Recording Direct vs. Recording w/ mic?
Discussion in 'Recording Studio' started by MIDNIGHT, Dec 5, 2008.
Recording Direct? or Recording with a mic?
  1. Direct
    26.1%
  2. With Mic
    73.9%
  1. MIDNIGHT
    MIDNIGHT V.I.P. Member V.I.P. Member
    2,911
    36
    Aug 7, 2007
    hey guys :wave:
    just wondering what the majority preference was between recording direct and recording with a microphone :D .. please vote on the poll and feel free to discuss :thumb:
    :cheers:
  2. markophonic
    markophonic Senior Member
    329
    93
    Jun 20, 2008
    I prefer to mic 99% of the time...though I have done a couple recordings going through a Yamaha DG stomp. I just prefer to take some time and try to capture what I want with mic placement and the room etc.
  3. Sony Oengui
    Sony Oengui Senior Member
    535
    9
    May 27, 2008
    Mic, all the time. Used to record directly but a while a go I got a mic. Never looked back.
  4. lp_junkie
    lp_junkie Senior Member
    10,573
    479
    May 24, 2008
    I do both on separate tracks and blend the signals, each gives it's own flavor to the part.
  5. Sony Oengui
    535
    9
    May 27, 2008
    Mmm, never thought of that. I hate the "line in" sound, but I'll see what happens if i blend the two.
  6. tomaburque
    tomaburque Senior Member
    155
    6
    Nov 29, 2008
    Mic'd cab still sounds best. But this Line 6 stuff is really good and makes it fast and easy to get a good sound. The Line 6 distortions sound a little harsh and transistory at first, but they do cut through the mix.
  7. Slapjaw
    Slapjaw Senior Member
    415
    84
    Oct 27, 2007
    I always go direct. I'll have to quit being lazy and wire in some mics.
  8. ojk007
    ojk007 Junior Member
    6
    0
    Dec 7, 2008
    i've always preferred recording with a mic. As then, you get the sound of the cab :) That said, when possible i take a line out as well, and mix the two.
    personal preference would be the e906, a very nice solid cab mic.
  9. kluson
    kluson Senior Member
    1,977
    108
    Oct 28, 2007
    had to vote for direct as I'm using pro tools and my mic is rubbish. If in the studio I would use Mic every time. Usually I crank the amp in the studio and play and monitor in the engineering room
  10. MIDNIGHT
    2,911
    36
    Aug 7, 2007
    hmm.. pretty obvious favor for recording with mics (as i sorta expected xD ..) .. i'm thinking about starting to record with mic too.. planning on getting a new audio interface (cuz my line 6 toneport makes this annoying crackling sound..), specifically the presonus audiobox cuz it records 24 bit and i hear has notch-above-the-rest preamps in them.. then get an SM 57 or something and start recording that way.. :D
  11. lp_junkie
    10,573
    479
    May 24, 2008
    the direct signal track gives you clean audio to work with for adding effects and then blending with the mic'd cab track gets a big fat sound to the finished tracks.
  12. madams17
    madams17 Senior Member
    202
    3
    Jul 9, 2008
    I'm not crazy about the sound of direct (I have a POD 2.0) and prefer the sound of a cab mic'd when I can get it. I usually use a SM57 or SM58 off axis to the speaker.
  13. lp_junkie
    10,573
    479
    May 24, 2008
    for mic'd I use a Marshall 4x12 with a SM57 off axis on which ever speaker sounds best that particular day.
  14. Bowhunterwt
    Bowhunterwt V.I.P. Member
    525
    6
    Aug 9, 2007
    I use both at the same time. I miked and direct in. Then I eq each track differently so get each one a different sound, then pan each one to left and right channel. It make the guitar sound fuller. I used a audix I5 then run it thur a art tube preamp then to the board. I turn on the limiter to avoid high volume spikes. The direct line run thu a DBX Noise Gate then thu a limiter to get the same effect. So I can't vote on this poll because I do both~!!!!:hmm::thumb::fingersx:
  15. AbuseArt
    AbuseArt Member
    64
    0
    Aug 27, 2008
    I use mic or direct with simulator plugin, for instance Amplitube
  16. Volusia
    Volusia Senior Member
    1,550
    101
    Aug 31, 2007
    I use both from a SM57 and a Line6 PODXT Live. I prefer the tonal qualities of amp miking, however, I already have certain tones dialed in on my POD so when I'm ready to record I don't have to waste a lot of time finding the right set up with the mike.
    Although I prefer the amp miking overall I find that even when I set the amp up in the same place and put the mike in the same position I can end up with a sound different than I had the last time. :hmm: It could be hearing fatigue on my part but it happens. I also agree with others that doing both on your mix is the best bang. Then you can mix it to your liking.
  17. lifele55
    lifele55 Senior Member
    3,432
    486
    Sep 3, 2007
    Using the toneport GX, so I guess I'd have to go with the direct route until I can get a decent amp that is..
  18. moff40
    moff40 Senior Member
    4,648
    962
    Sep 19, 2008
    It depends on what style you're doing, too. I know country guys who would rather plug their Teles into a DI box, straight into the console.
    The modellers\simulators like POD and SansAmp, and the various plugins for DAWs also have their place, both in the project studio and in the "real" studios. Lots of modern guitar parts are recorded using one of them.
    Mic-ng a cabinet with an SM57 works well live and in the home\project studio, but it's not the mic most often chosen in the big studios. They'll most often use a MD421, MD441 (dynamic), or an RE20 (condenser), and sometimes Crown PZMs or Brüel & Kjær 49xx-series mics. And they'll often mix and match those mics at different distances from the cone.
