Replacement top hat knobs for 2016 R8?
Discussion in 'Historics & Reissues' started by GazzaBloom, Jan 1, 2018.
  1. GazzaBloom
    GazzaBloom Member
    45
    53
    Apr 1, 2016
    My 2016 R8 knobs sit very high off the body. There is no real scope to put washers cavity side of the pots as there is very little thread available for the nuts as it is. It appears that the pot shaft length is too long, or the knob holes aren't deep enough. (No pun intended ladies!)
    Is there a suitable aftermarket replacement knob that will sit more flush to the body that you can recommend?
  2. rockinlespaul
    rockinlespaul Oxblood Addict V.I.P. Member
    9,837
    9,610
    Aug 12, 2007
    Pics?
    Kris Ford likes this.
  3. Kris Ford
    Kris Ford Senior Member
    4,754
    4,033
    Dec 17, 2011
  4. winexprt
    winexprt Senior Member
    3,389
    3,115
    Aug 17, 2008
    Pics of how high your R8's knobs are would really help. Any different knobs would have the same shaft depth I believe.
    Pappy58 likes this.
  5. GazzaBloom
    GazzaBloom Member
    45
    53
    Apr 1, 2016
    Here's a pic showing the gap:
  6. bossaddict
    bossaddict @david.beason on IG Premium Member
    6,424
    8,244
    Apr 4, 2013
    That height looks normal for a Historic. I'm not aware of any aftermarket knobs that would be drilled deeper. I think you might be better off putting some washers or something on the control cavity side of your pots to make them stick out less, but still have enough thread for the nut to be able to bite.
  7. Crotch
    Crotch Support MLP Veterans & Vendors Double Platinum Supporter Premium Member
    12,217
    18,083
    Jan 13, 2012
    I agree. It doesn't look too far off. They don't sit as flush as USA.
  8. DanD
    DanD Senior Member
    669
    673
    Feb 23, 2009
    I've found that my knobs aren't all completely seated on some of my newer Gibson's. Appears they quit 'hammering' them home. Not nearly as many cracked knobs tho.
    If you pull the control cavity cover and support the back of the pot with one hand and apply force to the same knob with the other you'll get a bit of seating on some knobs.
    Looks like the highest knob in the foreground needs the nut raised on the shaft. Thin pot washers in the control cavity will help there.
    I slightly warm my knobs before installation. Makes it very easy to completely seat them. ;)
    Kris Ford and GitFiddle like this.
  9. Tim Plains
    Tim Plains Senior Member
    12,457
    7,631
    Feb 11, 2008
    That wouldn't bother me any. I'd be more concerned with adding a second thumbwheel to that bridge post (but even that isn't a real concern).
  10. GitFiddle
    GitFiddle Senior Member
    10,885
    13,444
    Jun 2, 2010
    DanD likes this.
  11. One-Eyed Jack
    One-Eyed Jack Junior Member
    27
    3
    Feb 9, 2009
    Look again, I can see a lot of bushing threads in your image. BTW, I have at least one LP that has elevated knobs like yours and have never thought about lowering them. The suggestion to heat the knobs sounds like the first thing to try, if you're bothered by the height.
  12. GazzaBloom
    GazzaBloom Member
    45
    53
    Apr 1, 2016
    Thanks for the replies guys. As I have been looking at the knobs closely lately I have now noticed thet they are all have crack lines showing inside! No idea how this has happened as the guitar has never been out of the house and is always hanging up. The knobs have never been removed. They work fine and the crack isn't through to the top but I can see 2 or 3 crack lines inside each one.
    I may well get some replacements now.
  13. Crotch
    12,217
    18,083
    Jan 13, 2012
    It's pretty normal actually. The cracks.
    DanD likes this.
