Pickup makers wiring diagrams.
Discussion in 'Pickups' started by captcoolaid, Dec 9, 2011.
  1. captcoolaid
    captcoolaid Senior Member
    11,415
    3,906
    Nov 29, 2008
    I thought it would be a great idea if we as winders put our diagrams up here with a color code explanation for members and for those needing a diagram when we are not available. So winders post your stuff. Please no sales stuff just the info.
  2. captcoolaid
    11,415
    3,906
    Nov 29, 2008
    For MHD pickups my color codes are as follows.
    Screw side
    Black = Start
    White = finish
    Slug side
    Red = Start
    Green = finish
  3. SKATTERBRANE
    SKATTERBRANE Banned
    21,435
    12,367
    Nov 26, 2008
    Mine is simply Gibson:
    Just like a car battery, Red = hot. Black = ground. The white and green tie the two coils together.
    Oh and, I also use Gibson as a reference here:
    Superswede and HOT-BRIT like this.
  4. darren.mcc
    darren.mcc Senior Member
    191
    23
    Feb 21, 2011
    Quickest sticky ever!!!
    HOT-BRIT likes this.
  5. fuelie
    fuelie Senior Member
    759
    768
    Nov 22, 2011
    My stuff is the same as Gibson and I always orient North side to the slugs.
    Slug North start = red
    Slug North end = white (tied to green unless splitting)
    Screw South finish = green (tied to white unless splitting)
    Screw South start = black
    Fancy printed diagrams are not finished yet. :)
  6. Zhangliqun
    Zhangliqun Senior Member
    1,598
    752
    Apr 10, 2007
    My 4-conductors just duplicate the Duncan code.
    My Splat humbuckers are:
    White = hot
    Red = Splat
    Black and bare = ground
    (IGNORE THE GREEN LEAD)
    The Splat code also applies to my tapped P90's.
    You will occasionally see P90's from me with a black, white and bare (ignore red & green) because the customer wanted to be able to flip the P90 out of phase, or because I couldn't guarantee it would be in phase with the other pickup in the customer's guitar so they could reverse the leads if they were out.
  7. jamman
    jamman Premium Member
    9,239
    7,470
    Oct 1, 2010
    Thanks to all of you guys . Great info to have .
  8. HOT-BRIT
    HOT-BRIT V.I.P. Member
    20,979
    16,550
    Aug 17, 2010
    thank you for sharing
  9. copperheadroad
    copperheadroad Senior Member
    1,335
    536
    Feb 8, 2010
    I always went with the Duncan color code
  10. cooljuk
    14,428
    19,061
    Mar 12, 2009
    Mine are pretty easy.
    Shield = ground
    Core = hot
    I highly recommend 50's wiring, 500-550k quality pots, and high quality caps with my pickups.
  11. Lowdown
    Lowdown Senior Member
    3,776
    2,344
    Dec 10, 2009
    This is what I want to see added as well. As not all mags are positioned equal,so to say :naughty:
    It's very annoying when swapping out mags,only to find...
    On some,North is oriented away from the slugs.
    Great sticky. Much needed. Thanx all :yesway:
    2 people like this.
  12. cooljuk
    14,428
    19,061
    Mar 12, 2009
    On mine North is always towards the slugs, as well. If a customer requests a flipped magnet, it will be the neck that gets the flip.
    1 person likes this.
  13. Zhangliqun
    1,598
    752
    Apr 10, 2007
    How do I put a diagram in here without having to pay $50 a month for a hosting service?
  14. cooljuk
    14,428
    19,061
    Mar 12, 2009
    Host the file on your own web server or Photobucket and use the [​IMG]
  15. Zhangliqun
    1,598
    752
    Apr 10, 2007
  16. cooljuk
    14,428
    19,061
    Mar 12, 2009
  17. jonesy
    17,190
    4,411
    Mar 28, 2008
    The Sheptone 4 conductor leads are the same color codes as Gibson uses...
  18. smorgdonkey
    smorgdonkey Senior Member
    2,093
    1,435
    Jan 26, 2009
    I hate the way that most 5 way switch diagrams are shown...they tend to mean nothing in relation to the 5 way switches that I ever have.
    That photographic diagram for MHD is really nice.
    2 people like this.
  19. jonesy
    17,190
    4,411
    Mar 28, 2008
    That is actually a 3 way toggle switch not a 5 way, and the switch shown in that MHD diagram is an import style toggle switch which has a slightly different layout than a Switchcraft toggle switch like you see in many LP's. Hot lug out and ground lug are on opposite sides of the frame.
  20. smorgdonkey
    2,093
    1,435
    Jan 26, 2009
    Yes. I was just commenting on wiring diagrams in general like for H/S/S or H/S/H super strats and so on.
