Question about pentatonic fingering
Discussion in 'Guitar Lessons' started by Guitar Rod, Apr 8, 2017.
  1. Guitar Rod
    Guitar Rod Senior Member
    1,438
    688
    May 29, 2016
    How do you do it? For example, in position 2 on the pentatonic scale I do exercises the traditional finger exercise way. Fingering 2-4 1-4 1-4 1-3 2-4 2-4. But in blues people do finger bending and vibrato which is nigh impossible with a pinky, so would it be better to shift fingers so you are using 1-3 1-4 1-4 1-3 1-3 1-3?
    For clarity, my examples are fingers used, not fret position.
  2. LenPaul
    LenPaul Premium Member
    2,914
    3,984
    Jul 13, 2012
    I prefer sticking to use of pinky, pinky doesn't have a lot of strength so it just fret the note
    while the middle & ring on the string behind the pinky do the heavy lifting.
  3. Steven
    Steven Senior Member
    1,085
    803
    Feb 7, 2011
    That's what I do, use 1-3 on most of the notes in the 2nd position minor pent shape. I often play most of my leads in the 2nd position on the G,B,E strings, and where you have your 3rd finger on the G string I instead use my 2 finger as a platform for easier 1-3 on the B and E string
  4. frankv
    14,528
    12,930
    Aug 25, 2011
    You have 4 fingers on that hand. Use 4 fingers. I have had to do it that way because I don't have larger enough hands to comfortably stretch to only use 3 fingers.
  5. SteveGangi
    SteveGangi V.I.P. Member
    30,881
    57,365
    May 20, 2010
    I use all 4 fingers, even though I do have enough reach to get away with fewer. Once you get used to it, it makes it easier.
  6. DotStudio
    DotStudio Silver Supporter
    3,775
    6,747
    Nov 13, 2015
    Be a real badass...
  7. Thumpalumpacus
    Thumpalumpacus Senior Member
    75,170
    182,634
    Nov 28, 2010
    Back the pinky up with another finger or two and you'll bend just fine.
    I usually play 1-finger/1-fret except for more outside stuff.
  8. Guitar Rod
    1,438
    688
    May 29, 2016
    Shapes 3 and 5 especially lend themselves to shifting fingers 1 and 3 or 4 around to do them. Think I'll do them that way and the rest the normal way.
  9. huw
    huw V.I.P. Member
    3,525
    4,743
    Jul 13, 2007
    Why choose?
    Learn both fingerings - they're each useful.
    It's worth mentioning that when you want to expand your scale use from just pentatonics to diatonic scales the "four fingers, one per fret" fingerings will make it a no-brainer to add in the two extra notes.
  10. Guitar Rod
    1,438
    688
    May 29, 2016
    Good to know. And good idea. Thanks!
