~Pickup Magnet Differences~
Discussion in 'Pickups' started by joek86, Apr 23, 2011.
  1. joek86
    joek86 Senior Member
    378
    112
    Aug 24, 2008
    I have been using A5 magneted pickups almost exclusively until today. I pulled out a guitar loaded with A2's. The guitar sounded stronger, thicker, greasier with less stuff going on and more fundimental tone. My question for guys that know their pups and mags is this; is this characteristic of the difference in these mags or the guitars that I was playing?
    FYI, The A5 pups have more output than the A2's. Both are top notch boutique built pups.
    ~Joe
  2. GuitarToneFreak
    GuitarToneFreak Senior Member
    6,959
    9,675
    Jan 10, 2011
    Wait until a winder chimes in for a better definition, but from what I understand Alnico 2 is more "smokey" and full than A5. A5 tends to be a stronger, higher output pickup, so your description of A2 compared to A5 sounds accurate to me :dude:
  3. captcoolaid
    captcoolaid Senior Member
    11,412
    3,906
    Nov 29, 2008
    A2s are smoother, A5s have more mids. The A5 has a stronger guass. Just because a pup has an A2 or A5 does not mean it is gonna be a higher out put or higher dc pup. They are used for completely different reasons. The mags will drastically change the overall shape of the pickups tone a great deal. Think of it this way same wind different mag different tone.
  4. joek86
    378
    112
    Aug 24, 2008
    What are the trademark differences in tone between the two...i'd like to compare it with what I am hearing. It should guide me as to whether I should try a set with different mags or not.
    ~Joe
  5. captcoolaid
    11,412
    3,906
    Nov 29, 2008
    A2 has a smoother tone to in general and an A5 has more mids and bite.
  6. Zhangliqun
    Zhangliqun Senior Member
    1,597
    751
    Apr 10, 2007
    A5 has more UPPER mids. The chewy mid-mids are lacking. It's a lot like taking an A2 and cranking up bass and treble/upper mids but the mid-mids (the ones we crave) get left behind. Basically A5 is kind of scooped. That can be good or bad, it all depends on the context.
  7. joek86
    378
    112
    Aug 24, 2008
    Thanks guys!
  8. BillB1960
    BillB1960 Senior Member
    15,908
    21,224
    Jun 1, 2008
    My favorite pickups from boutique as well as major manufactureres use either Alnico 2 or Alnico 4 magnets although not every Alnico 2 I've tried has been stellar. Ex: I love Classic 57 p'ups and they have Alnico 2s but the Burstbucker 1 & 2 also have A2s and I'm not a fan of those. The GuitarForce LOTBs that I adore in my G0 have A4s.
  9. rocknhorse1
    rocknhorse1 Senior Member
    8,780
    2,757
    Feb 22, 2010
    I have heard a lot of people say they like the A4 mags. From what I have heard they have a push in the lower mids, like under 600hz. Does this seem right to you Bill? I have never played them so I don't know for sure, just going by what I have heard in demos.
  10. BillB1960
    15,908
    21,224
    Jun 1, 2008
    I'd say that accurately describes the LOTBs. They have kind a bowling pin shaped kind of sound if that makes sense. :hmm:
  11. 5F6-A
    5F6-A Senior Member
    9,464
    2,016
    Aug 16, 2007
    don't forget AIV...
  12. LtKojak
    LtKojak Senior Member
    4,017
    2,739
    Aug 26, 2009
    I consider the A4 mag the perfect mag for a neck p'up. It's got sizzle, but without ever being boomy nor shrill, as A5 does, and you can make it sound both vintage and modern, depending on your rig's EQ. It's got a polite but commanding tone and kind of a flat EQ. It pairs beautifully with either an UnOriented A5 (UOA5) for a vintage vibe or my favorite, A8, for the bridge spot.
    HTH,
  13. 5F6-A
    5F6-A Senior Member
    9,464
    2,016
    Aug 16, 2007
    interesting approach.... ;)
