Question on caps
Discussion in 'Tonefreaks' started by whomeno, Oct 5, 2017.
  1. whomeno
    whomeno Senior Member
    151
    52
    Nov 21, 2008
    OK where dose the cap go. Seymour duxam has it center post on the tone pot and ground to the tone pot. I see wiring diagrams that has it center post tone pot and input volume pot. Others have it center post tone and center post volume.
    Which is the right one
  2. DarrellV
    DarrellV About as sharp as a bowlin' ball! -NPM Silver Supporter Premium Member
    17,788
    41,184
    Nov 1, 2016
    I can't see what you are looking at, but a tone cap needs to be hooked to the hot, or signal, lead of the pickup it is working for.
    It can be connected to where the pickup lead is soldered to the volume pot. That's fairly common.
    On the other end it usually connects to the center post of the tone pot.
    One outer leg of the tone pot is then soldered to its own case for grounding.
    Wrong leg grounded results in tone pot working backwards. Just unsolder wrong leg from tone pot casing and solder the other one if this happens.
    Tone cap works by siphoning off the higher frequencies to ground. Tone pot controls how much ground is available to the cap.
    That's it...
  3. whomeno
    151
    52
    Nov 21, 2008
    OK on Seymour Duncan's site for humbuckers 2hb 1vol 1 tone and 3 way switch they have cap center post tone pot and grounded to tone pot. I will wire it up like you said thanks
  4. whomeno
    151
    52
    Nov 21, 2008
    here is wha sd has
  5. whomeno
    151
    52
    Nov 21, 2008
    so which one is right? if these are wrong could you post a diagram that is right
    Thanks
  6. whomeno
    151
    52
    Nov 21, 2008
    here is one from stew mac
  7. DarrellV
    17,788
    41,184
    Nov 1, 2016
    They are both correct, but go about it in 2 different ways.
    Electrically they do the same thing, but one has the signal going to the cap then to ground, the other has the signal going through the pot first then the cap to ground.
    Electricity doesn't care since it flows through the whole chain on its way to ground either way.
    Hope that made sense...
    Juan Wayne likes this.
  8. whomeno
    151
    52
    Nov 21, 2008
    so there is no differance in sound between the two correct
  9. Juan Wayne
    Juan Wayne Senior Member
    1,528
    1,515
    Nov 15, 2012
    Correct. As DarrellV said, electricity doesn't care.
    Components connected in series can be put in any order, and all the signal will "see" when going through that path is the total opposition to its flow to ground, which is the total impedance, i.e. the resulting sum of those oppositions, no matter the arrangement.
    DarrellV likes this.
  10. DarrellV
    17,788
    41,184
    Nov 1, 2016
    Thanks for fielding that one !:cheers:
    I just now checked back in because you liked my post.
    I'm trying to encourage people to reply or hit like on my comment to draw my attention back to the topic and know that they left a reply.
    I don't want anyone thinking I'm ignoring them, LOL! :sadwave:
    whomeno and Juan Wayne like this.
  11. Juan Wayne
    1,528
    1,515
    Nov 15, 2012
    Same boat here. I've used the same technique before. The days without the Like Button were dark ones for MLP.
    I still get notifications when I'm quoted though, have been getting them since the interface change, but not everyone replies using the button.
  12. DarrellV
    17,788
    41,184
    Nov 1, 2016
    Works for me! Here i am!:thumb:
  13. whomeno
    151
    52
    Nov 21, 2008
    Thanks for all the help!!
