two problems:
    - The guitar hums through some amps and not others. The type of hum that goes away when you touch metal parts (e.g. strings). Some amps hum like mad and others don't. Why could that be?
    - There's no continuity between neck metal cover and pot casings. Is this normal. I always thought tele neck cases were connected to earth... could that be the reason for the ghost hum?
  2. DarrellV
    DarrellV Make the Switch for the Better! Silver Supporter Premium Member
    10,404
    12,917
    Nov 1, 2016
    I would start there. Make sure all the pot cases are grounded and the bridge plate.
    Make sure your jack is wired properly and not reversed.
    You didn't say if it hums in both pup positions or favors one or the other..
    See if the neck cover is grounded with the coil ground and make sure that they aren't reversed.
    This would make the neck cover hot...
  3. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    Hum is the same when using any of the pickup switch combination....
    Neck pickup was quite battered when I got it. only 2 wires as well.
  4. DarrellV
    10,404
    12,917
    Nov 1, 2016
    Still sounds like the hot and ground are backward on the jack...
    Or the ground is floating and unhooked from the rest of the guitar.
    :photos: would help, obviously...
  5. chasenblues
    chasenblues Senior Member
    19,010
    25,294
    Apr 2, 2007
    The grd might be tiny or not look like a grd.
  6. Fred
    Fred Premium Member
    247
    59
    Feb 8, 2010
    The ground wire is supposed to go under the bridge plate not the neck plate.
  7. chasenblues
    19,010
    25,294
    Apr 2, 2007
    w666 likes this.
  8. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    Good news and bad news.
    Good news: hum is gone.
    Bad news: my beautiful jtm45 clone is responsible for the hum. tried today with a different guitar and it hums too until I become earth by touching strings.... :(
  9. Robert Parker
    Robert Parker Senior Member
    497
    147
    Aug 3, 2010
    How is the power in your home? I found recently that if it has rained recently - say a few days anyway - I get WAY more hum from my amps and guitars. If it's been dry for several days the signals are all much quieter.
    My gear is also dead quiet at my buddy's house where we rehearse, regardless of weather. So you might take the amp and a couple guitars elsewhere and see what happens.
    5F6-A likes this.
  10. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    I live in northern England.... rains fairly often LOL!
  11. chasenblues
    19,010
    25,294
    Apr 2, 2007
    5F6-A likes this.
  12. 5F6-A
    5F6-A Senior Member
    9,365
    1,931
    Aug 16, 2007
    Not unlike what I see around me everyday! LOL
