Quck connect question
Discussion in 'Pickups' started by filtersweep, Oct 20, 2018.
  1. filtersweep
    filtersweep Senior Member
    1,146
    1,519
    Apr 11, 2012
    i could open the cavities and check- but thought I’d ask here first:
    I have two guitars with 490/498 pickups. One has coil tapping- the other doesn’t.
    Do both use the same connectors- with empty pins on the regular pickups?
    Do both have 4 wire leads- and the same pickups- or do the regular pickups have two wires?
    My assumption is that basically I could not use the same quick connect to move a set of pickups from one guitar to the other.
  2. DarrellV
    DarrellV About as sharp as a bowlin' ball! -NPM Premium Member
    18,355
    43,381
    Nov 1, 2016
    Off the top and you can wait for the pros, but my take on the reason for the QC was to make it easy to do just that.
    Plug and play simplicity. I could be wrong.... My understanding was this was Gibson's way to make it easier for users to do swaps without a lot of effort or complications in wiring.
    The pins make the decisions for what goes where on the PC board.
    Now in thinking about it, the coil tap one has pull pots, right? Could be those coil tap leads go to the switch pot and would have to be unsoldered and hooked together to use as a regular pickup in the other guitar.
    I've also read that those coil tap ones are reverse magnet and wound to be hum cancelling in the coil tap position. Might wind up out of phase in a normal guitar scheme.
    Do you have pics of both cavities, or were you hoping to find out first before opening them up?
    cooljuk likes this.
  3. filtersweep
    1,146
    1,519
    Apr 11, 2012
    I’m traveling at the moment. Opening is probably the best bet. I believe the connectors are likely different- even though the pickups are the ‘same.’
    DarrellV likes this.
  4. cooljuk
    14,856
    20,300
    Mar 12, 2009
    You'll have to check. Gibson has used several types of connectors and, as Darrell mentioned, Gibson guitars with push/pull knobs and quick connect pickups have one pickup reverse wound and reverse magnetic polarity (to keep hum cancelling in the middle position with both pickups in single coil mode). So, it's possible that between the different wiring and different connectors, you have three unique pickups in your two guitars. Simple, right? Haha!
  5. EndGame00
    EndGame00 Senior Member
    887
    496
    Sep 1, 2013
    Gibson seems to be phasing out the quick connect pickups...Ive asked the forum what part number for the five-pin male connector so I could order them and not a single reply given....
  6. cooljuk
    14,856
    20,300
    Mar 12, 2009
    Here. I took a photo of all the Molex and Mouser part numbers for the common ones:
    Personally, my recommendation is to abandon this limiting technology. If you can't solder, it's much easier and more valuable of a skill to learn to solder than it is to learn to crimp these little nightmares. A soldering iron can also be had much cheaper than the crimping tool.
    jeffy and Jymbopalyse like this.
  7. mrdannyboy
    mrdannyboy Senior Member
    723
    718
    Jan 19, 2014
    I move pickups from guitar to guitar sometimes. The boards I have either have 2pin black connectors or 4 pin white connectors.
    You can move the Pick up from guitar to guitar is long as the PCB boards have the same connecters
  8. cooljuk
    14,856
    20,300
    Mar 12, 2009
    ...but if the guitar has push/pull pots and uses the white connectors, than you can only swap neck pickups with neck pickups and bridge pickups with bridge pickups, otherwise your pickups will be out of phase with each other. Not only are the connections different, but the neck and bridge pickups are actually built differently from each other (unlike all other Gibson humbuckers in other guitars and available in the aftermarket).
    See? It's so simple and universal! :fingersx:
    filtersweep and mrdannyboy like this.
  9. mrdannyboy
    723
    718
    Jan 19, 2014
    Cheers be never thought of utilities g a bridge pickup in the next position. It that’s good to know. What would the results be?
  10. cooljuk
    14,856
    20,300
    Mar 12, 2009
    In nearly every other case (especially between 1957-1979) there were no differences at all between the pickups that were put into the bridge and neck positions.
    In those Gibsons with the quick connects and push/pulls, the pickups will likely play out of phase in the middle position if you start mixing bridge/bridge, neck/neck, or stock/aftermarket.
  11. cooljuk
    14,856
    20,300
    Mar 12, 2009
    filtersweep likes this.
  12. jeffy
    jeffy Senior Member
    1,561
    809
    Aug 29, 2010
    I'm kinda surprised that's the case. All that works I did. Hahah! This was the old thread which should have come up in a search. http://www.mylespaul.com/threads/why-5-pu-wires-on-molex-connector-2012-std.210303/
    Honestly though, I'd convert it over to soldered pots. Soldering is a lot simpler and for most people a lot cheaper. Those PicoBlade connectors are really tiny and can be frustrating to crimp. Also the Molex crimper isn't cheap.
