Refret Tutorial
Discussion in 'Luthier's Corner' started by Freddy G, May 8, 2011.
  1. Freddy G
    Freddy G V.I.P. Member
    12,096
    26,497
    Mar 18, 2007
    Thanks Roman!
  2. steadystate
    steadystate Member
    60
    32
    Mar 4, 2013
    This thread is exactly what I needed today. Thanks!
    1 person likes this.
  3. jbrybar
    jbrybar Senior Member
    310
    166
    May 4, 2011
    Many thanks to you for the in depth tutorials. I am so grateful for you and all other members graciously sharing your techniques for repairs, and building guitars from scratch. I have learned so much and am working on finishing my first build ever. I already have most raw materials and parts for my second build which I plan to document and share. I've been a member for awhile now but have "lurked" long enough. Again I can't thank you enough. I'm hooked!
  4. Happy Trees
    Happy Trees Senior Member
    577
    250
    Feb 21, 2013
    You are officially THE MAN!
  5. Ian Coros
    Ian Coros Member
    98
    45
    Nov 25, 2011
    A hairdrier can work wonders when removing neck binding , though be very careful not to deform it , I just used it to make it touchwarm iyswim .
  6. Actinic
    Actinic Senior Member
    3,379
    2,948
    Feb 17, 2011
    A how-to page on fret removal issues the following warning:
    DO NOT use a soldering gun to heat up the fret on a Gibson guitar, as you cannot remove the neck from the body easily. You could damage the pickups.
    How to Remove Electric Guitar Frets - Electric Guitar Repair
    This does not make sense. A soldering iron should not damage a pickup, otherwise covers could never be soldered to pickup baseplates. Where did this urban legend come from?
  7. MRJ5
    MRJ5 Premium Member
    1,542
    379
    Jun 13, 2008
    I believe what is referred to as a "soldering iron" is actually should be referenced as a soldering gun.
    There is some truth to this. This type of soldering gun contains a transformer to regulate heat. This transformer creates a magnetic field when held close to the pickups, could demagnetize the magnet. This is not true for the pencil type soldering irons.
    I have seen people successfully use a soldering gun around pickups before with no damage but I have also seen the transformer in these types of guns weaken magnets. These warnings have been around for years and while I would not call them a urban legend, I would caution that improper placement of the transformer in these types of soldering guns to pickups could magnetize the magnets.
    Additionally they create way too much heat and could damage components when used to solder electronic parts. Soldering pencils (irons) are much better suited to guitar work.
  8. Actinic
    3,379
    2,948
    Feb 17, 2011
    Those big guns are pretty scary, and Freddy does not use them. But when a hobbyist (one of us) uses a temperature controlled iron, you can have 2 amps shooting through a heater element that transfers energy to a tip. Voltage is around 25 V for a 50 W iron. AC is probably worse than DC, but DC is easier to control and maintain. Impact on the pickups is the primary consideration.
    Since most soldering irons produce a minimum of 400 deg F of heat at the tip, is this underkill or overkill for heating the fret? The good irons have a temperature sensing feature, and I want to use that to control the beast. I am trying to find excuses to put off a fretting job on a set-neck guitar, and any excuses members can give me to just wait and let a pro do it are welcome. The tools and supplies have already been bought. Man, they are expensive. :lol:
  9. milkjam
    milkjam Senior Member
    683
    499
    Jan 4, 2010
    just another thank you for these vids. i recently got an old guitar that is in very bad shape but i decided to have a go at refretting it. there is a ton of great info here on this site and this kind of sticky is an excellent resource. really really good of you to take the time and trouble to share your knowledge. cheers!
  10. Tugboat
    Tugboat Senior Member
    376
    86
    Oct 25, 2012
    Some sage advise from a PM conversation with Freddy (Freddy should be by shortly to post his response to my question):
    I have another question if you have a few. I used your instructions to install my frets (I didn't have a drill press or fret press so I improvised with a 12" radius block and a fret hammer). Everything went smoothly but there's one fret that one end popped up on a bit. I didn't catch it until I'd already glued it in. Will this get fixed after a fret level or should I reseat the fret somehow? Or should I remove/reinstall?
    See the pictures below:
    Another picture (it's the third fret):
  11. Freddy G
    12,096
    26,497
    Mar 18, 2007
    Once you heat CA and break it's bond it's useless. So yes, I would pull that fret and replace it. You might try running a bit of thin CA glue into the slot after you pull the fret out. Then after the CA is hard recut the slot with your saw. This will give the barbs on the fret tang some solid material to grab onto.
    I add glue to freeze the fret in the slot regardless of what species the fretboard is.
  12. twinrider1
    twinrider1 Senior Member
    3,080
    1,353
    Apr 29, 2007
    Thank you Freddy G. Greatly appreciated. Just watched Part 1 (how'd I miss these?)...at 13:20, careful, that's hot. :)
  13. sevycat
    sevycat Member
    53
    41
    Jun 5, 2011
    I did two refret jobs on my beater guitars as practice, this tutorial gave me something new to add to my skill set as I move forward in learning.
  14. Baylin
    Baylin Senior Member
    1,150
    846
    Feb 16, 2014
    2 people like this.
  15. EssexBlues
    EssexBlues Junior Member
    1
    0
    Jan 13, 2015
    I think I got here just in time. Got the neck of my Hamer on the bench. Thanks for straitforward approach.
  16. kakao
    kakao Senior Member
    1,548
    641
    Jun 24, 2014
    Thank you for the great video ..
  17. CheopisIV
    CheopisIV Copper Slinger MLP Vendor
    3,622
    2,730
    Apr 15, 2010
    I've been sitting on a USA Tele neck for a while with intent to refret. Finally bit the bullet after finding this thread and got at it. Total beginner work here but I sure learned a lot! She ain't pretty but it's definitely playable now and feels very nice. I got it cheap as the previous owner pulled the first fret and damaged the board some. Nothing too bad, just cosmetic so doesn't bother me.
    #1) Measure your fretwire before ordering. I ordered much narrower wire than was previously on it, which isn't necessarily a bad thing, but the new stuff shows some of the spur holes from the old wire and the discoloration.
    #2) Get the Fret Polishing guards!! I didn't and scratched up the board pretty good even though I taped it off. Tape doesn't put up with much friction or heat. I intend to sand it down and refinish it someday anyway as it already had some worn through spots on the front and back.
    #3) Take your time and do it right! Freddy's Vid was perfect and it was a lot easier than I anticipated. I rushed through and did the whole board in 2 days (maybe 4 hours total) and it actually turned out very good from a players perspective. Craftsman perspective I rate my work as 2/10 but it's a testing guitar (and my own) so I don't care much about the pretty factor :)
    #4) Getting the nut right gave me a whole lot more issue than the frets and it's still not quite right but close enough for now. I ordered a 'pre cut Fender' nut from Mojotone and it still needed a lot of filing to get to the right outside dimensions. I think I spent as much time on the nut as I did on the refret!
  18. Dr Gonzo
    Dr Gonzo Junior Member
    5
    1
    Jul 18, 2015
    Thanks for the tutorial. However, after seeing this I know I am not ready to do this on my own ;-(
  19. fatdaddypreacher
    5,933
    3,925
    Feb 5, 2011
    just wanted to stop in and say thanks a million on a splendid thread, freddy. I've only done one refret, as what little i do is a few new hobby builds, and the one i did was already butchered by someone, so i couldn't hardly hurt it. I do however, have a refret someone wants me to do so i studied your videos and found them exceedingly helpful. well done, well filmed, and easy to understand--even for an old fart like me.
    thanks for all you do for the forum, and especially this contribution. i'm sure you spent much of your valuable time compiling and posting this. thanks again.
  20. Freddy G
    12,096
    26,497
    Mar 18, 2007
    I'm glad these videos are proving to be helpful!
