Refret Tutorial
Discussion in 'Luthier's Corner' started by Freddy G, May 8, 2011.
  1. MBrennan
    MBrennan Senior Member
    175
    58
    Feb 3, 2010
    This is a great tutorial--Thanks for taking the time to post them.
    I've got an old maple Kramer neck in need of new frets and have been putting off trying it myself -- 'til now.
    I use my drill press for a fret press also. One thing you didn't mention--be careful turning on the work light on the drill press!? :shock:
    Can't wait Chapter 4! :thumb:
  2. Freddy G
    Freddy G V.I.P. Member
    10,829
    21,894
    Mar 18, 2007
    Damn right! :thumb:
  3. redozzman
    redozzman Member
    68
    31
    Sep 8, 2010
    I'm fairly new to this forum, and I must say that for you to take time to produce these tutorial videos is absolutely fantastic! they are a pleasure to watch and you do an outstanding job! keep em coming!!! That goes for all the great luthiers on this site!!! THANK YOU!
    Freddy G likes this.
  4. Tim Plains
    Tim Plains Senior Member
    12,475
    7,667
    Feb 11, 2008
    Great video. :thumb:
  5. Penny Dreadful
    Penny Dreadful Banned
    6,199
    6,218
    Feb 21, 2008
    It takes time to put together these videos. I really appreciate the step
    by step walk throughs. :applause:
  6. Mr Teeny
    Mr Teeny Senior Member
    3,543
    2,402
    Dec 27, 2010
    Very concise videos as usual Freddy, how much harder is it to re-fret when there's binding on the guitar. Not talking about the nibs or saving them just when the fretboard has binding.
  7. Freddy G
    10,829
    21,894
    Mar 18, 2007
    Not a huge difference, but as I stated in the video, the slots are a bit harder to clean out. Also you have to undercut the tangs. But the one thing that's easier is that you don't have to file the tangs flush to the neck and risk scratching the finish.
    Here is the next part.
    HEADKNOCKER, Donnie, Deftone and 9 others like this.
  8. dickjonesify
    dickjonesify Senior Member
    4,742
    4,615
    Apr 16, 2010
    I envy your patience, Freddie. You're a great tech. Thanks again for the tutorial. :dude:
  9. Mr Teeny
    3,543
    2,402
    Dec 27, 2010
    Thanks, do you snip the tangs to size then file the tang off for a flush fit to the slot size. I've an old guitar that's just not worth the cost of a refret so may bite the bullet after this tutorial and give it a go.
    I took the plunge a month or so ago and refinished a guitar using the advice from yourself and others on the forum. Did the wet sanding and some buffing yesterday and gotta say I'm over the moon with just how flat and neat it's actually turned out. Certainly wouldn't have got anywhere near that result without the clear bits of advice on here of how to do things properly. Been times along the way when I've wondered what the hell am I doing this for but once you make inroads you wonder why the hell didn't I do it sooner.
  10. Penny Dreadful
    6,199
    6,218
    Feb 21, 2008
    I have had dead spots on guitars over the years, and it never occurred to me that
    it was the fretwire itself. I always thought that the truss rod needed a tweak.
    Just a heads up to my fellow thread followers that Freddy has recorded these videos
    in high definition. I click on the HD1080, go to full screen and enjoy!
    Thank you again Fred for sharing!
  11. nuance97
    nuance97 Premium Member
    2,172
    1,231
    Feb 26, 2009
    These videos are so freakin' great! Thank you so much Freddy!!:applause::thumb::D:applause::thumb:
  12. Ganorin
    Ganorin Senior Member
    287
    200
    Aug 7, 2010
    Same for me, thanks a lot! Others are charging $$ for such a detailed lesson!:applause:
  13. Freddy G
    10,829
    21,894
    Mar 18, 2007
    I use this Stew-mac fret tang nipper...works great!
    STEWMAC.COM : Fret Tang Nipper
    That red finish looks great BTW...nice job!
  14. Penny Dreadful
    6,199
    6,218
    Feb 21, 2008
    This thread is helping alot of people and its very detailed.
    May I suggest this being made into a sticky?
    Mods?..
    nuance97 likes this.
  15. free2rock
    free2rock Senior Member
    435
    179
    May 31, 2010
    Wow... Congrats on the sticky! :)
  16. drewguitars
    drewguitars Senior Member
    150
    33
    Feb 1, 2009
    Thank you so much for taking your time and doing the video's, i really like your way of doing things, you have the skills and the patience .
    This info will come in handy when i'm starting my first fret job...
    PS , i would let you refret any of my guitars anyday..
    Great work
  17. ExNihilo
    ExNihilo Senior Member
    1,612
    1,767
    Nov 21, 2008
    OK, that was simply fantastic. Thank you very much for all of your work putting that together.
  18. FF_Pedals
    FF_Pedals Senior Member
    2,125
    216
    Jan 22, 2009
    I really appreciate your tips Freddy. I'm just finishing up my first fretboard and used your x-acto blade trick to wick a little glue under the fret ends, it worked great! Before I was messing around with a capillary tube that kept getting clogged. I have some CA glue from a model shop that came in a little bottle that easily just puts a nice drop on the x-acto blade and the fret really soaks it up right off the blade without running all over the board.
    :thumb:
  19. melomanarock
    melomanarock Senior Member
    232
    265
    May 13, 2010
    amazing.. very helpful tutorial.. I could've used it a couple of years ago when I started cutting the frets from the first fret up and came short.. :s
    one thing though.. I haven't seen you check the slot depth to the fret's tang.. did I miss it somewhere??
  20. Freddy G
    10,829
    21,894
    Mar 18, 2007
    You're right, yes of course you should always check the fret slot depth. I glanced over it on this neck because I just compared the new wire tang to the old wire. If I were doing something like planing the fretboard to take a warp out or just rejuvinate the surface because of wear then I would most definately be checking the slot depth against the tang length.
