Power Amp into Traditional Cab
Discussion in 'Amp Modeling' started by hbucker, Jul 6, 2017.
  1. hbucker
    hbucker Senior Member
    3,661
    1,287
    Oct 15, 2007
    For those using a power amp to run their modeler into a traditional guitar cab, what power amp are you using?
  2. cybermgk
    13,620
    18,050
    Jul 7, 2011
    I'm not doing that, but I have tried it with my Matrix gt1000fx. Works fine. I have heard the Rocktron works well. The latter is more powered at what a Guitar CAB can use.
  3. carydad
    carydad Senior Member
    1,472
    364
    Nov 7, 2007
    Many over the years. Pretty wide range-depends what you are looking for. On one end you've got the Matrix type thing that get high praise. On the other end, I've gigged a little magnum44. Something like a quilter or that new Duncan pedal might be cool. The other guitar player in band2 has the 200W quilter. Yes, he blew up a speaker. Sounds killer. I use an old school Crate power block because I am cheap and it sounds good. Not much luck with generic PA power amps. I had a hartke bass amp that I used for power, it was okay. Prefer the power block to that though.
  4. frankv
    14,529
    12,933
    Aug 25, 2011
    My guitar teacher use to use a Quilter power amp... I was so impressed at the time I almost got one.
  5. drew365
    drew365 Senior Member
    1,251
    898
    Oct 23, 2011
    If you use a guitar cab, you will lose the option of IR's, which is one of the coolest tone shapers most modelers have to offer. You could try running IR's with a guitar cab, but my limited experience in doing that was it didn't sound that good.
    frankv likes this.
  6. hbucker
    3,661
    1,287
    Oct 15, 2007
    Understood. This is an option though. Curious to hear responses to the question.
    Thx!
  7. NeubyWanKaneuby
    NeubyWanKaneuby Senior Member
    1,407
    516
    Jun 21, 2008
    I used a Rocktron Velocity 100 with my GSP1101, but sold them both off after I picked up my AxeFX. I only play that direct into my audio interface.
  8. Liam
    Liam V.I.P. Member
    5,951
    2,403
    Nov 19, 2007
    I used a Matrix GT1000FX into a mid 70s Marshall 4 x 12 (G12M30), 1980 Marshall 4 x 12 (G12-65), and Matamp 4 x 12 (Celestion Hot 100) last year. Worked really well, didn't try to drive anything too hard as there was surplus power available. Turning cab modelling off didn't yield particularly great results for some amp models, so I ended up using cab IRs even though it was technically "incorrect". Solid amp, loads of power, drives my current FRFR setup too.
    Liam
  9. Zoobiedood
    Zoobiedood Senior Member
    861
    294
    Sep 1, 2015
    I am awaiting a Duncan PowerStage 170. I tried it out at NAMM and it sounded amazing.
  10. hbucker
    3,661
    1,287
    Oct 15, 2007
    FWIW: I just purchased a used, ss power amp to drive my 212 cab. Certainly, not all models sound good through this cab. (I don't like all of the models anyway, regardless of IR, FRFR, Headphones, Monitors, or Cab.) But several sound really nice.
    With the removal of the IR from a given patch, plus a little tweaking here and there - sometimes no tweaking needed - it gives that "amp is actually in the room with me" feel that I strive for even when I'm using IR's and full range speakers.
    As stated earlier, it's just one more option for sound production with my AX8. This experiment was successful.
    Liam likes this.
  11. TP6
    TP6 Senior Member
    661
    500
    Sep 6, 2014
    My setup isnt super serious but I had an extra cabinet I wanted to drive and I was curious as to how the Atomic would sound in a traditional setup so I ended up getting the EHX .44 Magnum for something cheap to mess with.
    Sure I dont get to run IRs into it (I have them auto disabled on the 1/4" outs anyway) but it still sounds pretty good and convincing enough for me. I have a whole bank I tweaked specifically for power amp and cab use and they sound great. Its been a while since I messed with them cause Ive been on a bit of a playing break but I was getting pretty usable clean, rock and metal tones easy enough. It might not sound exactly like it would with an IR but its still usable and super convinient if I want to jam with buddies and have a simple setup to use.
    Also I agree with the above poster with the 'amp in the room' sound and vibe. Great for that too.
    hbucker likes this.
