Possible issues with my new Les Paul
Discussion in 'Gibson Les Pauls' started by Dr.Tj, Jan 11, 2019.
  1. Dr.Tj
    Dr.Tj Member
    38
    77
    Mar 4, 2016
    I love my new traditional '18. I have some questions/possible issues.
    1: does the toggle switch get loose over time and starts rotating? I found that mine got loose even after tightening and the switch ring won't even stay aligned and keeps moving.
    Even the pointers on the pots are a little loose and I don't have a wrench that will get in there.
    2: The volume/tone knobs are acting weird. There is no effect on volume/tone at pointer level 1. Faint noise can be heard when the volume knob is at 1.5 but it's doesn't have any character/sounds like it has a loose connection or something. A nice rolled off volume can be heard at 2 position on the pointer. Is something wrong with my pots? Also there's some cracking before I turn it off completely.
    3: What are some 'first' OD/Distortion pedals that you recommend for a nice smooth drive?
  2. wilmacat16
    wilmacat16 Junior Member
    27
    12
    Aug 18, 2017
    1. Over time that has happened to my various guitars, but tightening it properly usually helps. The one time it didn’t (not on a les Paul; an epiphone) my repair person put a washer on to hold that in place. However, I’m not sure if that’ll be a one size fits all solution.
    2. I’m not sure I understand. You’re saying that when you roll the volume all the way down, there is no volume?
    3. For a “first” more affordable OD, I’d say EHX Soul Food (Klone), or an east river drive (tube screamer copy for a good price).
  3. Dr.Tj
    Dr.Tj Member
    38
    77
    Mar 4, 2016
    No... Suppose you rolled the volume all the way down. Try to open it up till the pointer says 1 on the knob. There's still no sound. A little sound can be heard when i get between 1 and 2 a dull sound is there. On 2 it sounds the way it should... Does it make any sense?
  4. Jymbopalyse
    Jymbopalyse Senior Member
    2,966
    6,218
    Oct 3, 2016
    1. wilmacat16 covered that well. Just tighten the screw.
    2. If there is something wrong, you probably got a bad pot. On two separate occasions I have been trying out LP's at the guitar store and a pot just spun round-and-round. Buddy at the store, seemed unphased by the finding.
    Perhaps try some deoxit to clean the pot up.
    It really shouldn't need it, but like I said earlier, it could also be a bad pot.
    3. What to get for a first OD. What kind of amp are you going through ?? If you are like me, and have NO IDEA where to start looking. Pick up a cheap one, any one, used even. At least you will now have something to compare to, and have an opinion on what you want different.
  5. Jymbopalyse
    2,966
    6,218
    Oct 3, 2016
    I have a feeling that this is the way it actually works.
    The Trad will have 50's wiring. I think what you are describing is normal.
  6. tzd
    tzd Senior Member
    5,700
    3,566
    Oct 21, 2011
  7. Sinster
    Sinster Senior Member
    11,552
    8,431
    Jul 5, 2008
  8. wilmacat16
    27
    12
    Aug 18, 2017
    I was going to say, I had a 2017 tribute and it has a little needle thing over the knob, the name of which I have no idea, that shows you exactly what number you are on and as far as I can remember (I no longer have it so I can’t check), it did not go below 1.
    mudface likes this.
  9. Dr.Tj
    Dr.Tj Member
    38
    77
    Mar 4, 2016
    I'm running it through a Laney CUB12R I don't find the natural drive heavy enough for me. Well for reference, I wanna go from Guns N' Roses to Metallica heavy. I just wanna sound good to be honest...
  10. wilmacat16
    27
    12
    Aug 18, 2017
    I run the risk of sounding like an idiot but I’m fairly sure it doesn’t go below 1. I mentioned above I vaguely recall this being the case on a tribute I had previously. I’ve since sold it but to be honest I never really look at the numbers when raising or lowering the volume...
    mudface likes this.
  11. Jewel the Sapphire
    Jewel the Sapphire Senior Member
    406
    518
    Jun 8, 2018
    You should get the octotool from music nomad its a much better tool for the money than the cheap metal one posted here
    I have nothing to say about 2 and 3 good luck :io:
  12. Dr.Tj
    Dr.Tj Member
    38
    77
    Mar 4, 2016
    Turned off.
    No sound. Not even with a cranked amp.
    Faint sound
    Now i think it is supposed to be this way only because it happens to both pots but I just wanna be sure.
  13. Gibsonrocknroll
    Gibsonrocknroll Silver Supporter
    2,124
    1,191
    Jul 10, 2010
    I use a Allparts Toggle Switch Wrench. It works well $7.00. As for an overdrive I think the Fulltone OCD and the Boss OS-2 Overdrive/Distortion are good pedals.
    Rob the Photog and Duane_the_tub like this.
  14. Roxy13
    Roxy13 Senior Member
    4,348
    15,301
    Dec 27, 2017
    I have one, too. It's a handy little thing.
  15. Dash
    Dash Senior Member
    107
    89
    May 31, 2012
    Pull the knob off, slightly loosen the nut, and move the pointer to where you want it to be. Carefully tighten the nut while holding the pointer in place. It may rotate when you turn the nut. It is also wise to hold the pot in the control cavity while tightening if possible.
    Jewel the Sapphire likes this.
  16. wilmacat16
    27
    12
    Aug 18, 2017
    Wow I’ve honestly never notice there is a 0. My bad. My current Les Paul has HP knobs - no numbers. Try moving the knob to align it correctly?
  17. gball
    gball Senior Member
    616
    533
    Feb 23, 2016
    Yah, pretty much normal. Best advice I can muster here is to adjust the knobs with your ears and not your eyes - the numbers can be deceiving. I am frequently much, much lower on the volume knobs than I would have guessed (like, at 2 on the knob when I coulda sworn I was in the middle somewhere).
    bulletproof likes this.
  18. ehb
    ehb Chief Discombobulator Gold Supporter Premium Member
    27,263
    123,954
    Feb 20, 2013
  19. Duane_the_tub
    Duane_the_tub Senior Member
    2,107
    3,608
    May 31, 2015
    +1 on the OCD. You'll fall in love with it and keep it for life, which is more than you can say for most objects and pretty much all people.
    Never turn anything on a Les Paul down past 6, it's bad for the guitar.
    I forget the first issue. Tighten something.
  20. ARandall
    ARandall Senior Member
    12,462
    8,076
    Apr 16, 2012
    Knobs are mass produced with the numbers at even gaps between figures. Pots are not all the same, and it all depends on the pickup and internal wiring as to what each number represents. It is up to you to learn your guitar and what it does at each volume level - I can't count the amount of variance I have had in tone and drive fitting even the same 2 pickup in various guitars.......
    Crackling on the other hand is something that should really not happen in a new pot.
    mudface likes this.
