Recently painted a "Fool" SG
Discussion in 'The Custom Shop' started by spikeymikey, Oct 10, 2017.
  1. spikeymikey
    spikeymikey Junior Member
    24
    31
    Oct 7, 2010
    Hello there all. I posted this on one of the other forums here and I thought it might be of relevance within this section. I hope you like it!
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
    jkes01, Lloyd_m, BurstingOut and 14 others like this.
  2. Freddy G
    Freddy G V.I.P. Member
    11,541
    24,436
    Mar 18, 2007
    Nice work. I love it!
  3. HEADKNOCKER
    HEADKNOCKER Banned
    1,123
    630
    Apr 30, 2014
    Me Too! I always wanted to paint a beater SG up like this or convert a Epiphone into one of these..
    Looks Great!!
    Gary/Hk
  4. blackat
    blackat V.I.P. Member
    1,171
    983
    Nov 21, 2010
    Ha. check my avatar....
    Very cool.
  5. bungle
    bungle Premium Member
    2,419
    2,756
    Feb 1, 2011
    Very impressive sir.:thumb:
  6. guitarjoem
    guitarjoem Double Platinum Supporter MLP Vendor
    497
    258
    Dec 15, 2014
    That is gorgeous!
  7. BurstingOut
    BurstingOut Senior Member
    102
    63
    Dec 17, 2016
    Beautiful work !
    Do you mind sharing the details of the process you used?
    Such as what paints you used - acrylics? white gesso?,
    techniques – did you use any masking or all hand painted lines?
    Prepare the guitar surface at all?...clearcoat after?..
    guitarjoem likes this.
  8. spikeymikey
    24
    31
    Oct 7, 2010
    Hi all,
    A collective big "Thank You" to you for these comments.
    I can se that in your avatar Black Kat, it looks good flanked by a couple of cherry ones!
    And BurstingOut, as for the process well, first I stripped the original finish off, gave it two coats of white acrylic primer and sanded the whole guitar china-smooth. This part took quite a while but the body was then ready for the basic drawing which was executed in pencil and the surface needs to be dead flat especially if you want to get the face and hands of the Angel figure delineated well. I prepared a basic blue-print on detail paper of the whole guitar, front, back, neck headstock and then laid the elements of that over the guitar body to mark off key locations of the design. The figure needed to be placed correctly which was made a bit trickier by the fact that the '74 spec SG has a slightly different layout to a '64. Once I'd got a feint impression of where everything went I then hand drew the figure, getting my wife to model the hands and trying to get the facial expression of the Angel as close to the original as possible.
    Once it was all down in pencil I painted everything in acrylic paint with sable brushes trying to paint thinly and build up the colour gradually. I tried to keep the paint, for example, the dark blues very thin to allow the light to pass through the paint surface and bounce back on the high white surface of the primer coat. That way the final colours have more vibrancy and dynamics. I didn't use any masking or paint spraying it was all done by hand. I think being a figure/portrait painter as my job helped quite a bit.
    It was difficult painting the back of the neck due to the curvature of the surface, that took much longer than I expected.
    The guitar is being clear-coated in acrylic now and I'll post more pics when it's assembled. I hope that helps?
    Cheers
    Mike
    BurstingOut and The_Nuge like this.
