Pickup doesnt read correct with ohm meter?
Discussion in 'Pickups' started by SlyStrat, Oct 17, 2017.
  1. SlyStrat
    SlyStrat Senior Member
    1,798
    899
    Jan 24, 2009
    Instead of staying steady at a number it fluctuates greatly. Broken wire inside?
  2. DarrellV
    15,375
    32,588
    Nov 1, 2016
    Or faulty ohmmeter leads?
    You should check that meter on a known good resistor or coil of some kind to be sure.
    Especially digital meters. i have found them flaky.
  3. Who
    15,741
    27,925
    Mar 15, 2012
    Why were you measuring it? Was there already a suspected fault?
  4. judson
    judson Senior Member
    2,747
    2,661
    Jan 26, 2016
    awhile ago i posted a similar question when i got no ohm reading but the pickup worked :dunno:
    but yeah let the experts chime in
    if your ohm meter is working properly, then u may be correct
  5. DarrellV
    15,375
    32,588
    Nov 1, 2016
    I was going to ask if there was an audible issue like weak or scratchy sound...
    First rule in trouble shooting is always to verify the problem and rule out other possible causes along the way.
    This would include cross checking your meter equipment on something else to see if it fluctuates too...
  6. SlyStrat
    1,798
    899
    Jan 24, 2009
    Other pickups read fine.
  7. cooljuk
    14,089
    17,950
    Mar 12, 2009
    This can happen in a pickup coil that is broken but still has a capacitive coupling. ....because the meter sends a DC voltage from one probe to the other to take the measurement. Or it can happen on a pickup with a loose connection. That happens on Fender pickups with partial failures at the eyelets.
    Does the pickup sound ok? Sound thin and weak?
    jamman likes this.
  8. jamman
    jamman Premium Member
    9,196
    7,422
    Oct 1, 2010
    ^^^Perfect answer ....:cheers:
  9. SlyStrat
    1,798
    899
    Jan 24, 2009
    The pickup works. Its pretty bright for a neck pickup. Its as loud as the bridge pup. How do I know if its working to its full potential? Thanks.
  10. cooljuk
    14,089
    17,950
    Mar 12, 2009
    If other similar pickups read fine on the same meter and that one fluctuates strangly, that's a sign in itself that it's not right.
    An LCR meter or oscilloscope could provide more information.
  11. SlyStrat
    1,798
    899
    Jan 24, 2009
    I think it has a broken coil. How much to fix it, James?
