Pickguard on or off?
Discussion in 'Gibson Les Pauls' started by Gahr, Mar 7, 2018.
What do you prefer?
  1. Pickguard on
    70.3%
  2. Pickguard off
    24.3%
  3. Ratz A$$
    5.4%
  1. Duane_the_tub
    Duane_the_tub Senior Member
    1,852
    3,035
    May 31, 2015
    Ok, for the hundredth time:
    Pickguard on. Straight-end cables. Pickup covers on. Jeans and boots. Brunettes. Boxer briefs. Vanilla.
    Left Paw, BeanoFAN and Gahr like this.
  2. JeffH66
    JeffH66 Pelham Blue Addict Premium Member
    325
    445
    Oct 31, 2010
    On, always on. I have a Gary Moore LP Standard with a killer flametop. It came without the pickguard installed. The guys at my other guitar forum almost unanimously pleaded for me not to drill the top, but every time I look at it all I can think is "it's missing the pickguard." It will happen eventually.
    Put it on, especially on the GT. And cream, always cream.
    Danomyte and Gahr like this.
  3. redcoats1976
    redcoats1976 Senior Member
    9,047
    5,485
    Feb 2, 2009
    on...reflector knobs.
    Gahr likes this.
  4. Prometheus
    Prometheus Senior Member
    1,916
    2,794
    May 22, 2012
    What is this heresy?! Redheads any day of the week!
  5. Jymbopalyse
    Jymbopalyse Senior Member
    2,022
    4,041
    Oct 3, 2016
    To the OP
    Yes. Most definitely !
    X–Ray and Gahr like this.
  6. BeanoFAN
    BeanoFAN Member
    84
    225
    Mar 5, 2018
    And dont forget switch washer (the forum won't let me call it a poker. chip.)
    Duane_the_tub likes this.
  7. Cygnus X-1
    Cygnus X-1 Senior Member
    227
    178
    Feb 28, 2017
    I had the same issue- am I missing something? Is this a new obscene phrase the kiddies are using these days??? Or is it b/c it's in reference to gambling?
  8. BeanoFAN
    BeanoFAN Member
    84
    225
    Mar 5, 2018
    Honestly for me it just sounds better than switch washer lol.
    Cygnus X-1 likes this.
  9. Duane_the_tub
    1,852
    3,035
    May 31, 2015
    I agree with you 99% (I married a brunette). But the classic question is "blondes or brunettes?"
  10. Dick Banks
    Dick Banks Senior Member
    467
    503
    Apr 27, 2017
    It's just something that will get you "punched in the nose." Virtually of course...
    You should try asking about tone and string gauge sometime. My nose is still hurting from that one....
    BeanoFAN likes this.
  11. crazytrain513
    crazytrain513 Senior Member
    1,411
    855
    Nov 1, 2012
    I generally prefer goldtops with the pickguard on if they have pickup covers.
    Pickguard off if you take off the pickup covers :slash:
    You might also have to decide yourself based on playability.
    I took it off a Trad I had once and I couldn’t play it right. Your hand gets used to resting on the pickguard sometimes when you play. That and just the visual difference when playing threw me off so back on it went.
  12. scozz
    scozz Senior Member
    3,202
    3,631
    Sep 3, 2007
    mgenet likes this.
  13. ARandall
    ARandall Senior Member
    11,731
    7,069
    Apr 16, 2012
    ^ I'm still with pickguard on even with covers off.
    JohnnyN likes this.
  14. mgenet
    mgenet Cheese Burger = Earth Silver Supporter Premium Member
    10,890
    14,745
    Sep 18, 2010
    2 centavos pro favor...
    Also forgot the Classic di rigueur in any MLP poll:
    Ratz Azz
  15. moreles
    moreles Senior Member
    2,661
    1,279
    Apr 16, 2011
    Yes. You should either put the pickguard on or leave it off. Case closed.
    mgenet likes this.
  16. NewDayHappy
    NewDayHappy Senior Member
    1,422
    2,204
    Dec 18, 2016
    I'm putting a pickup washer on my '17 Standard, I'd like the pick guard on, but I can't see myself drilling a hole in my Les Paul, so it will probably be no pick guard for me.
  17. C.J.
    C.J. Senior Member
    174
    88
    Dec 28, 2015
  18. rtTX
    rtTX Member
    52
    38
    Sep 12, 2017
    Surprised your ‘17 Standard didn’t come with pick guard. Mine did and it doesn’t require the bracket or the typical 2 screws in the body. However, my Standard is HP, maybe yours a “T”?
    If, next to the body, the treble side of each of your pickup rings have a small notch cut out them Gibson makes a ‘clip-on’ pick guard that was frequently left off the guitar but included with the case candy. That’s now mine arrived and and I popped it on immediately.
    BTW, the underside of pick guard has a clear rubber bumper thingy to position guard proper distance from body as bracket does but without need of the bracket or its screw. Looks cleaner without bracket so best of both worlds really: you can have guard without the typical bracket, or you can easily pop it off leaving no holes in body.
    I prefer the pick guard on whilst playing but I like the ability to easily and toollesssly remove it for the occasional cleaning & polish.
    Not sure if Gibson sales the HP’s plastic pickup rings and guard separately but that’s the route I’d take if they do to avoid having to drill 2 holes unnecessarily in a guitar that didn’t already have them.
    NewDayHappy likes this.
  19. dsmcl77
    dsmcl77 Senior Member
    3,149
    8,852
    Jun 2, 2014
    "Pickguard On" gives the Les Paul a rich sustaining tone with focused mid frequencies that cut through the mix and drive the amplifiers into creamy compressed overdrive. :jb:
    But if you want to drive the amps into wild distortion, cutting mids and treble while retaining rounded bass, and harmonics that spurts out of the guitar, then it's "Pickguard Off" .:slash:
    Perrystrings likes this.
  20. NewDayHappy
    1,422
    2,204
    Dec 18, 2016
    Only the HPs come with the clip on, mine is a standard and it requires you to drill two holes into the body to install it, I refuse to do that. A clip on pickguard is something I'd be interested in buying, but from my understanding they're rare and quite expensive, maybe I'll keep my ears tuned to eBay for one. The washer is a no brainer though, only cost me $5 from Sweetwater, shipping included.
