Refret Tutorial
Discussion in 'Luthier's Corner' started by Freddy G, May 8, 2011.
  1. Popskull
    Popskull Junior Member
    22
    3
    Jan 10, 2012
    So I just attempted a partial re-fret, As I suspected there was no trouble yanking the frets out but it turned out to be more work to do a partial refret than replacing all of them.
    All the frets ended up being different height/un-even due to not bending them enough (Don't own a fret bender), not cleaning out the slots enough thus the frets sat tall.
    SO... I have to do it all over again. This time I'm going use a saw to cut the slots clean, properly cut the tang as to hang over the binding and not dig in to it.
    Ah well, learning curve i guess.
    1 person likes this.
  2. RockinRyan13
    RockinRyan13 Member
    60
    3
    Apr 10, 2011
    question, what does everyone find to be the best method to removing scuff marks from filing down the fret edges?
  3. gtr-tek
    gtr-tek Fumble Fingers
    2,589
    863
    Mar 24, 2010
    Sanding. Lots of sanding... Start at around 320 grit and work your way up to 1200.
  4. melomanarock
    melomanarock Senior Member
    232
    265
    May 13, 2010
    Hey Freddy,
    Do you have any special tips to avoid chip out when removing frets from an ebony board??
  5. Freddy G
    Freddy G V.I.P. Member
    12,096
    26,500
    Mar 18, 2007
    Have a bottle of CA glue ready and glue the chips back into place immediatley!
    Let the wire heat up well, go slow when pulling them out. Pay close attention, when you see a chip starting too pull up use another tool like a small slot screwdriver to hold the chip down as you continue.
    2 people like this.
  6. Aleksander
    Aleksander Senior Member
    280
    103
    Sep 16, 2010
    To avoid the cheap put the strongest tape next to the fret you are removing, and heat it up. :dude:
  7. BPW666
    BPW666 Senior Member
    241
    173
    Jul 27, 2012
    Quick question, the truss rod, do I take the tension off before levelling the frets?
    I've got a cheap battered old Ibanez shred machine that I love an want to spruce up a bit, one thing it needs is the frets levelling a touch. The neck is so thin that as I'm restringing it everything frets out until I've got 5 strings on to pull the neck straight. So if I level the frets with the strings off and don't adjust the truss rod I'll end up with a concave surface when the strings are back on.
  8. Freddy G
    12,096
    26,500
    Mar 18, 2007
    Different approaches to that problem. You can use a jig like Dan Erlewine's neck jig which holds the neck in playing position when the strings are off.
    Another way if you don't have the jig is to sight down the neck when it's strung up to pitch and evaluate the problem areas. Typically what you might see is some uneven fret(s) height, perhaps a twist in the neck, perhaps there's a hump or rise near the highest frets (all just examples of what to look for). Also, what does the relief look like? A lot of times on a very thin neck the relief will get suddenly drastic just at the first couple of frets. It should be a more gradual curve.
    Anyway, make note of everything you see and which areas you should concentrate on leveling (keeping in mind that you have to work out these problem areas in concert with leveling out frets that are pitted).
    It will help to relax the truss rod so that the frets are in a basically straight plane when you do the levelling. You may find that you'll have to do some levelling, then string up to pitch to check your progress.
  9. BPW666
    241
    173
    Jul 27, 2012
    Thanks Freddy much appreciated. I think once I've finished my current build I'll have a go at refurbishing the Ibanez.
  10. P-Five
    P-Five Member
    85
    18
    Aug 23, 2010
    So, if I understand correctly, WITH the jig you level the frets with the neck in playing position, so with a slight up bow? Without the jig you have to get the neck as straight as possible? those two methodes contradict eachother... Or are there more ways to achieve level frets?
  11. Freddy G
    12,096
    26,500
    Mar 18, 2007
    I can't speak for exactly how the jig works because I don't use one. Personally I evaluate the neck when it's strung up to tension and then work on the problem areas.
  12. P-Five
    P-Five Member
    85
    18
    Aug 23, 2010
    Hmmm... From what I understand from the SM website, the neck is straightened with the help of the jig, without changing the trussrod.
  13. Marshall Arts
    Marshall Arts Senior Member
    2,047
    409
    Dec 4, 2008
    Thanks for the awesome vids, Freddy.
    I'm actually confident now to try it myself. It's a usefull skill to have.
    But not on my LP's to begin with. I don't think I'll ever have the guts to do them myself :p
    I have a cheap telecaster copy a friend of mine salvaged from work (land fill). I think I'll practice on that one first. It has a few bad frets and a few springy frets as you mentioned in your vid. (But actually a guitar with potential, believe it or not :D )
  14. peach64
    peach64 Senior Member
    1,709
    862
    Mar 2, 2009
    Thank you, Thank you, THANK YOU Freddy,
    you are THE MAN! Now I know why I did lousy fret jobs, only to get them re-fretted by a professional luthier. I'm looking forward to giving it another go.
    Any suggestions for a bound brazilian fretboard for my Les Pauls?
    Thanks Again,
    Peach
  15. Harborbreeze
    Harborbreeze Junior Member
    4
    1
    Aug 31, 2012
    I have seen your video it really entertaining. I enjoyed it very much. I believe that if want to learn guitar then we have to consult a good tutor or trainer because its very risky to learn without help.
  16. Freddy G
    12,096
    26,500
    Mar 18, 2007
    A new addition. Here's a wacky refret job that that most of you will never have to deal with. I've never seen anything like this before so i thought I'd throw it up here...cheers! :dude:
    12 people like this.
  17. Mr Teeny
    Mr Teeny Senior Member
    3,543
    2,403
    Dec 27, 2010
    Amazing job as always Freddie, I was surprised the binding came away so easily. Was it as easy as you made it look or were there some hidden steps ?
  18. Freddy G
    12,096
    26,500
    Mar 18, 2007
    Thanks,
    Luckily it came off with very little effort and no damage.
  19. TKOjams
    TKOjams Senior Member
    10,060
    6,811
    Sep 12, 2009
    I absolutely love those basses!!! (It's a getty thing of course):dude: wonderful job bringing her back to her former glory.:applause::applause::applause:
  20. Roman
    Roman Master Luthier V.I.P. V.I.P. Member
    6,688
    5,758
    Dec 4, 2007
    Freddy, I just watched your videos over lunch. Very well done, concise, and informative.
    Hats off, you are the new Dan Erlewine! :thumb:
    3 people like this.
