Question, ES LP to 54 specs ?
Discussion in 'The Custom Shop' started by staffy, Apr 8, 2017.
  1. staffy
    staffy Senior Member
    530
    775
    Jul 16, 2013
    Hi there from oz, i'm wondering if it is possible to convert one of those es lp's with no f-holes into a 54 GT type spec, P90's wrapover tail piece etc and who could do it. Thanks Staffy
  2. ARandall
    ARandall Senior Member
    11,796
    7,188
    Apr 16, 2012
    Gold is a type of paint that will tell you straight away if you've filled any holes.....like from regular t/p studs for example.
  3. staffy
    530
    775
    Jul 16, 2013
    Thanks for that, I didn't take that into consideration at all. I have one '54 RI already and was thinking that a hollow one would be kind of unique, may have to try and get one made.Thanks again.
  4. Riffster
    Riffster Senior Member
    310
    180
    Apr 9, 2010
    Even with wood plugs and the grain filler, sanding filler and primer?
  5. ARandall
    11,796
    7,188
    Apr 16, 2012
    Yep
  6. staffy
    530
    775
    Jul 16, 2013
    not a good look
  7. ARandall
    11,796
    7,188
    Apr 16, 2012
    Luckily its right under the bigsby on mine.....which is why I opted to go for the gold on this guitar.
  8. staffy
    530
    775
    Jul 16, 2013
    Imay have to wait and see if Memphis puts one out(in my dreams) Thanks Randall
  9. Riffster
    310
    180
    Apr 9, 2010
    Yikes,
    The reason In was asking is that I have an all mahogany faded LP that I plan on refinishing on gold and I am filling in some holes in it.
    I will probably still do it but will set my expectations low.
  10. ARandall
    11,796
    7,188
    Apr 16, 2012
    The issue with mahogany will be the sinkage. That pic I showed never had the dowel mark obvious until the finish was starting to cure. Of course the gold is one of the early coats which means you almost need to have your basecoat cured and levelsanded before you apply even the colour.
    There was another goldtop top-only conversion/refin I did at the same time which I knew would have some marks in it. I thought I'd rid the top of most of them, but the same thing happened - this was a relic finish anyhow so there was no issue for me.
