potted or unpotted for a 335
Discussion in 'Pickups' started by db3266, Jan 17, 2013.
  1. db3266
    db3266 V.I.P. Member
    2,893
    1,577
    Oct 18, 2010
    Is this decision more sensitive for semi-hollow body guitar?
    Is the best bet to go potted to avoid any feedback issues?
  2. MiniB
    MiniB Senior Member
    4,076
    2,920
    Dec 31, 2012
    I like the upotted Duncan Antiquities in mine and like what unpotted PU's add in general (have them in LPs as well). On the 335, they seem to emphasize more of the 'woodiness' of the guitar as opposed to the more focused sounds of something like '57 Classics. But I also don't play with a lot of gain through high power amps any more, so that could be an issue with feedback.
    What I do for a measure of safety is make sure the cover is down nice an snugly, with a layer of double-stick scotch tape between the slug bobbin and inside. Not as much of a hollow click as you tap the cover once you solder it back on nice and tight. That always helps to take away a little grating from the pick attack, and I can see it maybe helping a little for feedback since you don't have as much of a metallic 'drum head' right over an already more microphonic pickup.
    So I would say a lot depends on your playing setup. I play in live blues/rock situations both small and medium-large...never with massive gain (mostly overdrive when needed). Whenever there's feedback, it's been controllable, but that takes work as well in terms of your hand technique and muting, etc. You can really use feedback as a useful tool if you get it down.
    1 person likes this.
  3. matt@msscguitar
    matt@msscguitar Premium Member MLP Vendor V.I.P. Member
    9,485
    6,259
    May 5, 2008
    Depends who makes the pickups. Some un potted pickups have squeal problems, some makers have zero problems with squeal. IMO, a semi hollow or hollow can be tougher to tame.
    2 people like this.
  4. captcoolaid
    captcoolaid Senior Member
    11,383
    3,858
    Nov 29, 2008
    Potted. Hollow bodies are notorious.
  5. LtKojak
    LtKojak Senior Member
    3,871
    2,483
    Aug 26, 2009
    I have both my 335s loaded with unpotted p'ups (ECP RD-59s and Antiquity HBs) and no problems with squealing whatsoever.
    The point is: with unpotted p'ups, if they squeal, you're using too much gain.
    As simple as that.
    5 people like this.
  6. db3266
    2,893
    1,577
    Oct 18, 2010
    My pickups of choice at the minute are going to be either the ECP RD59 low winds or Bare Knuckle Stormy Monday's. Both winders are top notch, so I guess the squeal issues will be less so with top shelf pickup winders.
  7. Bigneil
    Bigneil Senior Member
    696
    610
    Mar 8, 2011
    I have heard of people packing foam or sponge into the pickup cavity. Presumably it helps to reduce feedback.
  8. cooljuk
    cooljuk Transducer Producer Premium Member MLP Vendor
    12,896
    14,844
    Mar 12, 2009
    I've seen my Creme Brulees (second hottest set I wind) played in a 335 through a Twin at FULL TILT and with a treble booster indoors in an open room with hardwood floors. Only musical sustaining feedback. No coil or magnet squeal.
    It's all in the wind and assembly.
    2 people like this.
  9. Quill
    Quill Senior Member
    4,548
    3,034
    Sep 15, 2009
    NOT just the assembly. The hands of the player have a little something to do with it.
    Yeah! fuk yeah! You find that point where the guitar just starts to vibrate, get the gain and the volume just so, and ride that edge between clean and scream - it's the reason we play these guitars.
    As a kid, I had my 335 with a pretty hot, unpotted humbucker in the bridge, a fantastic 50w or 60w Hiwatt head (forget now) and a borrowed cab with two 15" speakers in it. And I just played around with the gain until it started to do what I wanted. Experienced players would come up to me and demand to know what kind of overdrive pedals I was using ... they'd get so pissed off when I said, my hands and the volume knob on the guitar.
    The unpotted pickup was absolutely key to the sound. Well - to my sound. It should at least be tried. Once the wax is in there, you can't take it out ...
    And yes, it's totally true - the pickup's gotta be good.
  10. ezra1
    ezra1 Senior Member
    868
    586
    Mar 20, 2009
    I like that story Quill !
  11. cooljuk
    12,896
    14,844
    Mar 12, 2009
    Here's some LOUD unpotted goodness.
    [ame=http://www.youtube.com/watch?v=LBfLE8wWTaI]ReWind Electric - Crème Brûlée Set - Lex SG through a Twin - YouTube[/ame]
    2 people like this.
  12. MiniB
    MiniB Senior Member
    4,076
    2,920
    Dec 31, 2012
    Was that a dimed Twin Reverb or Tweed Twin? Sounded pretty badass.
  13. Mouse
    Mouse Senior Member
    2,626
    3,785
    Nov 2, 2008
    here is 330 which have unpotted single coil pickups, can be notorious with feedbacks, cured with some foam beneath soundholes.
    with 335 and unpotted paf style should be more than ok
    [ame]www.youtube.com/watch?v=ClHMjnhW9Gc[/ame]
  14. cooljuk
    12,896
    14,844
    Mar 12, 2009
    Twin clone. Thank you. If my memory serves me right, that's forum brother Lex, playing either an LP or SG with Creme Brûlées.
  15. cooljuk
    12,896
    14,844
    Mar 12, 2009
    Are those your winds? They sound like it. A4s?
  16. MiniB
    MiniB Senior Member
    4,076
    2,920
    Dec 31, 2012
    So a 5E8 (that 2x12 cab in the video)? Pretty gnarly-sounding.
  17. cooljuk
    12,896
    14,844
    Mar 12, 2009
    I think so. I'll check back on my old PMs tomorrow if I have time. Could always ask Lex, too. He and I talked about that gear a bit because I really loved it.
    Of course, there's a treble booster in there and the Creme Brûlées add a good bit of compression and midrange harmonics.
  18. Mouse
    Mouse Senior Member
    2,626
    3,785
    Nov 2, 2008
    yeah sound might be common, but no, those are original P-90's in the original guitar.
  19. nicolasrivera
    nicolasrivera Senior Member
    19,562
    10,592
    Dec 3, 2008
    I agree with this, but i always wondered how the hell did Gary Moore managed to have so much gain and power out of those vintage unspotted PAFs.
    Any ideas?
  20. lespaul01
    lespaul01 Banned
    16,929
    16,578
    Mar 12, 2011
    What is a spotted PAF?
    2 people like this.
