REPLACING KNOBS ON 2016 LP TRADITIONAL
Discussion in 'Luthier's Corner' started by Jonboy, Dec 29, 2017.
  1. Jonboy
    Jonboy Junior Member
    3
    0
    Nov 9, 2012
    I HAVE A 2016 TRAFITIONAL PRO III, WHEN PURCHASED NOTICE 2 CRACKED KNOBS.WOULD LIKE TO REPLACE THEM,BUT THEY ARE VERY TIGHT(ON PISH/PUSH POTS). I HAVE HEARD OF POTS BEING DAMAGED TRYING TO REMOVE KNOBS...BEST WAY TO GO ABOUND REMOVING/REPLACING KNOBS...THANKS
  2. Who
    15,385
    27,008
    Mar 15, 2012
    I've damaged a pot pulling one off, once.
    Since it's push/pull, it will be easy to get under the knob. Sort of like what this dude is doing:
    Wrap the edge of a t-shirt under, and lift the shirt. If it seems like it is VERY difficult, stop.
    Then (and this is just me, because I love the Dremel).... I would protect the surface of the guitar, and use a Dremel cutting wheel to crack the knob in half.
  3. flamesarewicked
    flamesarewicked Senior Member
    527
    492
    Feb 12, 2013
    I use a knob puller tool.. it was less than $10 online.. just put new knobs on my 17 traditional 67A8375C-23D3-428D-8B4C-9A00291A6CE1.jpeg
    Who likes this.
  4. bluesriffdev
    bluesriffdev Senior Member
    376
    256
    Mar 10, 2014
    I've never changed knobs on a push/pull pot, how would they be different to normal pots in terms of risk of being damaged?
    I'd just do what the persons above have said, or get a piece of string, form a knot over the knob and pull it upwards towards you.
  5. mux164
    mux164 Senior Member
    2,618
    1,869
    Sep 1, 2012
    Shoelaces work great, or I have even used wires out of an old extension cord that I have stripped
  6. Who
    15,385
    27,008
    Mar 15, 2012
    I would think knobs on push/pulls need to be snug. Don't want to pop one off during a show.
  7. guitarjoem
    guitarjoem Double Platinum Supporter MLP Vendor
    499
    256
    Dec 15, 2014
    Kris Ford likes this.
  8. WezV
    WezV Senior Member
    351
    403
    May 17, 2016
    It’s possible to pull the entire shaft out, don’t ask me how I know this. Then it’s new pot time.
    You can normally do it by going slow and carefully.... but if you are getting rid anyway cutting it off is a safer answer.
    bluesriffdev and Who like this.
  9. Subterfuge
    Subterfuge Senior Member
    547
    737
    Aug 18, 2017
  10. monkfish
    monkfish Member
    82
    91
    Mar 23, 2014
    smk506 likes this.
  11. Dilver
    Dilver Senior Member
    780
    981
    Apr 26, 2011
    I’ve always used the cloth method - put cloth under the knob, twist it tightly to “grab” the knob and and pull upwards. Personally, I’d avoid anything where you’re putting ANY pressure on the top. Easy and cheaper to replace a pot vs a dent in your finish. Even if you were to damage the pot (doubtful), they are pretty cheap and easily installed. Don’t worry about it so much.
  12. WezV
    WezV Senior Member
    351
    403
    May 17, 2016
    All the advise so far is fine for normal pots, but a tight knob on a push/pull does need more care... there is a very real chance of damage if it’s not done slowly and carefully
  13. WezV
    WezV Senior Member
    351
    403
    May 17, 2016
    dickjonesify likes this.
  14. dickjonesify
    dickjonesify Senior Member
    4,742
    4,615
    Apr 16, 2010
    I would try to offer advice but, I’ve broken many knobs :doh:
  15. kmasters68
    kmasters68 Senior Member
    1,317
    345
    Aug 6, 2015
