Post Guitars You Built
Discussion in 'Luthier's Corner' started by Knarbens, Dec 21, 2008.
  1. KnightroExpress
    KnightroExpress Senior Member
    1,387
    1,370
    Sep 5, 2013
    It's as much protection as any other oil I've tried...so not a whole lot, but that's just how it goes with oil.
  2. KnightroExpress
    1,387
    1,370
    Sep 5, 2013
    While I'm on a multi-8 roll, here's another!
    Voyager MS8
    26.5-28" multiscale 8 string
    Padauk body with wenge top
    Wenge neck with padauk accent lam
    Ebony fretboard, 20" radius
    Jescar 47095SS fretwire
    Bare Knuckle Nailbomb set with ceramic bridge
    5-way rotary switch (bridge series, outer coils parallel, outer coils series, inner coils parallel, neck series)
    Hipshot hardware
    cmh6122, mux164, 61LPSG and 3 others like this.
  3. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,199
    860
    Nov 29, 2012
    DAYUM!
    Thats sweet Andrew.
    Well both are sweet, but too many strings for me to know what to do with. I can barely play 6.
  4. Ripthorn
    Ripthorn Senior Member
    1,435
    1,100
    Mar 7, 2014
    That sappy paduak is the best!
  5. 61LPSG
    61LPSG Senior Member
    1,677
    434
    Oct 31, 2007
    That Paduak is just crazy ....gorgeous.:cheers2:
  6. jack briggs
    jack briggs Senior Member
    581
    596
    Mar 7, 2008
    Cold Duck Time (Heather Mist):
    Thanks for looking!
    cheers,
  7. Satellitedog
    Satellitedog Senior Member
    563
    81
    Mar 13, 2014
    Usually I'm torn when I see a new Jack Briggs guitar, because as much as I love the high quality of the craftsmanship, I'm not a fan of the headstock design.
    This heather metallic semi however is just so bloody cool I cannot but admire it.
    Brilliant job.
  8. Dr.K
    Dr.K Junior Member
    26
    186
    May 11, 2013
  9. j.six
    j.six Senior Member
    2,242
    1,734
    Aug 22, 2008
    Finished this Raven up the other day. If any of you are going to Summer NAMM, it'll be at the Boutique Guitar Showcase.
    Black limba body and neck, angel step maple top, Richlite fretboard (experiment guitar), stainless frets, etc.
    Sully
  10. KnightroExpress
    1,387
    1,370
    Sep 5, 2013
    The padauk Pulsar is done!
    Specs-
    Padauk body and neck
    Cocobolo fretboard, headplate, and accent laminates
    24.5" scale, 24 stainless frets
    Mojotone Hot Classic PAFs with A4 mags
    Pinnacle bell brass Tune-o-matic
    Hipshot locking tuners
  11. Manton Customs
    Manton Customs Senior Member
    137
    204
    Oct 27, 2013
    Haven't posted on here for a while, but just finished this one up so thought I'd share.
    Manton Customs Origin Green Les Paul (6).JPG Manton Customs Origin Green Les Paul (9).JPG Manton Customs Origin Green Les Paul (2).JPG
  12. Ripthorn
    1,435
    1,100
    Mar 7, 2014
    Gorgeous! What type of neck tenon did you use?
  13. distorted_tom
    distorted_tom Junior Member
    1
    1
    Aug 17, 2010
    My most recent build
    cmh6122 likes this.
  14. madvic
    madvic Junior Member
    1
    5
    Jan 29, 2011
    Hello, this is my first post here, please bear with me...
    Since this is a "Les Paul" forum, I thought I could post my attempt at building one.
    I call it "Les Diaz" since Diaz is my name. Never mind the "brand" name (Lagui), that's something that looked cool 10 years ago.
    Actually I have an original Les Paul case since 30 years ago and I wanted to fill it with a decent guitar, so I decided to build this one. I had some material lying around and some plans, so there we go.
    The guitar body is made from "Jatoba", a tropical wood which is quite heavy and resonant.
    I chambered it as much as I dared to, still, this is a heavy guitar: 6 kg.
    On top of the Jatoba body I dropped a carved maple top made from 3 pieces.
    The neck is 3 pieces made with maple and rosewood (the center stripe is actually an accoustic side blank!). I am not good at scarf joints so I prefered to use the more robust three pieces approach.
    Hardware is Gotoh or similar, no fancy stuff there, and the pickups are modern Gibson Brustbucker Pro.
    The finish is an "accident": it started as a sunburst, I lay down the base color, though about it and decided to keep it as it was. Actually most of the color comes from the clear coats which were not so clear :)
    I must say that this build was surprisingly easy, I didn't have real plans, just extrapolated from some Internet-found drawings. So probably the dimensions aren't fully correct.
    Anyway the result has been fantastic, great playability and sound, lot's of punch and sustain. I can also use it for soft sounds like subtle saturations in Blues or Jazz environments.
    DSCN0018.JPG DSCN0033.JPG DSCN0031.JPG IMG00091-20111226-2132.jpg IMG00090-20111226-2132.jpg IMG00092-20111226-2133.jpg
  15. Manton Customs
    137
    204
    Oct 27, 2013
    Thank you. It's a standard long tenon, except with an extra mating face at the back...if that makes sense!
    cmh6122 likes this.
  16. bhmcintosh
    bhmcintosh Les Pauls, Telcasters, and 12strings Premium Member
    384
    231
    Apr 20, 2009
    *sigh* You're killin' us, Jack! Every time you post build pics not ONLY do the rest of us want to set fire to our shops sell our tools on eBay, but the magnificent pics you take OF those builds have us all throwing our cameras into the nearest convenient large body of water! Gorgeous gorgeous gorgeous! :thumbs:
  17. jack briggs
    581
    596
    Mar 7, 2008
    (In a most Mrs. Doubtfire type accent) Oh, Heavens! I should think that I'm not doing my job properly, then! My aim is to inspire, not deflate! As I have been inspired by so many over the decades, I only hope that others may too find inspiration to try things outside of their comfort zones. As for the photography, a $500 Nikon helps - as does the $500 studio setup (and tripod). Composition and clarity play a large part, but, what it all really comes down to is "lighting, lighting and lighting!"
    Thanks very much for the comments!
    cheers,
    bhmcintosh likes this.
  18. Kinghat
    Kinghat Senior Member
    196
    236
    Jan 11, 2013
    Here's the third Kinghat Rocket. Still tweaking the design slightly each time. Swamp ash body, McNelly Cornucopia humbuckers, RS Guitarworks 500k superpot, Hipshot bridge
    cmh6122 likes this.
  19. KnightroExpress
    1,387
    1,370
    Sep 5, 2013
    The first Wayfarer MS6 is done! Look for it on stage over the next few weeks with Jeremy Smith of Like Moths to Flames :metal:
    Specs-
    Black limba body w/ ziricote top and ivoroid binding
    Wenge neck w/maple laminates
    Pale moon ebony fretboard w/Jescar 58118SS wire
    25-26" multiscale
    Hipshot 18 degree bridge and open-gear locking tuners
    Elysian Pickups hot modern bridge (Alnico/ceramic hybrid), modern neck (A4)
    IMG_20170724_183426.jpg IMG_20170724_183548.jpg IMG_20170724_183601.jpg IMG_20170724_183655.jpg IMG_20170724_183706.jpg IMG_20170724_183717.jpg IMG_20170724_183729.jpg IMG_20170724_183832.jpg
    JayDee80, cmh6122, Frack and 2 others like this.
  20. mux164
    mux164 Senior Member
    2,597
    1,823
    Sep 1, 2012
    Awesome guitar once again, love the scarf joint and the laminations
    KnightroExpress likes this.
