Post Guitars You Built
Discussion in 'Luthier's Corner' started by Knarbens, Dec 21, 2008.
  1. mux164
    mux164 Senior Member
    2,629
    1,888
    Sep 1, 2012
    IMG_7610.JPG IMG_7612.JPG Latest one and a family photo
  2. Darell
    Darell Member
    83
    50
    Jan 22, 2014
    Thanks to all the people on here that post their builds; I wouldn't have been inspired to try this. This is my first build. I started with a Pit Bull Explorer kit. I routed the body and fretboard for binding and routed the fretboard for block inlays to replace the dots. I split the 12th fret inlay to cover the two dots. I made the nut from a blank, re-wired a pair of Epi Probuckers to two conductor, used vintage push back wire, Gotoh bridge and stop tail and Switchcraft jack and switch. I wanted to do a laminate on the headstock but ended up painting it black instead. I learned how to use a router, install binding, remove and replace fret wire and made a fret wire bending jig. The kit was good quality to me however there is no neck angle. I should have made it 3 degrees with a shim or trimming because when I assembled it the string height was way too high even with bridge all the way down on the body. I ground the bottom of the bridge a few mm and it plays fine now. IMG_0665.JPG IMG_0666.JPG IMG_0685.JPG IMG_0692.JPG IMG_0702.JPG IMG_0720.JPG IMG_0758.JPG IMG_0839.JPG IMG_0840.JPG IMG_0845.JPG IMG_0849.JPG IMG_0850.JPG Gonna do an SG in sea foam green with a maple fretboard next.
    Darell
    shickma0, SeanHeffer, DRF and 8 others like this.
  3. guidothepimmp
    guidothepimmp Senior Member
    590
    549
    Sep 8, 2012
    apologies for all the pics. a tele style i done from a couple of planks and a big ol piece of ash. turned out ok, took me forever to get the fret work to where it should be
    20141229_144408.jpg 20140426_101910.jpg 20150112_145135.jpg 20141230_105745.jpg 20150116_123503.jpg 20150124_115249_zpsn2vxmobd.jpg 20150131_101705_zps20r5wemp.jpg 20150221_142649_zpsfnpeuhbk.jpg 20150228_131852_zpsei1cx3sk.jpg 20150307_123750_zps87rjvf8a.jpg 20150307_231435_zpslglkixe2.jpg 20150308_093900_zps0biwrpwx.jpg
    dcomiskey, Zeegler, 61LPSG and 6 others like this.
  4. Esel
    Esel Member
    66
    91
    May 13, 2013
    Just jumped off the bench.
    Purple Raincaster.
    Redesigned Harley Benton TE-30 (45$)
    Quilt Veneer, Eastwood P90, Binding, new Dots.
    downloadfile-1.jpeg downloadfile.jpeg downloadfile-3.jpeg downloadfile-2.jpeg
    Alex Dovnar, El Pablo, saks and 4 others like this.
  5. Esel
    Esel Member
    66
    91
    May 13, 2013
    Absolutely stunning beauty:applause:
  6. guidothepimmp
    590
    549
    Sep 8, 2012
    cheers Esel
    very kind of you
  7. Skyjerk
    5,853
    6,880
    Feb 9, 2014
    Looks great :)
    Good job working a solution for the neck angle. I actually built the bridge on my 22 Special that way on purpose. I like the bridge low.
    I find a tall bridge and tall rings to be visually unappealing, and from a playing perspective not real ergonomic (for me).
    My personal opinion is also that a tall bridge can be less stable over time (leaning) and will not conduct vibration as well
    as a low, more solid bridge.
    I didnt grind the bridge though. I planned the neck angle so that the bridge would be low with the bottom of the bridge just barely
    above the wood, and I counter-sunk the posts. Worked out perfectly.
    archey, mux164 and KnightroExpress like this.
  8. j.six
    j.six Senior Member
    2,244
    1,749
    Aug 22, 2008
    This one should go home today; I'm waiting on a replacement Pigtail wraparound.
    '71 Trella for Stevie D (Buckcherry/Josh Todd and the Conflict)
    Mahogany body/maple cap, mahogany neck/ebony board
    Stainless steel frets, 12-16 compound radius
    Paint/relic work by Billy at Rock N Roll Relics.
    Good times!
    Sully
  9. Skyjerk
    5,853
    6,880
    Feb 9, 2014
    For those that might not remember, I built this guitar in memory of my firstborn son Chris who passed away Feb 18, 2017. He was 24 years old
    Its called "Phoenix"
  10. archey
    archey Senior Member
    1,005
    848
    Nov 28, 2010
    Chris, you did a great job. That's a awesome tribute.
  11. fatdaddypreacher
    5,789
    3,798
    Feb 5, 2011
    as one might expect.....absolutely stunning. the style, the colors, and as usual, the execution. I pray you get a sense of peace everytime you see it, and for sure when you play it. well done, sir.
  12. 61LPSG
    61LPSG Senior Member
    1,682
    442
    Oct 31, 2007
    Chris,
    Beautiful work as always, and a wonderful tribute.
    Nothing can undo your loss, but with time I hope that you will remember the good times more than the loss.
  13. Darell
    Darell Member
    83
    50
    Jan 22, 2014
    Very, very nice!
  14. D Rhinehart
    D Rhinehart Senior Member
    274
    129
    Dec 13, 2011
    Here is a 24 fret Bass I built a few years ago Cocobola and Roasted Flamed Maple with Ebony board with Flamed Maple blocks , Ken Smith pups , bridge and 18v circuitry sorry for so many pics !
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    lowatter, cmh6122, 61LPSG and 4 others like this.
  15. Skyjerk
    5,853
    6,880
    Feb 9, 2014
    That looks delicious!
    It sounds delicious too, for that matter. Sounds like a tasty dish on the menu of a fancy restaurant :)
    "Cocobola and Roasted Flamed Maple chutney with Ebony board with Flamed Maple vinaigrette"
    D Rhinehart likes this.
  16. mux164
    2,629
    1,888
    Sep 1, 2012
    IMG_7877.JPG IMG_7879.JPG This fella has a new owner, it's a shame I kinda wanted to keep it
    cmh6122, Esel and fatdaddypreacher like this.
  17. KnightroExpress
    KnightroExpress Senior Member
    1,392
    1,413
    Sep 5, 2013
    I already posted pics of this guitar, but it ended up in a music video (guy to the far right), so I figured I'd share :)
    mux164 likes this.
  18. fatdaddypreacher
    5,789
    3,798
    Feb 5, 2011
    cool, dude. congratulations
    KnightroExpress likes this.
  19. dcomiskey
    dcomiskey Senior Member
    164
    76
    Sep 19, 2016
    That's SO cool, Knightro! Although....where did they plug in?? :D
  20. Skyjerk
    5,853
    6,880
    Feb 9, 2014
    Sweet. Thats very cool :)
    I liked the song but it was lacking a phat guitar solo :)
