Pick guard fix question.....
Discussion in 'Luthier's Corner' started by HardCore Troubadour, Aug 29, 2017.
  1. HardCore Troubadour
    HardCore Troubadour Senior Member
    8,284
    6,064
    Nov 17, 2012
    hey guys,
    I know that most of the newer pick guards on acoustics are attached with double sided tape etc. etc.
    I have the very point end of a guard on my Songwriter that is lifting, and I really do not want to take it completly off and re-apply if at all possible.....it is not really enough to get it raised and slip a piece if tape under it unless I use tweesers and then would probably need to trim the excess, which scares me a little.....
    this is a very small thing maybe 1/4-\ to 1/2 an inch, but it catches my pinky sometimes when strumming and hurts like hell......
    is there anything I can do?
    what is the best solution?
    thanks for any help....
    HCT
  2. DarrellV
    15,451
    32,960
    Nov 1, 2016
    Take up drumming, maybe.....:run:
  3. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    theres a smartass in every crowd and guitar crowds have 4.....
    :cheers2:
  4. DarrellV
    15,451
    32,960
    Nov 1, 2016
    You know you'll always be my hero, Lee! :cheers:
  5. fumblefinger
    fumblefinger Senior Member
    1,206
    491
    May 10, 2012
    On a serious note, could you get a syringe needle under it? A little thinned Titebond injection and a clamp?
    I Break Things likes this.
  6. kiko
    kiko Senior Member
    1,087
    1,229
    Jul 16, 2015
    Do it right, take it off and fix it properly.
  7. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    I can get a needle under , but I am pretty sure it is on with tape, not glue.
    man, I hate to take it off for 1/8" corner, but if that is the best tining????
  8. DarrellV
    15,451
    32,960
    Nov 1, 2016
    I'll prolly get banned for suggesting this, :wow:but if its such a small amount could you just clip it off with some nail trimmers or something?
    Slip some tape under there and reshape it with an emery board?
  9. jkes01
    jkes01 Senior Member
    2,075
    954
    Jan 10, 2011
    A few pics of the area might help.
    Those pick guards are thicker than most. The one on my hummingbird artist is a little thicker than the one on my Martin.
    Maybe warm it up with a hair dryer, press and hold it back down. Might get that adhesive re-activated. That's what I would do before I pull it. :thumb:
    fumblefinger likes this.
  10. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    I would take it off before cutting.....I will try the hair dryer and see...if it does not work, I will post a pic....yes they are thicker than a normal "flat" guard....almost a little scalloped on the edges.
  11. lowatter
    lowatter Senior Member
    1,218
    670
    Oct 1, 2009
    Without pictures it's pretty hard to have the guys here help you so that a proper assessment and suggestions can be made. If there was something that caused the pickguard to lift such as heat or material abnormalities etc. Please take a pic and submit it for better suggestions.
    Without seeing the issue I would use 2 sided tape after lifting the guard and cleaning the area of debris. JMHOYMMV
  12. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    I will get some pics tonight....I got tied up.
    No heat or material defects etc. it is as if the tape from the factory is not adhearing in that last little bit at the bottom point of the pickguard.
  13. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
  14. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
  15. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    after all that, nothing.......lol
    c'mon, help a brother out.
  16. jkes01
    2,075
    954
    Jan 10, 2011
    The answers have already been provided, you just need to choose your path. Double stick tape is where I would be at if the hair dryer didn't work.
  17. HardCore Troubadour
    8,284
    6,064
    Nov 17, 2012
    but do I really need to pull the entire thing?...and if not, once stuck, how do I trim the excess tape to fit, without damaging a 2K guitar?
  18. jkes01
    2,075
    954
    Jan 10, 2011
    You can try to slip double sided tape (3m or stewmac) under the area and press it back down. Providing that there is no adhesive there to start with. Trim with a new exacto blade. Light touch is needed to only cut the tape.
    The other option is to take it to a qualified Gibson repair shop.
    D Rhinehart likes this.
  19. barchiola
    barchiola Senior Member
    266
    101
    Dec 11, 2008
    another option is to slide a sliver of hot glue under the loose tip of the pick guard. carefully heat up the area and when the glue appears soft, remove the heat and use a small weight to hold the tip of the pick guard down. Trim excess glue with an xacto knife after it cools off. be really careful you don't mar the finish with the heat though!
    i cut slivers of hot glue to slide under heat shrink tubing to adhere the tubing to the wires inside and to fill where tubing might be too big for the wires. works great.
  20. smk506
    smk506 Senior Member
    2,164
    2,993
    Jan 5, 2009
    I used to use this 3M double sided tape in a picture frame shop. It was thin, strong and acid free for preservation needs. If you can get it under there you could remove the excess with a light swipe with an exact nice and a strongish scrubbing motion. It comes backed so if I were to use it I would cut some strips, work them in, sticky side down, remove the backing and less down.
    I have no idea how these would react with any finishes though someone at 3m likely would.
    https://www.3m.com/3M/en_US/company...ape-Acid-Free-908?N=5002385+3293241540&rt=rud
