Phaez Amps [merged]
Discussion in 'The Squawk Box' started by LPV, Jun 27, 2009.
Phaez sub forum? Yes or no?
  1. Yes
    44 vote(s)
    51.8%
  2. No
    41 vote(s)
    48.2%
  1. V2
    V2 V.I.P. Member
    2,215
    2,376
    May 30, 2011
    Probably pretty similar.
    It's easier to drive the snot out of an EL84, so it can sound more aggressive. Personally I like the JJ 6V6S.
    cherrysunburst00 likes this.
  2. Duane_the_tub
    Duane_the_tub Senior Member
    1,182
    1,432
    May 31, 2015
    OK, somebody with Phaez experience want to weigh in on how this sounds?
    Concept: Plexi/Dumble home amp
    Channels: M87X and Daisy Cutter, each with lo+hi inputs
    12 watts, with power scaling down to >1 watt
    Power section: 1XEl34 (can also take a 6V6 or 6L6, auto biasing)
    Tube-driven FX loop
    Anything else worthy of inclusion? Like I said, it'll be a home amp. I also already have my Fender bases covered.
    musicmaniac and cherrysunburst00 like this.
  3. cherrysunburst00
    cherrysunburst00 Senior Member
    9,885
    10,494
    Mar 15, 2015
    COOL idea
    Duane_the_tub likes this.
  4. Pleximan
    Pleximan Premium Member
    377
    313
    Aug 9, 2013
    Yes, it's easier to drive EL-84 tubes in to saturation. The EL-84 really doesn't like it much. My Phaez McClane eats EL-84 tubes for lunch. They usually need replaced after about two months for me. The amp is used in a full band situation though. The 6V6 tubes would definitely last longer and give you that glassy, rounded slash tone. You can tell on AFD he's not using EL-34's in the amp. It's very smooth, glassy, and round. Aggressive in the bass register, a characteristic of 6550's. 6V6 tubes IMO would be closer to that or closer to a 6L6 even. The circuit really matters in this case. Old Marshalls need EL-34's; new inspired by amps can be built around any power tube and still sound like the intended amp. My Demeter TGA 2 inverter cops a very close to Fender clean with EL-34's or 5881 tubes. Or a full bore Marshall overdrive with the same said tubes.
  5. V2
    V2 V.I.P. Member
    2,215
    2,376
    May 30, 2011
    He also used Alnico II pickups, which give an extra glassy sound (as on 'under the bridge' by the Red Hot Chili Peppers). You can get smooth tones out of EL34s with those pups....
    bufbills likes this.
  6. rclausen
    rclausen Senior Member
    2,573
    1,974
    Nov 9, 2011
    I'm not familiar with the M87X but the Daisy Cutter isn't going to give you anything close to a plexi or dumble sound, unless you're after a SUPER saturated plexi tone. He has/had a dumble inspired circuit.
  7. Duane_the_tub
    1,182
    1,432
    May 31, 2015
    I might have the name wrong then. It's whatever he calls his Dumble OD circuit.
  8. rclausen
    2,573
    1,974
    Nov 9, 2011
    HRM possibly? Either way, it sounds like a great amp. I think it would end up leaning more towards the plexi with the el34 and more dumble-ish with a 6l6
  9. Duane_the_tub
    1,182
    1,432
    May 31, 2015
    Upon further review, seems like the Dumble circuit would be much more functional as a standalone amp. I instead went with a Plexi for the clean channel and the Daisycutter - the circuit that put Randy on the map - for the OD channel. 12 watts with power scaling, power section swappable between EL34 and 6V6/6L6, hi-lo inputs and a loop.
    Build is underway - stay tuned!
  10. singlecut
    singlecut Senior Member
    7,960
    6,149
    Jul 11, 2007
    Looking forward to your opinion
    I have a Phaez or 2
    Really good amps
  11. Duane_the_tub
    1,182
    1,432
    May 31, 2015
    Done, awaiting shipment. Am I excited? Yeah, just a little...
  12. cherrysunburst00
    9,885
    10,494
    Mar 15, 2015
    NICE!!! CONGRATS!!!
    I luv me dem tube amps
  13. jay1williams
    jay1williams Senior Member
    2,160
    1,014
    Mar 3, 2010
    Awesome, Congrats!!
    Post some clips when you get it...
  14. needlespauls
    needlespauls V.I.P. Member
    6,178
    1,117
    Jan 14, 2008
    Depending on finances this year...I might just try out a simple 6v6 low watt Daisycutter. Seems like the bread and butter high-gain circuit.
    Liked the 2 Phaez amps I had in the past a lot....I played a used Daisycutter at a local store a couple years later and was like dammit!! That’s the sound that matches up with me. We’ll see....
  15. cherrysunburst00
    9,885
    10,494
    Mar 15, 2015
    I've been wantin' a 6v6 amp meself.
    Which 2 Phaezes did you have?
    Had me a SIBLY w/1 el34 and powerscaling. Pretty darn nice amp. I miss it.
    needlespauls likes this.
  16. jay1williams
    2,160
    1,014
    Mar 3, 2010
    Randy gets killer tones out of 6V6's, not sure how he does it...
  17. V2
    V2 V.I.P. Member
    2,215
    2,376
    May 30, 2011
    I'd like to know who owns the two custom 10W Daisycutters that I built. I don't think the original owner has 'em anymore. They were pretty darn good amps....
  18. needlespauls
    6,178
    1,117
    Jan 14, 2008
    I had the very first Pasadena...a 50 watt EL34 version, and an 18 watt EL84 Jackal. Overall I liked the Pasadena better, but I don’t think I got to spend enough time with the Jackal. I know for a fact that at the time the cab I had probably didn’t do the two heads enough justice.
  19. Duane_the_tub
    1,182
    1,432
    May 31, 2015
    The eagle has landed. I'm gonna wait on the NAD post until we've become better acquainted, but right out of the box: I'm pretty psyched.
    V2, rclausen and jay1williams like this.
