Poly checking on a 71 LP ? pics, opinions wanted
Discussion in 'Luthier's Corner' started by judson, Feb 11, 2019.
  1. judson
    judson Senior Member
    3,501
    4,033
    Jan 26, 2016
    so this morning im playing a 71 lp project i bought a few months back and look down and see the sun is hitting it and a ton of spider checking is there but not even, more just in sections.
    the seller i bought it from said it was stripped and coated in polyurathane.. i thought poly would not crack like nitro?
    i wanted to lightly sand this sheen off and maybe give it a clear coat of laquer and leave it alone..there are parts that are already dull but others still have a sheen to it
    there are other issues that need addressing ahead of the finish but i was somewhat surpised at all the very fine checking that isnt really noticable from 4 feet away just if you look close...:dunno:
    if i sand with extra fine grit to knock the sheen off, will the checking leave? nothing on the back at all just the top looks like he put the poly on
    your thoughts are appreciated...thanks
    IMG_20190210_094117990.jpg IMG_20190210_094555524.jpg IMG_20190210_094521281.jpg
    endial likes this.
  2. warprider
    warprider Senior Member
    376
    389
    Jan 31, 2011
    Dude. Leave it. It looks fantastic.
    mdubya, smk506, judson and 5 others like this.
  3. BPW666
    BPW666 Senior Member
    268
    198
    Jul 27, 2012
    Yeah me likey too, leave it love it.
    Ben
    judson and Nick-O like this.
  4. Heppe
    Heppe Senior Member
    597
    254
    Jan 14, 2011
    Yes! Looks great as it is:applause:
  5. Rocco Crocco
    Rocco Crocco Senior Member
    6,824
    8,307
    Feb 8, 2013
    If he truly refinished it in poly, it wouldn't check like that.
    BrianB, judson and Who like this.
  6. stp
    stp Senior Member
    126
    58
    Jun 3, 2015
    poly does not check.
    judson likes this.
  7. rockstar232007
    rockstar232007 Senior Member
    16,207
    12,771
    Jun 28, 2008
    Actually, depending on how thin it is applied, it can most definitely check.
    I've had vintage, poly-coated guitars, that looked just like that.
    smk506, judson and larryguitar like this.
  8. B. Howard
    B. Howard Premium Member
    602
    519
    Apr 19, 2014
    Most modern poly will craze like that when the maximum coating thickness is exceeded, so it was likely put on much too thick....
    Overs-paraying with lacquer or anything else will not make the crazing disappear and may in fact make it stand out more by turning the cracks either white or black.
    judson likes this.
  9. Dilver
    Dilver Senior Member
    1,070
    1,615
    Apr 26, 2011
    lots if people pay for checking like that... be happy with it.
    judson likes this.
  10. endial
    endial Senior Member
    2,554
    2,453
    Oct 23, 2014
    IF it's the case he stripped it, he my have neglected to wipe it down with lacquer thinner or acetone, leaving traces of the lacquer on the wood. Poly over light areas that still have lacquer might just do something like that.
    Edit: It DOES look really cool. So-
    judson likes this.
  11. lunchbox
    lunchbox Senior Member
    7,191
    10,129
    May 29, 2011
    I’ve had poly chip off and separate from the body in bubbles (late ‘70’s Matsumoko Vantage VS650), but I’ve never seen it check like that. I don’t believe that is poly.
    judson likes this.
  12. charlie chitlins
    charlie chitlins Senior Member
    3,000
    2,600
    Feb 8, 2011
    As it was explained to me buy a serious plastics guy, the molecules in plastic line up in long, straight chains.
    That's why some plastics, like candy wrappers, tear easily in one direction, but not the other.
    The only poly "checking" I've seen is long straight lines all going in the same direction.
    There was a custom painter I knew who did "crackle" paint jobs where the top coat would crack in all directions and reveal the bottom coat.
    I think this was done with synthetic/plastic-based paints.
    Whatever it is....as said...leave it. It looks great!
    judson likes this.
  13. malcostuart
    malcostuart Senior Member
    452
    156
    Aug 14, 2009
    it's gained character ! love it. it's just what I'd like on a gold top, or any other actually. thanks for the eye candy !
    judson likes this.
  14. malcostuart
    452
    156
    Aug 14, 2009
    in fact, a picture of the full body would be really appreciated, please ?
    judson likes this.
  15. judson
    3,501
    4,033
    Jan 26, 2016
    thanks for the coments,
    so if i lightly sanded and coated with laquer i was hoping thr checking would come thru more maybe??
    as you really dont see the checking from 2 or 3 feet away like in this pic
    i took the picguard off to see underneath is the second pic
    i think it was a cherryburst before from looking in the cavity, pots date late 1970
    neck binding removed and sanded thin, refret cuts my finger bad, toggle holes suck but plays great ....
    it has other issues i need to adress first as i mentioned but the checking caught my eye
    yesterday
    IMG_20180907_095216855_HDR[1].jpg IMG_20190210_094430376_HDR.jpg IMG_20190210_093951561_HDR.jpg
    endial likes this.
  16. WhiteEpiLP
    WhiteEpiLP Senior Member
    1,392
    1,030
    Nov 29, 2012
    Maybe test in a pick up route or under the switch chip, put a drop of acetone on it an see if it softens the finish. If it is poly acetone wont do anything to it but if it is nitro it will soften it. Tread carefully though cause if it is nitro and you get the acetone anywhere you dont want it your gonna have a bad time.
    judson likes this.
  17. judson
    3,501
    4,033
    Jan 26, 2016
    thats a thought but maybe just a light sanding under the rings or pokerchip....
    i know what acetone can do as i use it too often really some would say :)
    its gonna take time to get all the other issues straightened out before i put any serious concern into the finish but it was something i just discovered and i bought this a few months back...yes its sort of cool...
  18. elephantrider
    elephantrider Senior Member
    3,143
    3,141
    Oct 23, 2015
    man, that this is sexy. wouldn't do a thing to it.
    judson likes this.
  19. malcostuart
    452
    156
    Aug 14, 2009
    :slap:Thanks for the extra uploads, they only go to show just what a beutiful colour that top is ! So unique. The only alterations I'd do to that guitar is put some cream P90s replacement pups in. Maybe it's still a good guitar even if painted green or red but the top just wouldn't be the same. It's a unique colour , a one of a kind, things like that aren't manufactured. Just keep it clean and play it often. Thanks again:acoustic:
    judson and warprider like this.
  20. charlie chitlins
    3,000
    2,600
    Feb 8, 2011
    So...you're thinking about risky things to do to your guitar so your checking can be seen from further away.
    Is that accurate?
    warprider likes this.
