Presonus Air10 FRFR powered speaker any owner or review ???
Discussion in 'Amp Modeling' started by skysc, Aug 24, 2017.
  1. skysc
    skysc Senior Member
    686
    238
    Jun 1, 2013
    So i made a thread a few week ago about a powered FRFR speaker for modeler ( axe fx , kemper , helix , ) .
    After checking the available speakers available with on best buy ( i have a gift card )
    i've realisez that a 10 inch would be perfect for my need ( played in a small room .. no need a more boomy 12 inch ) .
    Id rather have a higher quality 10 inch . The available option for the 10 inch was a Presonus Air10 . no alto or yamaha dxr , ev zlx etc.. are available .
    Now theres not much review of that speaker . I dont lknow much about Presonus except that they make audio interface . Is it a reputable company ??
    the spec sheet is on the website under the AIR 10 . Its a Class D / Class AB powered speaker .
    https://www-media-presonus.netdna-s.../pdf/A_Brief_Tutorial_on_Loudspeakers_web.pdf
    NOw i dont know much about frequencies , class D/Class AB so i cant really read the spec sheet.
    Ive read that it seeem to be very clear power and great quality . but thats only 1 review . i think theres a 5 years warranty on it .
    WOuld you suggest it ???? over Altots212 , EV zlx12p
    Its' 499 $ ( u.s ) . It seeem to be in the range of the YAMAHA DXR 10
    thx
  2. KenG
    KenG Senior Member
    6,269
    3,336
    Sep 13, 2009
    12 inch woofers usually result in a lower crossover frequency because their high freq response falls off at a lower freq. 10's IMO will likely give more of the guitars primary tones in the speaker vs the tweeter/HF driver.
    I would look for acrossover freq well over 2KHz and want a ratio of 1/2 to 1/3 the speakers power amp wattage assigned to the HF driver.
    Rhust likes this.
  3. Rhust
    Rhust Senior Member
    4,878
    2,877
    Jan 9, 2012
    Hadn't seen those, but that's quite a bit considering the alternatives available. Even the Laney IrT-X is less $ and designed to be exactly what you want/need. For that you could get 2 good 8"studio monitors, but I know that's not exactly the same... but for low volume, it is a consideration.
